[Geoserver-devel] GeoWebCache release for GeoServer 2.7.3
I’m in the process of cutting the 2.7.3 release (due tomorrow), as usual
there is a need for a GeoWebCache release.
I though a release script was in the work, but I don’t see a corresponding
build on Ares, so I guess it’s not there yet.
So I guess we have to follow manually the release guide again right?
https://github.com/GeoWebCache/geowebcache/blob/master/geowebcache/release/RELEASE_GUIDE.txt
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Kevin made a script to help, but he still needed to run it. We can ask him if it is committed to the project GitHub?
On Sat, Oct 17, 2015 at 7:21 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Jody Garnett
On Sat, Oct 17, 2015 at 4:36 PM, Jody Garnett <jody.garnett@anonymised.com>
I did not see it here:
https://github.com/GeoWebCache/geowebcache/tree/master/geowebcache
I've verified that 13.3 builds on a empty repo (and removed a reference to
another maven repo that
went down), and just kicked its publishing (it is deploying as I write).
I'll check if there if we have anything for GWC tomorrow, if not, I'll make
a manual release.
The draft blog posts for the GeoTools and GeoServer release are already up
in the respective
blog platforms, in case anyone wants to improve them.
Ing. Andrea Aime
@geowolf
Technical Lead
so I’ve moved on with the GWC release, but I cannot deploy, no rights to publish on
the new repo (I had them on the old one).
In the meantime I’ll tag and upload to sourceforge… but no GWC deploy means on
GeoServer release
On Sat, Oct 17, 2015 at 5:27 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Oct 17, 2015 at 4:36 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I did not see it here: https://github.com/GeoWebCache/geowebcache/tree/master/geowebcache
I’ve verified that 13.3 builds on a empty repo (and removed a reference to another maven repo that
I’ll check if there if we have anything for GWC tomorrow, if not, I’ll make a manual release.
The draft blog posts for the GeoTools and GeoServer release are already up in the respective
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Oh, I did not check, but it seems that also the GeoTools 13.3 deploy failed:
http://ares.boundlessgeo.com/jenkins/view/geotools/job/geotools-release-publish/40/console
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geotools: Failed to deploy artifacts: Could not transfer artifact org.geotools:geotools:pom:13.3 from/to boundless ([https://boundless.artifactoryonline.com/boundless/release/](https://boundless.artifactoryonline.com/boundless/release/)): Access denied to: [https://boundless.artifactoryonline.com/boundless/release/org/geotools/geotools/13.3/geotools-13.3.pom](https://boundless.artifactoryonline.com/boundless/release/org/geotools/geotools/13.3/geotools-13.3.pom), ReasonPhrase:Forbidden. -> [Help 1]
So yeah… the build server also seems to be missing the right permissions…
Ing. Andrea Aime
@geowolf
Technical Lead
It is supposed to deploy to OSGeo though - for releases.
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, Oct 18, 2015 at 5:19 PM, Jody Garnett <jody.garnett@anonymised.com>
Jody, no clue... the release build is something I did not touch, for
geowebcache
I also just went for the build instructions, so no idea why this happened,
but it
seems to be related to the last repo storm...
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks Andrea, I am going through all the ares build jobs and pom.xml settings and double checking everything (and sending pull requests out to projects that did not make the switch):
  • GeoTools is supposed to deploy releases to OSGeo webdav
  • Collecting up all the problem reports now, starting to suspect the “new” GeoTools SNAPSHOTS (even though they are getting published) are causing problems downstream.
On 18 October 2015 at 12:28, Andrea Aime <andrea.aime@anonymised.com> wrote:
Jody Garnett
On Sun, Oct 18, 2015 at 5:19 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody, no clue… the release build is something I did not touch, for geowebcache
I also just went for the build instructions, so no idea why this happened, but it
seems to be related to the last repo storm…
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, Oct 18, 2015 at 11:34 PM, Jody Garnett <jody.garnett@anonymised.com>
- GeoTools is supposed to deploy releases to OSGeo webdav
I checked again the Jenkins logs, it contains a succesful deploy to OSGeo,
what I was not
aware of is that the release job also publishes to Boundless repo, and
fails there:
mvn clean -P deploy.boundless deploy -DskipTests -Dall
It's apparently something we have done for a long time:
https://github.com/geotools/geotools/blob/master/build/release/publish_release.sh#L56
The thing is, if the script does not complete, it does not upload to SF nor
it tags.
GeoWebCache is not even trying to publish to OSGeo instead... I'll need
deploy credentials
to complete that:
https://github.com/GeoWebCache/geowebcache/blob/master/geowebcache/pom.xml#L66
Ing. Andrea Aime
@geowolf
Technical Lead
I saw the profile deploy.boundless in the pom.xml (and updated it). I was not sure if it was being used or not.
I will check your credentials for manual deploy of geowebcache (I also had private credentials to deploy geotools dependencies previously).
Jody Garnett
On 18 October 2015 at 16:35, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sun, Oct 18, 2015 at 11:34 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I checked again the Jenkins logs, it contains a succesful deploy to OSGeo, what I was not
aware of is that the release job also publishes to Boundless repo, and fails there:
It’s apparently something we have done for a long time:
The thing is, if the script does not complete, it does not upload to SF nor it tags.
GeoWebCache is not even trying to publish to OSGeo instead… I’ll need deploy credentials
to complete that:
Ing. Andrea Aime
@geowolf
Technical Lead
