Yes…It is a bit difficult for me, I will try to figure it out something. I will keep you in touch if I found something out.
Jody Garnett
On 30 January 2015 at 08:14, Andrea Aime <andrea.aime@anonymised.com> wrote:
By the way, forgot one thing… there is a function that can see the whole collection, it’s the rendering
transformation one.
So I guess if you wanted, you could use that one to do the computation, and bake directly into the
attributes the color you want, and then in the style you just pick the color.
See also: http://docs.geoserver.org/2.5.x/en/developer/programming-guide/wps-services/implement-rendertrans.html
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
Geoserver-devel mailing list
On Fri, Jan 30, 2015 at 4:15 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
On Thu, Jan 29, 2015 at 2:59 PM, Bonventi Matthieu <matthieu.bonventi@anonymised.com> wrote:
Any idea about how I can use them ? I mean it would be cool if I could get a max value and a min value from these function and use them as parameter for the function which calculate and return the color.
Not so easy though… the issue is that you cannot pass the whole feature collection to a filter function in a style,
they are always fed feature by feature.
Also, computing the min/max value would be rather expensive to do on a call by call basis, and would also
return different values every time, because the feature collection the renderer gets is relative only
to the current bbox.
Long story short, it’s better to pre-compute these values (against the whole dataset, and once
for all).
One idea that might work would be to have a GeoServer extension that computes the extrema
values on the full dataset periodically, or event based, and attach them to the layer info/resource info
metadata map, and then have another extension that feeds these values into the env function,
for the styles to pick up at runtime.
Just thinking out loud.
Ing. Andrea Aime
@geowolf
Technical Lead
