[Geoserver-devel] Getting a 406 when hitting the root rest endpoint
when I try to hit geoserver/rest on a master build I get the following:
HTTP/1.1 406 Not Acceptable
X-Frame-Options: SAMEORIGIN
Content-Length: 0
Access-Control-Allow-Origin: *
Access-Control-Allow-Headers: Origin, X-Requested-With, Content-Type, Accept
Connection: close
Content-Type: text/plain; charset=UTF-8
I guess this is somehow related to the GWC API switch?
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
just did a test and I’m having the same issue, this seems to be affecting all REST entry points.
On 09/11/2017 04:05 PM, Andrea Aime wrote:
Date: Mon, 11 Sep 2017 15:04:13 GMT
Content-Length: 0
Connection: close
Andrea Aime
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Yes. It is related to the GWC API switch. I have been looking into it, but to be honest not having much luck so far.
In brief the issue seems to be that the GWC Spring MVC context is interfering with the base GeoServer Spring context. This manifests in a few ways, but I suspect the issue you’re seeing is because none of the correct Message Converters exist within the Spring MVC context that gets used. You can see this in the current YSLD test failures (the ones that Jody set to ignore). These fail ultimately because the StyleInfo message converters aren’t available.
I’ve tried a few things to fix this, with no luck so far. Namely I’ve tried separating out the standalone GWC Spring MVC config into its own optional module, and excluding this module from the GeoServer build. This fixes the GS REST endpoints, but then the GWC endpoints are no longer available. When I debug under this scenario I can see that the GWC endpoints are there, but they’re mapped under the base /rest context, rather than the /gwc context. I’ve tried a few other permutations of Spring configurations without much luck. Try as I might I can’t get the two REST contexts to coexist correctly.
I’m going to keep working on it, but I’m also open to any suggestions. I have no idea what sorts of customizations in GeoServer might be interfering at this point. Theoretically I think two separate Spring REST contexts are able to exist in the same application, but so far it hasn’t worked out for me.
Devon
On Mon, Sep 11, 2017 at 9:24 AM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Content-Length: 0
Connection: close
Andrea Aime
[Geoserver-devel@anonymised.com366...sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Nuno Oliveira
@nmcoliveira
Software Engineer
Geoserver-devel@anonymised.com.366…sourceforge.net
I have just tried the master branch and the issue is gone, thanks Devon.
Devon
On Mon, Sep 11, 2017 at 9:24 AM, Nuno Oliveira <nuno.oliveira@…1268…> wrote:
Content-Length: 0
Connection: close
Andrea Aime
[Geoserver-devel@...366...sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Nuno Oliveira
@nmcoliveira
Software Engineer
Geoserver-devel@…366…sourceforge.net
Nuno Oliveira
@nmcoliveira
Software Engineer
