[Geoserver-devel] GetLegendGraphic needs some advice
trying to implement GetLegendGraphic I get wondering if there not
already exists a legend generator (say, something that recieves a
Style/Rule and produces a pretty graphic) in gt2 code base, instead of
being forced to do so many tricks to actualle get a renderer producing a
simple graphic.
could anyone givme some pointer?
My first try was to port LegendImageGenerator from the old wms server in
gt, but it relies in the fact that Java2DRenderer.processSymbolizers()
is public, wich is not the current situation.
Thanks in advance,
Gabriel
I think you can just make that method public, if that's the only thing
stopping you. I think that the LegendImageGenerator was the only gt
implementation of a legend generator, though I could be wrong.
Chris
On Mon, 27 Dec 2004, Gabriel Roldán wrote:
simple graphic.
Thanks in advance,
Gabriel
SF email is sponsored by - The IT Product Guide
Read honest & candid reviews on hundreds of IT Products from real users.
Discover which products truly live up to the hype. Start reading now.
http://productguide.itmanagersjournal.com/
Geoserver-devel mailing list
That was the best fix I could come up with at the time, since I didn't really want to build a whole map each time. I've not been following renderer design recently so there may now be a better way to do this. I'll try and have a poke round (possibly on the way to New York next week).
Ian
Dear friends:
If I try to add a new Oracle Spatial entity to Geoserver i get:
Could not create multilinestring with interpretacion 1- we can only represent 1 for straight edges.
The table i want to register has geometries with these values:
SDO_GTYPE : 2006 – bidimensional multiline
SDO_ELEM_INFO (1,2,1,7,2,1) – two line segments (SDO_ETYPE = 2), with straight lines between vertex (SDO_INTERPRETATION = 1).
What is wrong?
Thank you in advance
Jesús de Diego
JESUS MANUEL DE DIEGO ALARCON
Dpto. Informática
WASSER S.A.E
C/ Iglesia, 4
28223 Pozuelo de Alarcón (Madrid)
TF: 913524721 - Fax: 913522382
jdiego@anonymised.com
CONFIDENCIALIDAD: La información contenida en este mensaje y/o archivo(s) adjunto(s) es confidencial/privilegiada y está destinada a ser leída sólo por la(s) persona(s) a la(s) que va dirigida. Si usted lee este mensaje y no es el destinatario señalado, o el responsable de entregar el mensaje al destinatario, o ha recibido esta comunicación por error, le informamos que está totalmente prohibida cualquier divulgación, distribución o reproducción del mismo. En ese caso le rogamos que nos lo notifique inmediatamente, devolviéndonos el mensaje original a la dirección arriba Comencionada, y lo destruya posteriormente.
Virus: Hemos tomado todas las medidas necesarias para que este correo electrónico y sus ficheros adjuntos estén libres de virus. Si recibe un mensaje con este remitente y no contiene esta firma ni su mensaje de confidencialidad entonces no ha sido enviado por el servidor de correo de Wasser, por lo que le rogamos que lo destruya inmediatamente. Además recomendamos que, a efectos de mantener buenas prácticas de seguridad, el receptor del mensaje se asegure igualmente de que este correo y sus ficheros adjuntos están libres de virus.
