[Geoserver-devel] [Geowebcache-devel] Adding WMTS REST API
Sorry for the double post.
I made a pull request for this in GWC:
https://github.com/GeoWebCache/geowebcache/pull/530
and another in GS:
https://github.com/geoserver/geoserver/pull/2491
Any feedback will be welcome :slight_smile:
On 07/19/2017 04:59 PM, Nuno Oliveira wrote:
I'm planning the implementation of the REST API for WMTS service as defined in the OGC WMTS standard:
http://portal.opengeospatial.org/files/?artifact_id=35326
This work would be relatively self-contained and the implementation will stay on the WMTS module.
My intention is to use Spring REST annotations, similar to what has already be done for the SQLite operations:
https://github.com/geowebcache/geowebcache/blob/129e1a153651adf69e2afb354a17e6265864b1ed/geowebcache/sqlite/src/main/java/org/geowebcache/sqlite/OperationsRest.java
To allow the reuse of the existing WMTS business code some refactoring would need to be done, currently a
few portions of the code get the parameters directly from the HTTP request instead of getting the necessary
values directly. So the refactoring will be basically remove the direct use of the HTTP request object and allow
callers to pass only the necessary values. All the changes would be additive and backward compatible.
Any comments ?
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
  The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Just a friendly reminder that this PR is pending waiting for review:
I have merged all the Spring changes and security changes :slight_smile:
On 08/23/2017 12:08 PM, Nuno Oliveira wrote:
and another in GS:
Any comments ?
Nuno Oliveira
@nmcoliveira
Software Engineer
