Besides the Unit tests, There are also some integration tests, including some focused on REST. They are in the gwc-web module in the RestIT class. They work against a full GWC instance in Jetty.
They are not run as part of the normal unit tests, but you can have Maven run them with ‘mvn verify’
On 8/3/17 14:17, Nuno Oliveira wrote:
Great news, thanks David !
Unfortunately next weeks I will not have any free time to help
The issue with GWC is that most of the tests (if not all) use mocks and don’t setup
a real Spring context. I had the same struggle when testing the operations REST
interface of the SQLite module[1].
The solution I come up with was to rely on Spring tests support, basically two
things are needed:
- a bunch of annotation in the test class that will define a spring context [2]
- a configuration class were you can define the necessary beans using mocks if needed [3]
The nice thing about this solutions is that the already existing mocks can be reused,
the no so nice thing is that you will have to hunt down the beans you need.
I hope it helps.
Nuno Oliveira
[1] https://github.com/GeoWebCache/geowebcache/blob/master/geowebcache/sqlite/src/test/java/org/geowebcache/sqlite/OperationsRestTest.java
[2] https://github.com/GeoWebCache/geowebcache/blob/master/geowebcache/sqlite/src/test/java/org/geowebcache/sqlite/OperationsRestTest.java#L56-L59
[3] https://github.com/GeoWebCache/geowebcache/blob/master/geowebcache/sqlite/src/test/java/org/geowebcache/sqlite/OperationsRestWebConfig.java
Kevin Michael Smith
[<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
On 08/03/2017 09:32 PM, David Vick wrote:
Hi All,
I participated in the Rest API upgrade for GeoServer in Italy and am trying to get GWC done before the code freeze. I have much of the Restlet ‘controllers’ converted over to Spring 4 MVC Rest but am struggling to get the test environment set up so I can get the unit tests written and ensure I have full test coverage before I issue a PR. Included is the link to the branch I am working off of, any help or comments is much appreciated.
https://github.com/vickdw/geowebcache/tree/rest-api-update
David Vick
Professional Services Engineer | Boundless
dvick@anonymised.com9…
mobile: +1-636-698-3174
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@anonymised.com.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
