Hi Devs
I notice from https://docs.geoserver.org/latest/en/user/services/wms/reference.html#getcapabilities and https://docs.geoserver.org/latest/en/user/services/wms/vendor.html#getcapabilities-request that XML is the only response format option for the GetCapabilities call, and I wonder why that is, and if it is technically not possible to return the response in application/json format?
I am sure that the OGC spec states XML only, but can JSON be supported as a vendor option?
Is there just insufficient demand for the format?
If I wanted to implement this format, can you give me any pointers? Is GetCapabilitiesTransformer.java only for XML and would need an equivalent for JSON?
Thanks
Peter
Hi Peter,
yes, in general the OGC service allow alternative formats for outputs, although normally they are found for
data requests such as GetFeature/GetCoverage/GetMap. The capabilities document must be supported in the mandated
XML variant, and a standard client will look for that format: there is less incentive to support other formats.
That said, it’s possible. Two considerations:
- You’ll have to hand write a JSON encoding for each protocol and version (cap documents can be very long, they are typically hand-crafted to avoid loading everything in memory)
- OGC APIs (available as GeoServer community modules) are instead JSON native first, although still in flux specification wise
- If you really want to go that way, I’d look around and see if any other project attempted that way, to avoid having multiple incompatible JSON variants out there.
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
