Kevin and Gabriel,
it looks like recent geowebcache-master ParameterFilter changes break geoserver-master in the gwc module:
https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/1232/
https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/org.geoserver$gwc/1232/testReport/
java.lang.UnsupportedOperationException
at java.util.AbstractList.add(AbstractList.java:131)
at java.util.AbstractList.add(AbstractList.java:91)
at java.util.AbstractCollection.addAll(AbstractCollection.java:305)
at org.geoserver.gwc.layer.TileLayerInfoUtil.updateStringParameterFilter(TileLayerInfoUtil.java:167)
I have kicked the build on OpenGeo Hudson to generate your official notification (our Jenkins polls more frequently).
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
OpenGeo Hudson looks hung (or very slow). I have confirmed the failure locally and created a Jira issue:
https://jira.codehaus.org/browse/GEOS-5743
On 02/04/13 09:43, Ben Caradoc-Davies wrote:
Kevin and Gabriel,
at
Kind regards,
Software Engineer
Sorry, I made a mistake while prepping that patch for commit. It should be fixed now on the GWC end.
On 1 April 2013 18:53, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Kevin and Gabriel,
at
Kind regards,
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Kevin Smith
Junior Software Developer, OpenGeo
<ksmith@anonymised.com>
Thanks very much, Kevin, for your prompt response. Confirmed fixed.
Kind regards,
Ben.
https://jira.codehaus.org/__browse/GEOS-5743
<https://jira.codehaus.org/browse/GEOS-5743>
Kevin and Gabriel,
break
https://cgsrv8.arrc.csiro.au/__jenkins/view/geoserver-master/__job/geoserver-master/1232/
<https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/1232/>
https://cgsrv8.arrc.csiro.au/__jenkins/view/geoserver-master/__job/geoserver-master/org.__geoserver$gwc/1232/testReport/
<https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/org.geoserver$gwc/1232/testReport/>
java.lang.__UnsupportedOperationException
at java.util.AbstractList.add(__AbstractList.java:131)
at java.util.AbstractList.add(__AbstractList.java:91)
at
java.util.AbstractCollection.__addAll(AbstractCollection.__java:305)
at
org.geoserver.gwc.layer.__TileLayerInfoUtil.__updateStringParameterFilter(__TileLayerInfoUtil.java:167)
Kind regards,
Software Engineer
Kevin Smith
<ksmith@anonymised.com <mailto:ksmith@anonymised.com>>
Software Engineer
