it seems the GWC master build is stuck on the build server, starting it manually won’t help, it will never even start to push out console messages.
I’ve seen this already when the Jenkins work area is corrupted, the only cure I’ve found it to create a new build with a different name and clean up deeply the working area (as Jenkins was not able to)
I can create the new build, but can’t do the file system cleanup. How shall we proceed?
GeoServer training in Milan, 6th & 7th June 2013! Visit http://geoserver.geo-solutions.it for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Hello Andrea,
it should be fixed now.
Indeed had to create a separate job, manually remove the geowebcache-master hudson workspace, and restart hudson. But it looks like its back to life.
Thanks for the catch.
Gabriel
On Mon, Apr 8, 2013 at 10:14 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Minimize network downtime and maximize team effectiveness.
Reduce network management and security costs.Learn how to hire
the most talented Cisco Certified professionals. Visit the
Employer Resources Portal
http://www.cisco.com/web/learning/employer_resources/index.html
Geoserver-devel mailing list
Gabriel Roldan
OpenGeo - http://opengeo.org
On Mon, Apr 8, 2013 at 5:28 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hello Andrea,
its back to life.
And thanks a lot for fixing it
Ing. Andrea Aime
@geowolf
Technical Lead
