our service exception handling work in such a way that build the output message
from the list of messages in the stack trace below the first ServiceException found.
p
Sometimes this is not desirable, as it often makes the message long and ugly,
when the code throwing the exception has all the information it needs to properly
setup a full OGC service exception response (message, code and locator).
One such case is processes built with WPS in mind, which could do their own
internal (complex) validation of inputs, or just report about hiccups occurred during
the processing, without the need for the messages to be variously glazed by exception
wrapping.
Given that we already have a deep tree of exceptions, with some subtrees handling
OWS 2.0 specific things, creating a custom exception class (like HTTPErrorCodeException)
would not work.
Instead I would like to introduce a special interface, DirectOGCException, that could be then
implemented by multiple ServiceException subclasses
The Dispatcher code handling exception would first try to do a full drill down in the current
stack trace, if one of those is found, then the exception writing code would receive it
directly, with no extra glaze around it.
Feedback?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
