[Geoserver-devel] GeoTools PR reviews and downstream builds
a common annoyance when reviewing a GeoTools PR is that, while it can be green on Travis,
it can still cause a downstream failure in GeoWebCache and GeoServer.
I don’t always checkout the PR, build it, and then run downstream builds locally when reviewing PRs… because well,
it takes quite a bit of time, and maintainer time is what we are short of.
Was wondering if this could be delegated to the build server, rough idea:
  • Add a entry in the build matrix that runs a custom shell script
  • The script build geotools without tests (the other builds cover that) in order to have fresh local GT jars in the maven repository
  • The script then check out GeoServer sources, and builds it with tests
  • Repeat the above steps for GWC as well
    However, I have no idea if a build matrix entry is even allowed to do the above.
    Has anyone experiences trying to do anything similar
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Another possibility would be to run the custom script on another build platform. Has anyone experience for example with circle-ci?
I see they provide 4 build containers to open source projects:
https://circleci.com/open-source/
Open to other free alternatives too, bring them in.
Is any part of the build chain Jenkins? I know Jenkins can call a build script from another branch of the same repository, but it may also work to call a build job from a different repository. I plan on investigating this process for our in-house builds for a project I moved to. Might be worth someone with access to the build servers to investigate cross-repository builds?
Chris Snider
Senior Software Engineer
pa-logo-email
(attachments)
Nope, we are talking about the PR validations performed by Travis and Appveyor, there is no Jenkins involved.
Not sure if it could make it involved, but also, even if technically feasible if we’d have the resources to make that happen.
One nice thing about Travis and Appveyor is that they provide the hardware for free (and circle-ci too, that’s why I was wondering about it).
(attachments)
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
When build.geoserver.org is back we should be able to configure it to check pull request branches and do a long build chain as you describe Andrea.
(attachments)
Jody Garnett
Hi Jody,
this worries me… the build server is showing long build queues with the current workload,
if we add more, we should also provision more build power imho?
(attachments)
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
While at the OSGeo code sprint, I spent some time working with CircleCI. The goal was to see if one build could chain multiple repos together. That is, could a CircleCI job build GeoTools, GeoWebCache, and GeoServer?
The good news is that CircleCI is flexible enough to chain builds. I put together a dummy example of that with JTS and Hatbox[1]. I was able to see a failure on a branch of JTS where I changed the name of class that Hatbox uses.
When I tried to setup a GeoTools build[2], I ran into problems where I was unable to get the project to build. I may have screwed up something with the job config or we need a bigger box from CircleCI (which would cost money).
Since I wasn’t finding good examples and was generally having trouble, I moved on to working with Jody on ImageN.
Anyone who is interested is more than welcome to my branches. Also, I’m happy to answer any questions. Wish I had better news…
Jim
  1. https://github.com/jnh5y/jts/blob/circleci/.circleci/config.yml
  2. https://github.com/jnh5y/geotools/blob/circleci/.circleci/config.yml
(attachments)
On 5/14/2019 2:49 AM, Andrea Aime wrote:
Hi Jody,
On Mon, May 13, 2019 at 10:54 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Mon, 13 May 2019 at 14:22, Chris Snider <chris.snider@anonymised.com> wrote:
Chris Snider
pa-logo-email
Sent: Monday, May 13, 2019 10:37 AM
To: Geotools-Devel list <geotools-devel@lists.sourceforge.net>; Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Subject: Re: [Geoserver-devel] GeoTools PR reviews and downstream builds
On Mon, May 13, 2019 at 5:29 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
GeoTools-Devel mailing list
GeoTools-Devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Not sure how practical it would be, but it would be nice to take it a
step further and detect related PRs on the downstream projects. For
instance if a GWC PR references a GS PR or vis versa, the downstream GS
build would use the downstream PR rather than master.
On 2019-05-16 12:15 p.m., Jim Hughes wrote:
and GeoServer?
Since I wasn't finding good examples and was generally having trouble,
I'm happy to answer any questions. Wish I had better news...
Jim
Hi Jody,
this worries me... the build server is showing long build queues with
<mailto:jody.garnett@anonymised.com>> wrote:
    When build.geoserver.org <http://build.geoserver.org> is back we
    Jody Garnett
        Chris Snider
        pa-logo-email
        <mailto:andrea.aime@anonymised.com>>
        *Sent:* Monday, May 13, 2019 10:37 AM
        *To:* Geotools-Devel list
        <mailto:geotools-devel@lists.sourceforge.net>>;
        <mailto:geoserver-devel@lists.sourceforge.net>>
        *Subject:* Re: [Geoserver-devel] GeoTools PR reviews and
        downstream builds
            server, rough idea:
              * Add a entry in the build matrix that runs a custom
                shell script
              * The script build geotools without tests (the other
              * The script then check out GeoServer sources, and
              * Repeat the above steps for GWC as well
        with circle-ci?
        ------------------------------------------------------- /Con
        by telephone or e-mail./
        <mailto:GeoTools-Devel@lists.sourceforge.net>
Kevin Michael Smith
<smithkm@anonymised.com>
(attachments)
