[Geoserver-devel] Getting access to a GeoServer after forgetting master/admin password
let’s say that someone does not use a GeoServer 2.2.x for quite some time,
the passwords are not stored anywhere, and the master/admin passwords
are just forgotten.
There must be a way for someone that has command line access to the GeoServer data
dir to start over and force GeoServer to use a certain new password.
Is there?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Two possibilities
  1. Check for a file security/masterpw.info
    This file contains the master password and you can log in with the user root. root has ROLE_ADMINISTRATOR.
  2. If you are using the default user group service, you can do the following:
Open security/usergroup/default/users.xml. Look for the admin user and set the password attribute like
password=“plain:geoserver”.
Obtaining the master password is difficult. It is located in security/masterpw/default/passwd. The password is stored encrypted and useless. You have to start a debug session to find this password in memory. Please tell me if you need further assistance.
Christian
2013/1/14 Andrea Aime <andrea.aime@anonymised.com>
are just forgotten.
Is there?
Ing. Andrea Aime
@geowolf
Technical Lead
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. SALE $99.99 this month only – learn more at:
http://p.sf.net/sfu/learnmore_122412
Geoserver-devel mailing list
Hi Andrea, did this help ?
2013/1/14 Christian Mueller <mcrmcr21@anonymised.com>
Two possibilities
Christian
are just forgotten.
Is there?
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jan 16, 2013 at 1:36 PM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
Ah hey, yep, it’s a good set of indications.
Having a command line tool to extract the master password without having to
put GeoServer in debug mode would be quite useful
Ing. Andrea Aime
@geowolf
Technical Lead
Perhaps a class with a main method in the main module. (if it is possible)
2013/1/16 Andrea Aime <andrea.aime@…1268…>
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jan 16, 2013 at 5:10 PM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
Yep, that would be nice
2013/1/16 Andrea Aime <andrea.aime@anonymised.com>
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
Perhaps a command line tool to reset the master password, rather than extract it?
Because users often use the same password in multiple places, extraction of a password might grant unintended access elsewhere. I am thinking of the use-case of a GeoServer instance whose administrator changes.
Many systems only store HMAC hashes of passwords for security; by design they cannot extract the original plaintext.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
My ideas so far:
  1. lost password for the admin user
    You need access to the physical storage of the user/group service (xml file, sql table,…). Change the password value of the admin user to “plain:geoserver”. (geoserver is the password). Log in as the admin user, change your password from geoserver to another value and press save. The new password is stored encoded replacing “plain:geoserver”.
  2. lost master password
    The master password is not a digest since it is needed for encryption/decryption of the key store. Yo have to login as an admin user. On the GUI you have to specify a file name and click on a button to store the plain master password in this file.
    The file name acts as a shared key between geoserver and the admin. (This is important, a fixed file location is vulnerable to an attack). The admin needs access to the file system, reads the master password and deletes the file.
The method writing the file checks the calling mehtod with
StackTraceElement[] stackTraceElements = Thread.currentThread().getStackTrace()
This is necessary to protect against "trojan horse" geoserver extensions.
Opinions ?
2013/1/21 Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Kind regards,
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
On Mon, Jan 21, 2013 at 8:55 AM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
My ideas so far:
Opinions ?
Both suggestions seem good to me
Ing. Andrea Aime
@geowolf
Technical Lead
Should I create a GSIP or is a JIRA improvement issue sufficient ?
If i understand our time boxed model correctly, this improvement will be applied to GeoServer 2.4 with the possibility to backport it after a vote.
Christian
2013/1/21 Andrea Aime <andrea.aime@anonymised.com>
My ideas so far:
Opinions ?
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Jan 21, 2013 at 9:52 AM, Christian Mueller <mcrmcr21@anonymised.com> wrote:
Jira should be sufficient, it’s not a large change or significant new API right?
Yep, the backport of a new functionality requires a vote
Ing. Andrea Aime
@geowolf
Technical Lead
