GeoTools / GeoWebcache / GeoServer Meeting 2017-09-19
Attending- Ian Turton
Jody Garnett
Kevin Smith
Torben Barsballe
Jukka Rahkonen
Agenda1. beta released
Swagger REST API docs
Release schedule
Actions from last Meeting- Jody: (done) beta release, blocked on GWC security issues
Nicolai: Write a proposal for API Change to FactoryRegistry
Jody: Create draft FOSS4G blog post, kudos to Andrea
Actions- Action (who?): Get ssh access to provide build box with “geotools” git user?
Torben: try this on core, send example to list and ask for help on extensions
Kevin: Create a GSIP placeholder page for next release about bundling API docs and User docs as optional extensions for GeoServer
Torben and Jody…: 2.12 RC1 (Week of Sept 25)
Ian (and Kevin?): 2.12 Release (Week of Oct 2)
Jody: Update release schedule
Beta Released
Thanks for doing the release Torben (and Andrea). Thanks to David Vick (with Devon, Torben) for completing the GWC migration restlet → spring.
Trouble:
GWC migration took longer
Integration with GeoServer resulted in duplicate contexts
We were not reading the request the right way so the body right way, changed to request parameter
JTS 1.14 broke our single dimension use of DefaultCoordinateSequence
Introduced JTS utility class method and avoided direct use of JTS Factory
Probably would of been cleaner to add logic/wrapper to DefaultFactoryFinder
Documentation change to ant / maven needed updated build scripts
fixed with torben
GeoTools publish build needs credentials to publish tag
Action: Get ssh access to provide build box with “geotools” git user?
Links:
Technical debt, work to do before release?
Complete swagger docs, in many many places, see next agenda point
GEOS-8215 - shows a design problem with “default” mime type for a process input
Can use you use factory get priority? To get a consistent array order …
GEOS-8291 - release data dir style linking issue
Rest API Spreadsheet
Status:
Torben is 1/3 of the way through checking core
styles, layers and importer are remains
John is 3/4 of the way throw GWC docs
What to check API
Missing endpoints that are undocumented
Check docs against the code
find missing query parameters
Undocumented features in the REST API
Documented functionality that is not implemented
Model output
check doc page links to complete list of api/1.0.0 docs
What check to examples:
- Examples migrated from CURL, Python, Java, Ruby → Endpoint with examples of CURL, …
Open questions:
How to document connection parameters for DataStores?
Swagger provides a generic key/value map
Idea: keys form an enum, enum documents the values
This does not work well as a distinct set of keys is required for each format
Ideas: Example of each kind of DataStore
Limit to the formats that come out of the box? Or include supported extensions?
Link to the GeoServer RST pages pages to document parameters
May need to create this
Can we GeoTools RST? It is not complete either …
Minimal example of creating each kind of DataStore
This is what people will use
Maximal example of updating each kind of DataStore
Use this to document parameters
Can we link to user guide to document parameters:
http://docs.geoserver.org/latest/en/user/data/database/postgis.html#using-default-connection
http://docs.geoserver.org/latest/en/user/data/database/index.html#data-database
Idea: Can we make a heading just for the table and combine forces and document once for GUI and REST API
Q: What about when key does not match gui label?
Q: What about keys that do not appear in the gui?
Q: Can we automatically generate a table based the live DataStoreFactory parameters.
Yes it is how we maintain function list in GeoTools
So this approach would be to generate format reference pages in the REST API section of the restructured?
How to include API in download doc bundle?
The website uses a javascript application - probably need a GISP for this
Can we include this in the geoserver app bundle? This is possible it is just an html page with a javascript app that reads, displays yaml
Could link to it from the html output?
This would allow swagger examples to run
As an extension? Detect docs in data directory and link …
As an extension that includes docs …
Maven pom.xml genrates api docs (looks bad) but we can include that in the standalone documentation
Result of discussion:
Provide an example of creating each datastore
Do not document connection parameters this release because we do not have a good approach
Idea: Try Enum + Reference Approach below
Action: Torben - try this on core, send example to list and ask for help on extensions
About shipping API docs, just focus on shipping for the website this release
Action: Kevin - Create a GSIP placeholder page for next release about bundling API docs and User docs as optional extensions for GeoServer
MetadataEntry:
type: object
title: entry
properties:
‘@key’:
title: key
type: string
enum:
description: Key used for metadata entry, additional keys are added over time
title: text
type: string
description: Text value for provided key Valid text depends on key used. Example {‘@key’=‘buffer’,‘$’=‘5’}") or 5
So we would make a connection parameter definition for each connection parameter of each format (Shapefile, PostGIS, DB2, etc…). We may even be able to reuse the database connection parameters this way if we are tricky …
And then when documenting datastores endpoint we would make a list that “refs” each of the connection parameter definitions.
Release schedule
Not much response to the email thread:
Asked about when to do RC1, considered tomorrow Wednesday?
Note: New branches and jobs takes a bit more than usual
Volunteers needed
Torben may be available after swagger review (after Friday)
Kevin is just back from holiday and does not know his availability yet …
Jody is on holiday next week and can be available (sigh)
Ian has work work deadlines but can help week of Oct 2nd
Looks like we can somehow make an RC1 the week of September 25th
- Action: 2.12 RC1 A combination of Torben and Jody …
And a release the week of October 2nd
- Action: 2.12 Release a combination of Ian (and Kevin?)
Action: Jody to update release schedule
Ian Turton
Placeholder for GSIP-163 - Internal Documentation Provider
https://github.com/geoserver/geoserver/wiki/GSIP-163
I added a few more ideas to consider.
Jody Garnett
Kevin Smith
Torben Barsballe
Jukka Rahkonen
Release schedule
Beta Released
Trouble:
fixed with torben
Links:
Status:
What to check API
Model output
Open questions:
MetadataEntry:
type: object
title: entry
properties:
‘@key’:
title: key
type: string
enum:
title: text
type: string
Release schedule
Volunteers needed
Ian Turton
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
GeoTools 18-beta tag now pushed to git, and the publish job should be fixed.
Torben
Jody Garnett
Kevin Smith
Torben Barsballe
Jukka Rahkonen
Release schedule
Beta Released
Trouble:
fixed with torben
Links:
Status:
What to check API
Model output
Open questions:
MetadataEntry:
type: object
title: entry
properties:
‘@key’:
title: key
type: string
enum:
title: text
type: string
Release schedule
Volunteers needed
Ian Turton
[Geoserver-devel@anonymised.com.366...sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Geoserver-devel@anonymised.com.366…sourceforge.net
