Hi to everybody,
after a discussion with Christian Mueller, the developer of the
image-mosaic-jdbc geotools extension, I realized that the GetFeatureInfo has
an strange behaviour when reading tif data stored on a postgis raster table.
I checked the examples of geoserver using files instead of db and I observed
the following output on GetFeatureInfo (in the Layer Preview of Geoserver)
My setup:
I have raster files in asc format, which I import in postgis using the
utility raster2pg.
After that I create the three files required for the image-mosaic-jdbc and
import the layer in Geoserver.
The creation of the image works perfectly, but when doing a GetFeatureInfo I
obtain:
I expected to obtain the same value like in the nurc:Arc_Sample example in
the demo.
Is there a way in doing this, or is a modification in the code required
thanks for your suggestions
View this message in context: http://osgeo-org.1560.n6.nabble.com/GetFeatureInfo-on-tif-data-tp4996558.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
