Attending
Andrea Aime
Kevin Smith
Torben Barsballe
Gabriel Roldan
Ian Turton
Actions from last meeting:- [DONE] Nils: Discuss GS Docker image on email list, proposal to follow (see dev guide)
Justin: PR to remove himself as maintainer various pom.xml files
Kevin: Review pom.xml for “boundless”
[DONE] All: Join the Bolsena code sprint for July 2nd and 3rd
Jody: [DONE] Ask attendees their address, and send food / beer / breakfast as appropriate (ended up with t-shirts)
Agenda- 2.17.3 release date
Rename master branch?
Jenkins concurrent builds
GeoServer microservices project
GeoTools GeoJSON store upgrade (https://github.com/geotools/geotools/pull/3051)
Sprint Updates
Actions-
2.17.3 release date
Yep, really 2.17.3.
https://github.com/geoserver/geoserver/wiki/Release-Schedule
Will be done in parallel with 2.18, will figure out the logistics and precise day when we get there.
No.
We are all masters here, there are no slaves!
Would require considerable changes to build server config. If someone wants to do the work, we can reconsider then.
https://osgeo-org.atlassian.net/browse/GEOS-9647
Also reference to GitHub: https://www.bbc.co.uk/news/technology-53050955
If we were to change, the following would have to be modified too:
The developer guide
Jenkins builds and potentially release scripts
PR checks (some of them, the cross-project one for example)
Documentation redirects/aliases (e.g. https://docs.geoserver.org/master/en/user/ etc.)
See email for background.
Builds cannot share the same workspace
All the main branches have their own workspaces
The java 11 builds do not have this … should we do something similar.
Maven local repository is not designed to be accessed by multiple builds:
We can consider making a separate maven repo for each build category?
we looked at this also during “new branch release” multithreaded build issues
Just a geoserver build weighs in about 5G
Q: what is A,B,C?
- We cycle through master, stable, maintenance, so they are arbitrary labels
Q: can we have “master”, “even”, “odd”?
Yes, but you have to change all the jobs by hand (jenkins is not smart about this rename)
Check release guide for update instructions…
Customer requirements:
HA
No filesystem
Dockerized environment
Compare:
Catalog with https://github.com/planetlabs/stratus (thick geoserver) on spring boot without filesystem, with a redis catalog, has a deep fork of GWC, good service startup fast
GWC extensibility
An example of difficult workarounds get spring boot and GeoServer to work
XML vs Annotation-based config: https://jira.spring.io/browse/SPR-7028
JDBC Config, still poor layer lookup performance with many layers (tens of thousands) (tested spring 2020)
Besides running separate microservices in a filesystem-less infrastructure, a by-product goal is to come up with per-service dimensioning specs for different workloads.
It also involves running on Java 14 and investigating the benefits and/or tradeoffs of using the ZGC. On the bright side, for containerized apps, it returns unused heap to the operating system, on the dark side, looks like it may report higher memory usage than it’s actually using.
Choice:
Do as a cluster of community modules
Eventually it could be a separate project under geoserver’s github organization
A mixin of the above two
Trying to get rid of gt-geojson, based on simple-json, and move to jackson. Part of the “bug fix” sprint too. Long term, replace json-lib generator too.
Bug fix Sprint
Thanks for participating.
A bump in fixes!
JTS 1.17.0 update, API change on geometry.reverse() causing some API changes for us.
Unchecked warnings cleanup
Begin of it: https://github.com/geotools/geotools/pull/3043
Approach: fix the easy ones, ignore the complicated ones like RangeSet
Community interest
make a public geotools branch for this cleanup
Andrea to setup a google doc
Example: gt-main has 700 warnings
