GeoTools/GeoWebCache/GeoServer PMC meeting - 2021-04-27### Attending#
Torben Barsballe
Kevin Smith
Jukka Rahkonnen
Jody Garnett
Andrea Aime
### Actions from last meeting:#
- [DONE] AA: ask on the list about a 2.18.3 release manager
### Agenda#
GSIP-202
GWC release script
Automatically close stale PRs?
Build server issue
### Actions#
action: Kevin is going to fix gwc release.rb using xpath or something
action: Kevin will look at GWC website upload
action: Assign a new port for LDAP testing (since we made a new release)
GSIP: https://github.com/geoserver/geoserver/wiki/GSIP-202
GeoServer homepage replacement, dedicated home page for workspaces, driven by freemarker but allow programmatic contribution. Remove version and commit numbers from pages accessible by anonymous users.
Discussion:
How do we discover workspaces? Right now they are not discoverable. Should they be? We should allow hiding them though, like with a security rule. Right now worksapce is adminable, but is it accessible? What about interaction with security subsystem?
How do security rules interact with the new page features, freemarker template configuration and with listing services and workspaces?
## GWC release script and docs#
Thanks to Ian for making the GT/GS release
Release script changes:
Change to pom “broke” release script, which was looking for a specific comment
Jody did a hack (ruby sub( search, replace ) vs sub! search, replace ← why why why
Action: Kevin is going to go fix it now using xpath or something
gwc website update?
cction: Kevin will look at this?
aside: documentation is done by copy, so old pages are not removed…
Can we delete everything before copy? Not so easy with S3 …
Going to github pages, limits run into 1GB limit, soft limit of 100GB bandwidth a month, soft limit of 10 builds an hour …
Q: Can we stay under 1GB?
Yes if we do stable, maintenance, latest …
It was around 500 MB last time we checked
html docs zip is 92 MB
/tmp/geoserver-2.18.3 $ du -csh *
2,5M api
5,8M developer
20K LICENSE.md
4,0K README.txt
112M user
4,0K VERSION.txt
120M totale
Automatically close stale PRs?#
Danger zone, what will Andrea break next
https://probot.github.io/apps/stale/
Can a bot do that? Yup…
- Can we exclude a PR from bot clean up (say with a tag?)
Potential config:
Number of days of inactivity before an issue becomes stale
daysUntilStale: 90
Number of days of inactivity before a stale issue is closed
daysUntilClose: 14
Issues with these labels will never be considered stale
exemptLabels:
- pinned
Label to use when marking an issue as stale
staleLabel: wontfix
Comment to post when marking an issue as stale. Set to false
to disable
markComment: >
This issue has been automatically marked as stale because it has not had
recent activity. It will be closed if no further activity occurs. Thank you
for your contributions.
Comment to post when closing a stale issue. Set to false
to disable
closeComment: >
This issue has been automatically closed because it has not had
recent activity. Please re-submit with updates if you want to resume work on this topic. Thank you for your contributions.
## Build server issues#Should we set up different maven repositories to avoid conflicting updates of shared files, like
“/var/lib/jenkins/.m2/repository/org/geotools/gt-s3-geotiff/maven-metadata-local.xml”
See the *-java11 tests on jeknins for an example of how this could be configured
Port conflicts between concurrent tests:
- H2 tests for example make use of a local test, there is a variable to disable these tests
LDAP test port issue?
- action: we forgot to assign a new port when we made the most recent release!
