[Geoserver-devel] GetFeatureInfo bug?
using geoserver trunk, basic.zip configuration, and the following request:
http://localhost:8080/geoserver/wms?service=WMS&request=GetFeatureInfo&bbox=-130,24,-66,50&format=image/jpeg&layers=states&styles=&width=550&height=250&query_layers=states&x=170&y=160&info_format=text/plain
I get the following error:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?><!DOCTYPE ServiceExceptionReport SYSTEM "http://localhost:8080/geoserver/schemas//wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt; <ServiceExceptionReport version="1.1.1"> <ServiceException>Argument &quot;sourceCRS&quot; should not be null.</ServiceException> </ServiceExceptionReport>
Hmm.... sourceCRS is definitely not a WMS 1.1.1 parameter... did I spot a bug, or I'm missing something obvious?
Brent just did a fix to try to get reprojection working right, so maybe some small thing is off with the fix.
But you should be including an EPSG code, as it's a normal part of the WMS request, and GetFeatureInfo relies on having a full WMS request embedded in it. So try with an epsg code. But regardless we should be returning a better error.
Chris
aaime@anonymised.com wrote:
opinions on IT & business topics through brief surveys -- and earn cash
Geoserver-devel mailing list
!DSPAM:1003,452112a4258642223018498!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Hum, the WMS response code includes SRS among the non mandatory parameters, and works
fine without it specified, so by extension getFeatureInfo should work fine without it too, no?
I already committed a fix on trunk and... arg! I just re-read the WMS spec and in fact SRS is required.
So what, do I revert the change and make getMap require SRS parameter as well?
Yeh SRS looks like it is required.
Did you fix it so it is optional? I've seen comments floating around in code saying that "SRS is mandatory but we are making it optional here". Can't find that code right now but I have seen it before.
I personally think that if they don't specify an SRS, the default is returned. Just to make things easier for the user.
Brent Owens
(The Open Planning Project)
The geoserver getMap behaviour was already to be lenient, and worked even without the SRS parameter.
The getFeatureInfo was not because it assumed SRS was always there, I just added a check to avoid
the x,y parameters coordinate reprojection in case the SRS is not specified, to make getFeatureInfo consistent with
getMap.
getMap.
That sounds like the best solution. I think it's fine for us to stay lenient. Just as long as we're consistent.
Chris
!DSPAM:1003,4521308e289734750375898!
Chris Holmes
getMap.
For consistency sake then, issue http://jira.codehaus.org/browse/GEOS-710 should be
resolved by not checking the VERSION parameter at all, since the other requests does not seem
to do anything but setting whatever version was required, working fine even if I do require version 0.1
or version "gizmo"...
Not sure the Geoserver behaviour is correct here thought, we should throw a service exception if
we are asked for an unsupported version... WMS wise, we do support 1.1.1, by extension 1.1.0,
I suppose 1.0.0 too?
