[Geoserver-devel] GetLegendGraphic
looks hand-made (<img src="/ms_tmp/1121108403_16_0_15_15.png"...) on
all
graphics, layer and range names are html text too, etc.
Here's one that looks at little less hard coded (I dont know if it is):
http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?Service=WMS&VERSION=1.1.0&REQUEST=GetCapabilities
Its a really really really difficult problem!!
really?
To do a good job of auto-generating could be difficult since not
everyone will have the same "taste" for the result. But, you're right,
it wouldnt be that difficult to make it better by adding in
meta-information about the little icons (from the title/abstract) and a
bit about the text labeling. What do you do for multiple symbolizers
in a rule?
People who want it to look better could use the auto-generated one as a
basis for making a custom-made one in "photoshop".
dave
This mail sent through IMP: https://webmail.limegroup.com/
all
>really?
Ok, we lack enough flexibility on the sld spec as to pass font attributes to
use on the legend graphic.
I imagine adding this functionality and then provide some configuration
options on the ui, as to switch between with/withour style names, and
configure the font to use.
But, you're right,
in a rule?
multiple symbolizers in a rule apply as a whole (like in the road with center
line example), so they share a single slot on the legend stack (correct me if
I'm wrong)
in all cases, the easy (and most appropriate way, imho), is to use the rule
name as the legend text. It is simple and consistent. If you have a rule for
population lower than 1000, call it " < 1000" on the SLD and you'll get
exactly that on the legend.
does it makes sense for you?
dave
This SF.Net email is sponsored by the 'Do More With Dual!' webinar
happening July 14 at 8am PDT/11am EDT. We invite you to explore the latest
in dual core and dual graphics technology at this free one hour event
hosted by HP, AMD, and NVIDIA. To register visit
http://www.hp.com/go/dualwebinar
Geoserver-devel mailing list
Gabriel Roldán <groldan@anonymised.com>
Axios Engineering <http://www.axios.es>
CR/Basurtu-Kastrexana 70, Mod. 14
48002 - Bilbao, Spain
te. (+34) 94 441 63 84
fax (+34) 94 441 64 90
