[Geoserver-devel] [Geotools-gt2-users] Re: SPAM: ImageMosaic vs. GeoTIFF tiling
Ciao Patrick, nice work.
Together with staff member from the Univ. of Genoa in Italy, we are
working for a customer on an approach to put generic rasters inside
postgis. When I say generic I refer to multiband spatiotemporal
rasters with multigranular resolutions.
Basically the idea is to ingest raster data into postgis that can span
over time and elevation/depth doing some good old preprocessing on
them which obviously includes tiling and adding overviews to the
original data. Actually for the moment we are keen to keep the final
data (tiles basically) outside postgis but we are trying to describe a
db schema + a lib structure that could allow to store them right
insided the db in case one wanted to do so. we are, of course,
planning on making an extensive use of JAI and ImageIO.
In the following weeks we should start sending out some schemas/code
hopefully in order to get some feedback.
Note that this work is not focused on creating a catalog of raster
data but rather on finding a way to ingest data and keep them stored
inside (or indeed by) a spatial db.
In this perspective your code sounds like a nice effort that we would
love to integrate somehow in the work we are carrying out.
Ciao,
Simone.
On 8/16/07, Patrick Way <pat@anonymised.com> wrote:
Hi Jody,
Thanks for the kind words and information about naming the java classes. I
would be interested in working with the community to improve this method of
managing rasters in the PostGIS database. My motivation for developing this
process was to achieve maximum performance with regards to rendering rasters.
If the grid size and resolution are chosen wisely then at any scale the sum
of the raster images required should not exceed 10-15 megabytes. By
preprocessing the images into smaller tiles the computer has less work to
perform and the image can be drawn faster. Also the GridCoverages generate a
bit faster than geotiffs partly because the transform and spatial reference
data are preprocessed as well. The cost for this concept is a large amount
of data stored which can be mitigated with a large hard drive.
Pat
On Wednesday 15 August 2007 20:00, you wrote:
> This sounds like a great hack Pat, are you planning on taking this
> anywhere?
> The PostGIS community keeps on wondering how to represent rasters in the
> database, I know OracleSpatial already has some crazy construct for it.
> A couple of comments about your code:
> - Java classes usually begin with an uppercase letter (ie not vtRaster)
> - If you and the user list are interested you can set up an unsupported
> module to collaborate on this idea
> Cheers,
> Jody
> Patrick Way wrote:
> > Hello,
> > I have had success by creating image tiles of varying resolutions and
> > storing them in a postgresql/postgis database. The element that makes
> > this possible was figuring out how to store geotiff files in a database.
> > To do this I created an imagecatalog table:
> > float --> resolution
> > geom --> envelope
> > text --> crs
> > text --> transform
> > double --> scale
> > bytea --> image
> > Then I wrote a java class for parsing a GridCoverage into the
> > binary,crs,and envelope data. Another class for the GridCoverage format
> > that is similar to a world file format.
> > I have been working with large geotiff files, to make them manageable I
> > have tiled them into grids at various resolutions and stored the tiled
> > images in the image catalog table
> > When I want to draw images on a map I use the map scale to determine the
> > appropriate resolution value then select the images from the image
> > catalog table that intersect the envelope and equal the resolution
> > value.
> > The code for the two java classes follows.
> > Pat
Geotools-gt2-users mailing list
Geotools-gt2-users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
Ciao Simone,
I am curious if the ImageIO.write method combined with the geophysics
companion of the grid coverage could be used for extracting a byte object
from the grid coverage that would preserve data that may go beyond the limits
of a simple rendered image pixel value? The biggest problem I had in getting
the image data into the database was figuring out how to produce a
ByteArrayOutputStream from a grid coverage. Maybe there is another method
for extracting your raster data?
Your project sounds very interesting, I would be very interested in reviewing
the schemas/code that you are developing as they are ready.
Ciao,
Pat
Ciao,
Simone.
> Hi Jody,
> I would be interested in working with the community to improve this
> method of managing rasters in the PostGIS database. My motivation for
> developing this process was to achieve maximum performance with regards
> to rendering rasters. If the grid size and resolution are chosen wisely
> then at any scale the sum of the raster images required should not exceed
> 10-15 megabytes. By preprocessing the images into smaller tiles the
> computer has less work to perform and the image can be drawn faster.
> Also the GridCoverages generate a bit faster than geotiffs partly because
> the transform and spatial reference data are preprocessed as well. The
> cost for this concept is a large amount of data stored which can be
> Cheers,
> Pat
> > anywhere?
> > the database, I know OracleSpatial already has some crazy construct for
> > it.
> > Cheers,
> > Jody
> > Patrick Way wrote:
> > > Hello,
> > > makes this possible was figuring out how to store geotiff files in a
> > > database. To do this I created an imagecatalog table:
> > > geom --> envelope
> > > text --> crs
> > > text --> transform
> > > double --> scale
> > > bytea --> image
> > > format that is similar to a world file format.
> > > I have tiled them into grids at various resolutions and stored the
> > > tiled images in the image catalog table
> > > the appropriate resolution value then select the images from the
> > > image catalog table that intersect the envelope and equal the
> > > resolution value.
> > > Pat
