[Geoserver-devel] [Geowebcache-devel] greetings
Putting on GS-dev, since really these are mostly gs questions.
On Thu, Sep 4, 2008 at 11:09 PM, Jody Garnett <jgarnett@anonymised.com> wrote:
Chris Holmes wrote:
I’m not sure if I’m yet convinced we should allow this to happen in the main capabilities document, like letting any plugin just dump in vendor specific stuff. I’d like to see a parameter to a caps request to add in the extended data. But could be convinced that we should support it in the main one. But since clients are going to have to know how to handle it anyways I don’t see a big loss in making them request it a certain way.
I do understand your hesitation Chris; it sounds like a scary facility to open up to community extensions right? The part I am wanting to be clear (as a client of geoserver) is to make sure that every additional thing we dump into the GetMap “vendor specific parameters” has some kind of indication that it is available in the vendor specific capabilities.
My hope is two fold:
  • someone setting up geoserver can turn “non standard” stuff on or off (by including a community extension at the very least)
  • as a client I will be able to tell up front by looking at the capabilities document what is supported
    (right now I check the URL and if I see “geoserver/wms” I know a bunch of stuff is supported - but since I do not know what version of geoserver is being executed it is really a guess - there is a “fall back” of strict compliance mode for when I guess poorly.)
That makes a lot of sense, indeed it’d be nice to be able to report on all our format options that we make available. But I think all I’m saying is I think I’d prefer a vanilla capabilities document at the request=GetCapabilities, and then if clients are more advanced and know they can do request=GetCapabilities&extensions=true or something, and get the full vendor params.
b) We need to intercept a GetMapRequest with “tiled=true” and
dispatch it to GeoWebCache rather than the normal GeoServer GetMap
handler…
This should be pretty easy, we already have the infrastructure to do this with our little in memory tile cache, which we use for openlayers tile return. So we just need to have that check GeoWebCache too (or instead). I asked Andrea about it, I’ll try to add a jira for it, should be able to do it for 1.7.1.
Agreed; it should not be too bad. I would prefer to have the geowebcache extensions register an interest; rather than adding conditional code to the existing GetMap functionality. I am not sure how feasible this is … is it something the dispatcher needs to consider? Or is it something that the GetMap implementation will check for (much like it checks for output formats right now…).
Andrea’s probably the man to ask, as I have no idear.
Chris
Jody
