Hi, I would appreciate someone could help me on this
issue. I have been trying to trace what is the problem
for the past few weeks.
I am trying out getting geoclient to work with
geoserverlite. Using apache server ver. 1.3.31 and php
version 4.3.6
Inserted mySQL database using the Java converter
(found @http://www.mycgiserver.com),through a dump
file. All my files (*.php,*.svg,*.js) are in one
directory "geoclient" under one single directory
(...\htdocs\geoclient\). I have tried different
shapefiles but still encounter the same error. Please
help.
I have attached the whole source code of
capabilities.php,simple_wfs.php,and client.svg.
Please enlighten me. Thank you. Sally
Followed instructions to edit the GetFeature
capability to point to GeoServerLite.
Capbilities.php
<GetFeature>
<ResultFormat>
<GML2/>
<Post
onlineResource="http://127.0.0.1/geoclient/simple_wfs.php"/>
simple_wfs.php
Replaced the original HTTP_RAW_POST_DATA source code
line with php://input
because I have the error which indicates
HTTP_RAW_POST_DATA undefined index,
though I had set the always_populate_raw_post_data and
register_globals to On
in the php.ini file.
//$data = $GLOBALS["HTTP_RAW_POST_DATA"]; //orig
$data=file_get_contents("php://input"); //debug //24
May 2004
Despite these modifications, I have the following
error
Microsoft JScript runtime error
'bboxinit' is undefined, line:541, column:4
After clicked the ok button of the error box,
I could only see the list of menu bar above, but there
is no map and
legend is empty.
Source Codes...
capabilities.php - Source Code
print '<?xml version="1.0" encoding="UTF-8"?>';
<WFS_Capabilities version="0.0.14">
<Service>
<Name>SimpleWebFeatureServer</Name>
<Title>Simple Feature Server</Title>
<Abstract>Open source simple web feature server
- GeoServerLite</Abstract>
<OnlineResource>http://127.0.0.1/geoclient/simple_wfs.php</OnlineResource>
</Service>
<Capability>
<Request>
<GetCapabilities>
<DCPType>
<HTTP>
<Post
onlineResource="<?=$thePath?>"/>
</HTTP>
</DCPType>
</GetCapabilities>
<DescribeFeatureType>
<SchemaDescriptionLanguage>
<XMLSCHEMA/>
</SchemaDescriptionLanguage>
<DCPType>
<HTTP>
<Post
</HTTP>
</DCPType>
</DescribeFeatureType>
<GetFeature>
<ResultFormat>
<GML2/>
</ResultFormat>
<DCPType>
<HTTP>
<Post
</HTTP>
</DCPType>
</GetFeature>
<Transaction>
<DCPType>
<HTTP>
<Post
</HTTP>
</DCPType>
</Transaction>
</Request>
<VendorSpecificCapabilities>
<GetExtendedProjectDescriptor>
<DCPType>
<HTTP>
<Post
</HTTP>
</DCPType>
</GetExtendedProjectDescriptor>
<GetStyledLayerDescriptor>
<DCPType>
<HTTP>
<Post
</HTTP>
</DCPType>
</GetStyledLayerDescriptor>
<GetExtendedLayerDescriptor>
<DCPType>
<HTTP>
<Post
</HTTP>
</DCPType>
</GetExtendedLayerDescriptor>
</VendorSpecificCapabilities>
</Capability>
//debug//added in to solve writeTag undefined
issue
include('convertgeom.php');
include('connect.php');
//?=$thePath? for the above...
//debug
$depth=1;
writeTag("open",null,"FeatureTypeList",null,True,True);
$depth++;
//$sql="SELECT TableName FROM Layers ORDER BY
LayerID DESC";//orig
LayerID DESC";
//print($sql);//debug //21 May 2004
$result = mysql_query($sql,$db);
while ($myrow = mysql_fetch_array ($result)) {
$TableName=$myrow["TableName"];
writeTag("open",null,"FeatureType",null,True,True);
$depth++;
writeTag("open",null,"Name",null,True,False);
//echo $TableName;
writeTag("close",null,"Name",null,False,True);
$depth--;
writeTag("close",null,"FeatureType",null,True,True);
$depth--;
writeTag("close",null,"FeatureTypeList",null,True,True);
</WFS_Capabilities>
simple_wfs.php - Source Code
//added NR
ob_start("ob_gzhandler");
May 2004
//print_r($GLOBALS);//debug //20 May 2004
$thePath= "http://".$SERVER_NAME.$PHP_SELF;
//echo $thePath; //debug
$server="http://".$SERVER_NAME;
//echo $server; //debug
$BBox=null;
//added NR
$disjoints=array();
$NotDisjoints=array();
$disjointCoords=array();
$notDisjointCoords=array();
//end added
$currentTable=null;
$currentTag=null;
$gen=array();
$gen[0]="";
$level=0;
$depth=0;
$tables=array();
$fields=array();
$wheres=array();
$limits=array();
function startElement($parser, $name, $attrs) {
global $BBox;
global $currentTag;
global $currentTable;
global $gen;
global $level;
global $depth;
global $tables;
global $fields;
global $limits;
$level++;
$currentTag = $name;
$gen[$level]=$currentTag;
if($level>0){
if
(($gen[($level)-1]=="Insert")||($gen[($level)-1]=="Update")){
$tables=$currentTag;
switch($currentTag){
case "GetExtendedProjectDescriptor":
getExtendedProjectDescriptor();
break;
case "GetStyledLayerDescriptor":
getStyledLayerDescriptor();
break;
case "GetExtendedLayerDescriptor":
getExtendedLayerDescriptor();
break;
case "GetCapabilities":
getCapabilities();
break;
case "GetFeature":
if (sizeof($attrs)) {
while (list($k, $v) = each($attrs)) {
if ($k=="maxFeatures"){
$limits[$currentTable]=$v;
writeTag("open","gml","featureCollection",null,True,True);
$depth++;
break;
case "Query":
if ($k=="typeName"){
$currentTable=$v;
$tables=$currentTable;
$fields[$currentTable]=array();
break;
function endElement($parser, $name) {
global $currentTag;
global $fields;
global $fieldCount;
global $level;
global $depth;
$currentTag=$name;
case "GetFeature":
doQuery("Select");
$depth--;
writeTag("close","gml","featureCollection",null,True,False);
break;
//added NR
case "DescribeFeatureType":
getXSD();
break;
//end added NR
case "Query":
break;
case "Insert":
doQuery("Insert");
$fields=null;
break;
case "Update":
doQuery("Update");
$fields=null;
break;
case "Delete":
doQuery("Delete");
$fields=null;
break;
$level--;
$currentTag = null;
// process data between tags
function characterData($parser, $data) {
global $currentTag;
//added NR
global $tables;
//end added NR
global $fields;
global $gen;
global $level;
global $depth;
global $BBox;
//added NR
global $disjointCoords;
global $notDisjointCoords;
//end added
// echo "currenttag: '".$currentTag."' gen-2:
'".$gen[$level-2]."' gen-3: '".$gen[$level-3]."' data:
".$data. " ";
$pos=strpos($currentTag, "coordi");
if(!(empty($pos))){
switch($gen[$level-2]){
case "BBOX":
$BBox=$data;
break;
case "Disjoint":
// echo "disjoint: ".$data;
if($gen[$level-3]=="Not"){
// echo "not";
$notDisjointCoords=$data;
else{
$disjointCoords=$data;
break;
default:
break;
switch ($currentTag) {
//added NR
case "PropertyName":
switch($gen[$level-1]){
case "Disjoint":
if($gen[$level-2]=="Not"){
disjoint($data,true);
else{
disjoint($data,false);
break;
default:
break;
break;
//end added NR
case "TypeName":
if($gen[$level-1]=="DescribeFeatureType"){
$tables=$data;
break;
$fields[$currentTable]=$data;
break;
default:
break;
function getCapabilities(){
global $thePath;
global $db;
include('capabilities.php');
//end added NR
function intersects($Box){
$Box=str_replace (","," ", $Box);
$coords = explode(" ", $Box);
$XMin=$coords[0];
$YMin=$coords[1];
$XMax=$coords[2];
$YMax=$coords[3];
return "((XMin BETWEEN $XMin AND $XMax ) AND
(YMin BETWEEN $YMin AND $YMax )) OR ((XMin BETWEEN
$XMin AND $XMax ) AND (YMax BETWEEN $YMin AND
$YMax )) OR ((XMax BETWEEN $XMin AND $XMax ) AND
(YMin BETWEEN $YMin AND $YMax )) OR ((XMax BETWEEN
$YMax )) OR ((XMin < $XMin ) AND (YMin < $YMin )
AND (XMax > $XMax ) AND (YMax > $YMax )) OR ((XMin
BETWEEN $XMin AND $XMax ) AND (YMin < $YMin ) AND
(YMax > $YMax )) OR ((XMax BETWEEN $XMin AND $XMax
) AND (YMin < $YMin ) AND (YMax > $YMax )) OR ((YMin
BETWEEN $YMin AND $YMax ) AND (XMin < $XMin ) AND
(XMax > $XMax )) OR ((YMax BETWEEN $YMin AND $YMax
) AND (XMin < $XMin ) AND (XMax > $XMax ))";
function getExtendedProjectDescriptor(){
global $thePath;
global $depth;
global $db;
include('EPD.php');
function getStyledLayerDescriptor(){
global $thePath;
global $depth;
global $db;
include('SLD.php');
function getExtendedLayerDescriptor(){
global $thePath;
global $depth;
global $db;
include('ELD.php');
//added NR
function getXSD(){
global $server;
global $depth;
global $db;
global $tables;
include('XSD.php');
//end added NR
function doQuery($queryType){
global $currentTag;
global $BBox;
global $tables;
global $fields;
global $values;
global $wheres;
global $limits;
//added NR
global $disjoints;
global $notDisjoints;
//end added
switch ($queryType) {
case "Select":
foreach($tables as $table){
$sql="SELECT ";
if (!(empty($fields[$table]))){
foreach ($fields as $field){
$sql = $sql. $field.",";
else {
$sql .= " * ";
$sql2 = "SELECT Min(XMin) AS TXMin,Max(XMax)
AS TXMax, Min(YMin) AS TYMin,Max(YMax) AS TYMax ";
$from = " FROM ".$table;
if
((!(empty($BBox)))||(sizeof($wheres))||(sizeof($disjointCoords))||(sizeof($notDisjointCoords))){
$from .= " WHERE ";
if (!(empty($BBox))){
$from .= intersects($BBox)." AND ";
if (sizeof($notDisjoints)){
for($i=0;$i<sizeof($notDisjoints);$i++){
foreach($notDisjoints[$i] as
$notDisjoint){
if($notDisjoint==$table){
$from .= "
(".intersects($notDisjointCoords[$i]).") AND ";
break;
if (sizeof($disjoints)){
for($i=0;$i<sizeof($disjoints);$i++){
foreach($disjoints[$i] as $disjoint){
if($disjoint==$table){
$from .= "
(NOT(".intersects($disjointCoords[$i]).")) AND ";
break;
if (sizeof($wheres)) {
while (list($k, $v) = each($wheres)) {
//note: incomplete: needs test for data
type of field
$from .= " (" . $k . "=" . $v . ") AND ";
if
$from=dropLastChrs($from,4);
if (!(empty($limits[$table]))){
$from .= " LIMIT " . $limits[$table];
doSelect($table,$sql,$sql2,$from);
break;
case "Insert":
$sql="INSERT INTO " . $table;
echo $sql;
break;
default:
break;
//added NR
function disjoint($data,$Not){
global $disjoints;
$posOr = strpos($data, "|");
if($Not==true){
$num=count($notDisjoints);
$notDisjoints[$num]=array();
if(!(empty($posOr))){
$tables = explode("|", $data);
$posSlash = strpos($table, "/");
$table = substr($table, 0, $posSlash);
$notDisjoints[$num]=$table;
else{
$posSlash = strpos($data, "/");
$table = substr($data, 0, $posSlash);
else{
$num=count($disjoints);
$disjoints[$num]=array();
$disjoints[$num]=$table;
else{
function genBBox($XMin,$YMin,$XMax,$YMax){
global $depth;
global $tables;
global $db;
writeTag("open","gml","boundedBy",null,True,True);
$depth++;
writeTag("open","gml","Box",null,True,True);
$depth++;
writeTag("open","gml","coordinates",null,True,False);
print $XMin.",".$YMin." ".$XMax.",".$YMax;
writeTag("close","gml","coordinates",null,False,True);
$depth--;
writeTag("close","gml","Box",null,True,True);
$depth--;
writeTag("close","gml","boundedBy",null,True,True);
function doSelect($table,$sql,$sql2,$from){
global $db;
global $depth;
$sql.=$from;
$sql2.=$from;
// echo $sql;
// echo $sql2;
$result = mysql_query($sql2,$db);
while ($myrow = mysql_fetch_array($result)){
if(!(empty($myrow["TXMin"]))){
//added NR
genBBox($myrow["TXMin"],$myrow["TYMin"],$myrow["TXMax"],$myrow["TYMax"]);
else{
return;
writeTag("open","gml","featureMember",null,True,True);
$depth++;
writeTag("open",null,$table,null,True,True);
$depth++;
for ($i=0;($i < mysql_num_fields ($result))
;$i++) {
$FieldName=mysql_field_name($result, $i);
$FieldValue=$myrow[$FieldName];
if (!(empty($FieldValue))){
if
(($FieldName!="Geometry")&&($FieldName!="TXMin")&&($FieldName!="TYMin")&&($FieldName!="TXMax")&&($FieldName!="TYMax")){
writeTag("open",null,$table.".".$FieldName,null,True,False);
echo $FieldValue;
writeTag("close",null,$table.".".$FieldName,null,False,True);
else{
writeTag("open",null,$table.".".$FieldName,null,True,True);
$depth++;
convertGeom($FieldValue);
$depth--;
writeTag("close",null,$table.".".$FieldName,null,True,True);
$depth--;
writeTag("close",null,$table,null,True,True);
$depth--;
writeTag("close","gml","featureMember",null,True,True);
function dropLastChrs($str,$no) {
$strLen=strlen($str);
return (substr($str,0,($strLen)-$no));
// initialize parser
$xml_parser = xml_parser_create();
// set callback functions
xml_set_element_handler($xml_parser, "startElement",
"endElement");
xml_set_character_data_handler($xml_parser,
"characterData");
xml_parser_set_option($xml_parser,
XML_OPTION_CASE_FOLDING, 0);
if(!xml_parse($xml_parser, $data))
echo "XML error:
".xml_error_string(xml_get_error_code($parser))." at
line ". xml_get_current_line_number($parser);
// clean up
xml_parser_free($xml_parser);
geoclient.svg - Source Code
<?xml version="1.0" standalone="no"?>
<!DOCTYPE svg PUBLIC "-//W3C//DTD SVG 20010904//EN"
"http://www.w3.org/TR/2001/REC-SVG-20010904/DTD/svg10.dtd">
<?AdobeSVGViewer save="snapshot"?>
This is an open source project (see definition at
http://www.opensource.org/docs/definition_plain.html).
and is distributed under the GNU General Public
License (see http://www.gnu.org/copyleft/gpl.html).
GeoClient is part of the GeoServer project, see
http://geoserver.sourceforge.net
<svg id="thesvg"
onload="init(evt);arrangeSVG(evt,0.8);initzp(evt)"
xmlns="http://www.w3.org/2000/svg"
xmlns:gml="http://www.opengis.org/gml"
xmlns:xlink="http://www.w3.org/1999/xlink">
<script xlink:href="geoclient.js"/>
<script xlink:href="legend.js"/>
<script><![CDATA[
var showCalls=null;
//uncomment these next two lines to avoid the two
initial prompts when application loads
//wfsPath="simple_wfs.php"; //orig
//showCalls=false;
if(showCalls==null){
showCalls=confirm("Display requests and
responses?");
var svgdoc;
var theLayers= new Array();
var wfsPath;
//added NR
var pathadder=null;
var pathadder2;
var zoomer;
var panner;
var startNew=false;
var origX;
var origY;
var newX;
var newY;
var startX;
var startY;
var oldX;
var oldY;
//added NR
//global variable for bounding box, if set through url
var bbox=null;
var currentMapScale;
var maxScales=new Array();
var minScales=new Array();
//read any url-encoded variables
function readVars(){
//commented out because not working in NS 4
str=unescape(location.search.substring(1));
if (str){
ampIndex=str.indexOf("&");
if(ampIndex!=-1){
var strPairs=str.split("&");
else{
var strPairs=new Array();
strPairs[0]=str;
for(i=0;i<strPairs.length;i++){
strVars = strPairs[i].split("=");
switch(strVars[0]){
case "bbox":
bbox=strVars[1];
ext=getExtent(bbox);
createExtent(ext);
break;
case "wfsPath":
wfsPath=strVars[1];
break;
//end added NR
function init(evt){
//added NR
readVars();
//end added NR
svgdoc = evt.getTarget().getOwnerDocument();
getCapabilities();
statusText("request","capabilities");
theCall=svgdoc.createElement("GetCapabilities");
nodeText=printNode(theCall);
if(showCalls==true){
alert(nodeText);
//added NR
if(wfsPath==null){
//end added NR
wfsPath=prompt("Enter path to web feature
server","simple_wfs.php");
//added NR
//end added NR
result=postURL(wfsPath,nodeText,parseCapabilities,"text/plain",null);//orig
function getExtent(ext){
reComma=new RegExp(",", "g");
ext=ext.replace(reComma," ");
return ext.split(" ");
function createExtent(extent){
xmin = extent[0];
ymin = extent[1];
width= extent[2] - extent[0];
height= extent[3] - extent[1];
height2= ((extent[3]) - (-1*(extent[1])));
//added NR
//so that events will be captured on <svg id="map">
element
backgr=svgdoc.getElementById("bg");
backgr.setAttribute("x",xmin);
backgr.setAttribute("y",ymin);
backgr.setAttribute("width",width);
backgr.setAttribute("height",height);
//end added NR
svgdoc.getElementById('map').setAttribute("viewBox",xmin+"
" +ymin+" "+width+" "+height);
svgdoc.getElementById('keyMap').setAttribute("viewBox",xmin+"
matrix="matrix(1 0 0 -1 0 "+height2+")";
mapLayers = svgdoc.getElementById("mapLayers");
mapLayers.setAttribute("transform",matrix);
keyMapLayers =
svgdoc.getElementById("keyMapLayers");
keyMapLayers.setAttribute("transform",matrix);
function statusText(type,content){
switch(type){
case "request":
window.status="Requesting "+content+" from
server...";
break;
case "response":
window.status="Parsing "+content+"...";
break;
function dropNS(str,ns){
reNS=new RegExp(ns+":", "g");
str=str.replace(reNS,"");
return str;
//added NR
function addNS(str,ns,elt){
reNS=new RegExp(elt, "g");
str=str.replace(reNS,ns+":"+elt);
return str;
//end added NR
function trimHeader(str){
strlen=str.length;
endindex=str.indexOf("?>"); //debug
if(endindex!=-1){ //if ==-1 means the srch string is
not found
str = (str.substring(endindex+2,strlen));
return str;
function trimLastCh(str){
strlen=str.length;
str = (str.substring(0,strlen-1));
return str;
function parseCapabilities(res){
statusText("response","capabilities");
text=res.content;
if(text==""){
alert("Empty response from server.");
else{
genFeatLater=false;
text=trimHeader(text);
var thenode =
svgdoc.getElementById("capabilities");
newNode = parseXML( text, svgdoc );
prompt("Capabilities response:
",printNode(newNode));
subnode=newNode.firstChild;
thenode.appendChild (subnode);
//added NR
if((text.indexOf("GetExtendedProjectDescriptor"))!=-1){
alert("getEPD after append child");//debug
getEPD();
//end added NR
if((text.indexOf("GetStyledLayerDescriptor"))!=-1){
getSLD();
if((text.indexOf("GetExtendedLayerDescriptor"))!=-1){
getELD();
genFeatLater=true;
//edited NR
if((text.indexOf("DescribeFeatureType"))!=-1){
getXSD();
//end edited NR
if(genFeatLater==false){
genFeatureList();
//also added <g id="xsd"> to svg element
function getXSD(){
statusText("request","XML schema");
theCall=svgdoc.createElement("DescribeFeatureType");
theCall.setAttribute("outputFormat","XMLSCHEMA");
var thenode = svgdoc.getElementById("capabilities");
//added NR
path=thenode.getElementsByTagName("DescribeFeatureType").item(0).getElementsByTagName("Post").item(0).getAttribute("onlineResource");
//end added NR
theFeatureTypes=thenode.getElementsByTagName('FeatureType');
for (i=0;i<theFeatureTypes.length;i++){
name=theFeatureTypes.item(i).getElementsByTagName('Name').item(0).firstChild.nodeValue;
text=svgdoc.createTextNode(name);
typeName=svgdoc.createElement("TypeName");
typeName.appendChild(text);
theCall.appendChild(typeName);
alert(nodeText);
//edited NR (wfsPath to path)
result=postURL(path,nodeText,parseXSD,"text/plain",null);
//end edited NR
function parseXSD(res){
statusText("response","XML schema");
text=res.content;
if((text=="")||(text==null)){
else{
text=dropNS(text,"gml");
text=dropNS(text,"xsd");
var thenode = svgdoc.getElementById("xsd");
prompt("XMLSchema response:
// prompt("XMLSchema response: ",text);
listFields();
function listFields(){
text="";
theComplexTypes=thenode.getElementsByTagName('complexType');
for (i=0;i<theComplexTypes.length;i++){
table=theComplexTypes.item(i).getAttribute('name');
nameLength=table.length;
typeIndex=table.indexOf("_Type");
if(typeIndex!=-1){
table =
(table.substring(0,nameLength-typeIndex+1));
text += "table "+i+": "+table+" ";
theElements=theComplexTypes.item(i).getElementsByTagName('element');
for(j=0;j<theElements.length;j++){
fieldName=theElements.item(j).getAttribute("name");
fieldNameLength=fieldName.length;
periodIndex=fieldName.indexOf(".");
if(periodIndex!=-1){
fieldName =
(fieldName.substring(periodIndex,fieldNameLength));
text += "field "+j+": "+fieldName+" ";
alert(text);
//added NR
//also added <g id="epd"> to svg element
function getEPD(){
statusText("request","extended project descriptor");
theCall=svgdoc.createElement("GetExtendedProjectDescriptor");
alert(nodeText);
//added NR
path=svgdoc.getElementById("capabilities").getElementsByTagName("GetExtendedProjectDescriptor").item(0).getElementsByTagName("Post").item(0).getAttribute("onlineResource");
//end added NR
result=postURL(path,nodeText,parseEPD,"text/plain",null);
var scaleFactor=null;
function parseEPD(res){
statusText("response","extended project
descriptor");
text=res.content;
if(text==""){
else{
var thenode = svgdoc.getElementById("epd");
prompt("EPD response: ",printNode(subnode));
theEPD=svgdoc.getElementsByTagName("ExtendedProjectDescriptor").item(0);
theSFnl =
theEPD.getElementsByTagName("ScaleFactor");
theSFnl.length==0 ? scaleFactor =null :
scaleFactor = theSFnl.item(0).firstChild.nodeValue;
if(bbox==null){
theBBnl = theEPD.getElementsByTagName("BBox");
bboxinit = theBBnl.item(0).firstChild.nodeValue;
ext=getExtent(bboxinit);
createExtent(ext);
calcScale();
//global variable scale of map at initial load
var baseScale=null;
function calcScale(){
mapv=svgdoc.getElementById("map");
mapW = parseFloat(mapv.getAttribute('width'));
mvb=mapv.getAttribute("viewBox").split(" ");
mapGW=(parseFloat(mvb[2]))-(parseFloat(mvb[0]));
baseScale=mapGW/(mapW*scaleFactor);
currentMapScale=baseScale;
//end added NR
function getSLD(){
statusText("request","styled layer descriptor");
theCall=svgdoc.createElement("GetStyledLayerDescriptor");
alert(nodeText);
result=postURL(wfsPath,nodeText,parseSLD,"text/plain",null);
function parseSLD(res){
statusText("response","styled layer descriptor");
text=res.content;
if(text==""){
else{
var thenode = svgdoc.getElementById("sld");
prompt("SLD response: ",printNode(newNode));
function getELD(){
statusText("request","extended layer descriptor");
theCall=svgdoc.createElement("GetExtendedLayerDescriptor");
alert(nodeText);
result=postURL(wfsPath,nodeText,parseELD,"text/plain",null);
function parseELD(res){
statusText("response","extended layer descriptor");
text=res.content;
if(text==""){
else{
var thenode = svgdoc.getElementById("eld");
prompt("ELD response: ",printNode(subnode));
//added NR
setScaleThresholds();
genFeatureList();
//end added NR
//added NR
function setScaleThresholds(){
theELD=svgdoc.getElementsByTagName("ExtendedLayerDescriptor").item(0);
theELDNL =theELD.getElementsByTagName("NamedLayer");
for(i=0;i<theELDNL.length;i++){
enlnod=theELDNL.item(i);
theName=enlnod.getAttribute("name");
theMaxnl =
enlnod.getElementsByTagName("MaxScale");
theMaxnl.length==0 ? maxScales[theName] =null :
theMaxnl.item(0).firstChild.nodeValue;
theMinnl =
enlnod.getElementsByTagName("MinScale");
theMinnl.length==0 ? minScales[theName] =null :
theMinnl.item(0).firstChild.nodeValue;
//end added NR
function genFeatureList(){
theLayers[i]=theFeatureTypes.item(i).getElementsByTagName('Name').item(0).firstChild.nodeValue;
writeLayer(theLayers[i],i);
//added NR
addExtras();
//end added NR
var sld = svgdoc.getElementById("sld");
if(sld.hasChildNodes()==true){
layerNodes=sld.getElementsByTagName("NamedLayer");
for(i=0;i<layerNodes.length;i++){
itemName=layerNodes.item(i).getAttribute("name");
childs=layerNodes.item(i).getElementsByTagName("UserStyle").item(0).childNodes;
for(j=0;j<childs.length;j++){
if((childs.item(j).nodeName=="PolygonSymbol")||(childs.item(j).nodeName=="LineStringSymbol")||(childs.item(j).nodeName=="PointSymbol")){
atts=childs.item(j).childNodes;
break;
layerStyle =
svgdoc.getElementById("l"+itemName).getStyle();
for(k=0;k<atts.length;k++){
switch(atts.item(k).nodeName){
case "FillColor":
layerStyle.setProperty("fill",atts.item(k).firstChild.nodeValue);
break;
case "StrokeColor":
layerStyle.setProperty("stroke",atts.item(k).firstChild.nodeValue);
break;
default:
break;
else{
layerStyle=svgdoc.getElementById("l"+theFeatureTypes.item(i).getElementsByTagName('Name').item(0).firstChild.nodeValue).getStyle();
layerStyle.setProperty("stroke","black");
//edited NR
if(bbox==null){
getFeatureInit();
else{
getFeature();
//end edited NR
function writeLayer(layer,index){
theMapLayer=svgdoc.createElement("g");
theMapLayer.setAttribute("id","l"+layer);
mapNode = svgdoc.getElementById("mapLayers");
mapNode.appendChild(theMapLayer);
//changed function name NR
function getFeatureInit(){
statusText("request","features");
theCall=svgdoc.createElement("GetFeature");
theCall.setAttribute("maxFeatures", "1000" );
for(i=0;i<theLayers.length;i++){
if(baseScale!=null){
if(isDisplayed(theLayers[i],baseScale,true)){
theQuery=svgdoc.createElement("Query");
theQuery.setAttribute("typeName",theLayers[i]);
theQuery=theCall.appendChild(theQuery);
else{
queries=svgdoc.getElementById("queries");
queries.appendChild(theCall);
alert("Request: "+nodeText);
result=postURL(wfsPath,nodeText,parseFeatureMembers,"text/plain",null);
function parseFeatureMembers(res){
statusText("response","features");
text=res.content;
//prompt("FeatureMembers result: ",text);
if(text==""){
else{
node = parseXML( text, svgdoc );
subnode=node.firstChild;
featureCollections=svgdoc.getElementById("featureCollections");
featureCollections.appendChild(subnode);
//added/changed NR
if((bbox==null)&&(bboxinit==null)){
boundedBy=subnode.getElementsByTagName("boundedBy").item(0);
bboxinit=boundedBy.getElementsByTagName("coordinates").item(0).firstChild.nodeValue;
createExtent(ext);
//end added/changed NR
features=subnode.getElementsByTagName("featureMember");
var prevlayer = "";
var idxxx=1;
for (i=0;i<features.length;i++){
childs=features.item(i).childNodes;
theNodeName=childs.item(j).nodeName;
if(theNodeName!="#text"){
layer=theNodeName;
break;
layer==prevlayer ? idxxx+=1 : idxxx=1;
genFeature(layer,features.item(i),idxxx);
prevlayer = layer;
//modified NR
//test if panbox already created...
pbExists=false;
rects=svgdoc.getElementsByTagName("rect");
if(rects.length>0){
for(i=0;i<rects.length;i++){
if(rects.item(i).getAttribute("id")=="panBox"){
pbExists=true;
break;
if(!pbExists){
addEvents();
addPanBox();
//to adjust circle radii on any newly created points
resetSymbols();
//end modified NR
function genFeature(layer,node,idxxx){
coords=node.getElementsByTagName("coordinates");
//if there is only one point, assume that it is a
point layer
if((coords.length==1)&&(coords.item(0).firstChild.nodeValue.indexOf("
")==-1)){
geom=coords.item(0).firstChild.nodeValue.split(",");
cx=geom[0];
cy=geom[1];
addPoint(layer,cx,cy,idxxx);
//otherwise, begin generating a path
else{
d="";
for (j=0;j<coords.length;j++){
itemx=coords.item(j).firstChild.nodeValue;
reSpace=new RegExp(" ", "g");
itemx=itemx.replace(reSpace," L ");
itemx=itemx.replace(reComma," ");
d += "M "+itemx;
addPath(layer,d,idxxx);
function addPath(layer,d,idxxx) {
var newnodea=svgdoc.createElement("path");
newnodea.setAttribute('d', d);
newnodea.setAttribute('id', "l"+layer+"f"+idxxx);
var mapNode = svgdoc.getElementById("l"+layer);
mapNode.appendChild(newnodea);
var oldlayer=""; //these two global variables to make
sure we recalculate only when the layer change
var rsize=0;
function addPoint(layer,cx,cy,idxxx) {
var newnodea=svgdoc.createElement("circle");
newnodea.setAttribute('cx', cx);
newnodea.setAttribute('cy', cy);
//changed nr
if (oldlayer!=layer) rsize =
calcSize(layer,"SymbolSize");
//end changed nr
newnodea.setAttribute('r', rsize);
oldlayer = layer;
//added AR : to calculate the marker size relative to
viewBox; strokeWidth calculated on Legend functions
function calcSize(theLayer,setting){
eld =
eldnl = eld.getElementsByTagName("NamedLayer");
for (ix=0;ix<eldnl.length;ix++){
eldnli=eldnl.item(ix);
if (eldnli.getAttribute('name')==theLayer) {
//changed nr
ssz = eldnli.getElementsByTagName(setting);
//end changed nr
thesize =
parseFloat(ssz.item(0).firstChild.nodeValue);
//changed NR
return getSize(thesize);
//added NR
function getSize(thesize){
map = svgdoc.getElementById("map");
mapWd = parseFloat(map.getAttribute('width'));
screenWd = parseFloat(screen.width);
mapVb = map.getAttribute('viewBox').split(' ');
vbWd = parseFloat(mapVb[2]);
resultsize = parseFloat(thesize*vbWd/screenWd);
return resultsize;
function doZoom(){
SetStaticZP();
resetSymbols();
getFeature();
function doScroll(){
SetStaticZP();
// getFeature();
//this function will send a GetFeature request
//for layers set to display at (new) current scale
function getFeature(){
currentMapScale=baseScale/(svgDocument.documentElement.currentScale);
//first, test if there is at least one layer to load
load = false;
if(isDisplayed(theLayers[i],currentMapScale,false)==true){
load = true;
break;
if(load==true){
mapR = svgdoc.rootElement;
mcs=mapR.currentScale;
minX=parseFloat(mvb[0])+mapR.currentTranslate.x;
minY=parseFloat(mvb[1])+mapR.currentTranslate.y;
maxX=minX+(parseFloat(mvb[2])*mcs);
maxY=minY+(parseFloat(mvb[3])*mcs);
theFilter=svgdoc.createElement("Filter");
theNot=svgdoc.createElement("Not");
theDisjoint=svgdoc.createElement("Disjoint");
thePropertyName=svgdoc.createElement("PropertyName");
nodeText="";
nodeText+=theLayers[i]+"/"+theLayers[i]+".the_geom|";
nodeText=trimLastCh(nodeText);
theTextNode=svgdoc.createTextNode(nodeText);
thePropertyName.appendChild(theTextNode);
theDisjoint.appendChild(thePropertyName);
theBox=svgdoc.createElementNS("gml","box");
theCoordinates=svgdoc.createElementNS("gml","coordinates");
theTextNode=svgdoc.createTextNode(minX+","+minY+"
"+maxX+","+maxY);
theCoordinates.appendChild(theTextNode);
theBox.appendChild(theCoordinates);
theDisjoint.appendChild(theBox);
theNot.appendChild(theDisjoint);
theFilter.appendChild(theNot);
logNode = svgdoc.getElementById("viewboxLog");
entries=logNode.getElementsByTagName("entry");
if(entries.length>0){
for(i=0;i<entries.length;i++){
entry=entries.item(i);
scale=parseFloat(entry.getElementsByTagName('scale').item(0).firstChild.nodeValue);
viewbox=entry.getElementsByTagName('coordinates').item(0).firstChild.nodeValue;
disjoint=false;
for(j=0;j<theLayers.length;j++){
if((isDisplayed(theLayers[j],currentMapScale,false)==true)&&(isDisplayed(theLayers[j],scale,false)==true)){
disjoint=true;
break;
if(disjoint==true){
nodeText="";
nodeText+=theLayers[j]+"/"+theLayers[j]+".the_geom|";
theTextNode=svgdoc.createTextNode(viewbox);
theFilter.appendChild(theDisjoint);
theCall.appendChild(theFilter);
nodeText=addNS(nodeText,"gml","box");
nodeText=addNS(nodeText,"gml","coordinates");
// if(showCalls==true){
theEntry = svgdoc.createElement("entry");
theCoordsNode=svgdoc.createElement("coordinates");
theCoords=svgdoc.createTextNode(minX+","+minY+"
"+maxX+","+maxY);
theCoordsNode.appendChild(theCoords);
theEntry.appendChild(theCoordsNode);
theScaleNode=svgdoc.createElement("scale");
theScale=svgdoc.createTextNode(currentMapScale);
theScaleNode.appendChild(theScale);
theEntry.appendChild(theScaleNode);
logNode.appendChild (theEntry);
//this function to test if the given layer should be
displayed
//at the current scale--checks MaxScale and MinScale
loaded with
//extended layer descriptor
function isDisplayed(layer,scale,isinit){
if((bbox==null)&&(isinit==false)){
if
(!(((baseScale>minScales[layer])||(minScales[layer]==0))
((baseScale<maxScales[layer])||(maxScales[layer]==0)))
&& (((scale>minScales[layer])||(minScales[layer]==0))
&& ((scale<maxScales[layer])||(maxScales[layer]==0))))
return true;
else{
return false;
else{
if(((scale>minScales[layer])||(minScales[layer]==0))
&& ((scale<maxScales[layer])||(maxScales[layer]==0))){
return true;
else{
return false;
function
getSetting(layer,settingType,dataType,setting){
theSetting=null;
ld =
svgdoc.getElementsByTagName(settingType).item(0);
ldnl = ld.getElementsByTagName("NamedLayer");
ldnli=ldnl.item(ix);
if (ldnli.getAttribute('name')==layer) {
settingNode = ldnli.getElementsByTagName(setting);
settingNode.length==0 ? theSetting =null:theSetting
=settingNode.item(0).firstChild.nodeValue;
if(dataType=="number"){
theSetting=parseFloat(theSetting);
return theSetting;
function resetSymbols(){
for (i=0;i<theLayers.length;i++){
type=getSetting(theLayers[1],"ExtendedLayerDescriptor","string","Shape");
if((type=="line") || (type=="polygon")){
node=svgdoc.getElementById("l"+theLayers[i]);
strokeWid=getSetting(theLayers[i],"StyledLayerDescriptor","string","StrokeWidth");
node.getStyle().setProperty("stroke-width",strokeWid);
else{
thePoints=svgdoc.getElementById("l"+theLayers[i]).getElementsByTagName("circle");
if(thePoints.length>0){
for(p=0;p<thePoints.length;p++){
rsize =
calcSize(theLayers[i],"SymbolSize")/svgDocument.documentElement.currentScale;
thePoints.item(p).setAttribute('r', rsize);
resetExtras();
function addExtras(){
theMapLayer.setAttribute("id","extras");
theExt=svgdoc.createElement("rect");
function resetExtras(){
wid=getSize(1);
pa=svgdoc.getElementById("pathadder");
pa.getStyle().setProperty("stroke-width",wid);
pa2=svgdoc.getElementById("pathadder2");
pa2.getStyle().setProperty("stroke-width",wid);
zm=svgdoc.getElementById("zoomer");
zm.getStyle().setProperty("stroke-width",wid);
pm=svgdoc.getElementById("panner");
pm.getStyle().setProperty("stroke-width",wid);
//added NR
function addFeature(evt){
var crtsc = svgdoc.rootElement.currentScale;
var crttr = svgdoc.rootElement.currentTranslate;
var mapnod = svgdoc.getElementById("map");
var mlvb = mapnod.getAttribute("viewBox").split(" ");
var xfac = parseFloat(mlvb[2]) /
parseFloat(mapnod.getAttribute("width")) / crtsc;
var yfac = parseFloat(mlvb[3]) /
parseFloat(mapnod.getAttribute("height")) / crtsc;
crdx=parseFloat(mlvb[0]) + crttr.x +
xfac*(evt.clientX);
crdy=((parseFloat(mlvb[1]) + crttr.y) +
yfac*(parseFloat(mapnod.getAttribute("height"))-evt.clientY));
newX=crdx;
newY=crdy;
xoff=mapnod.getAttribute("x");
yoff=mapnod.getAttribute("y");
alert("xoff: "+xoff+" yoff: "+yoff);
//alert("x: "+evt.clientX+" y: "+evt.clientY+ " wid:
"+parseFloat(mapnod.getAttribute('width'))+" height:
"+parseFloat(mapnod.getAttribute('height')));
if( pathadder==null )
pathadder = svgdoc.getElementById("pathadder");
pathadder2 = svgdoc.getElementById("pathadder2");
pathadder2.getStyle().setProperty("visibility",
"visible");
startX=newX;
startY=newY;
pathadder.setAttribute("d", "M " + startX+ " " +
startY + " ");
else
var newpath=pathadder.getAttribute("d");
if (startNew==true)
startX=newX;
startY=newY;
newpath=newpath+" M " + startX + " " + startY + "
startNew=false;
else
newpath=newpath+" L " + newX + " " + newY + " ";
if((oldX==newX)&&(oldY==newY))
startNew=true;
else
oldX=newX;
oldY=newY;
pathadder.setAttribute("d",newpath);
pathadder2.setAttribute("d", newpath );
function addFeaturePoint(evt) {
xfac*(evt.clientX);
yfac*(parseFloat(mapnod.getAttribute("height"))-(evt.clientY+30)));
newX=crdx;
newY=crdy;
if((pathadder !=
null)&&(startNew!=true)&&(pressedButton="add_feature"))
//alert(newpath);
function startZoom(evt){
zoomer = svgDoc.getElementById("zoomer");
zoomer.getStyle().setProperty("visibility",
"visible");
function continueZoom(evt){
zoomer.setAttribute("width",(Math.abs(newX-origX))*scaleFactor);
zoomer.setAttribute("height",(Math.abs(newY-origY))*scaleFactor);
function endZoom(evt){
if( zoomer != null )
"hidden");
zoomer.setAttribute("width","0");
zoomer.setAttribute("height","0");
oldCurrentWidth=currentWidth;
oldCurrentHeight=currentHeight;
newWidth=(newX-origX)*scaleFactor;
newHeight=(newY-origY)*scaleFactor;
if (!newWidth==0)
if((newHeight/newWidth)>heightFactor)
currentHeight=newHeight;
currentWidth=newHeight/heightFactor;
minX=minX-((currentWidth-newWidth)/2);
else
currentWidth=newWidth;
currentHeight=newWidth*heightFactor;
minY=minY-((currentHeight-newHeight)/2);
svgDoc.getElementById('theSVG').setAttribute("viewBox",minX+"
"+minY+" "+ currentWidth+" "+currentHeight);
currentScale=baseScale*scaleFactor;
loadSVG(minX,minY,currentWidth,currentHeight,currentScale);
scaleFactor=currentWidth/mapWidth;
setScale(currentScale);
resetSymbols();
showHideRows();
else
minX=oldMinX;
minY=oldMinY;
alert("To zoom in, click and drag around the area
you want to view.");
zoomer = null;
]]></script>
<svg id="map" x="0" y="30">
<g id="mapLayers"
style="fill:none;fill-rule:evenodd;stroke-antialiasing:true;">
<!-- added NR -->
<rect id="bg" style="fill:white;"/>
<rect id="zoomer" x="0" y="0" width="0" height="0"
style="visibility: hidden; fill:
none;stroke:red;stroke-width:1"/>
<line id="panner" x1="0" y1="0" x2="0" y2="0"
<path id="pathadder" style="fill:none;visibility:
hidden; stroke:red;stroke-width:1" d=""/>
<path id="pathadder2"
style="fill:pink;fill-rule:evenodd;opacity:0.3;visibility:
<!-- end added NR -->
</g>
<g id="featureCollections"/>
<g id="queries"/>
<g id="capabilities"/>
<!-- added NR -->
<g id="epd"/>
<g id="viewboxLog"/>
<g id="sld"/>
<g id="eld"/>
<g id="xsd"/>
</svg>
<svg id="keyMap" >
<!-- added AR : still referencing the whole mapLayers,
not the preferred individual layer -->
<use id="useMapLayers" xlink:href="#mapLayers" x="0"
y="0" width="100%" height="100%" />
<g id="keyMapLayers"
style="fill:none;fill-rule:evenodd;stroke-antialiasing:true;"/>
</svg>
<svg id="legend" x="0" y="0" width="2" height="100" >
<rect id="legBack" x="0" y="0" width="100%"
height="100%" fill='#DDD' stroke='#EEE'
stroke-width='1'/>
<svg id='tester' onload="" x="0" y="0" width="2"
height="100" preserveAspectRatio="xMinyMin meet">
<g id='legendLayers'>
<text x="2" y="10" font-family="Arial"
fill="black" stroke="none" font-size="10" >.</text>
<g id="cboxes" transform="translate(2,25)"
onclick='chk(evt);'></g>
<g id="legends" transform="translate(20,25)"
onclick='alert(printNode(evt.getTarget().parentNode))'></g>
<g id="labelkey" transform="translate(20,25)"
onclick=''></g>
</g>
</svg>
<g id='legbutton'>
<rect id="butBack" x="0" y="0" width="1000"
height="18" fill='#BBB' stroke='none'
stroke-width='0'/>
<text x="2" y="12" font-family="Arial" fill="black"
stroke="none" font-size="12" >Legend</text>
<use id="legup" onclick="legscroll(evt)"
onmousedown="chbutd(evt)" onmouseup="chbutu(evt)"
xlink:href="#triangleup" x="0" y="0" width="14"
height="14" />
<use id="legdown" onclick="legscroll(evt)"
xlink:href="#triangledown" x="0" y="0" width="14"
height="14" />
</g>
</svg>
<svg id="toolbar" width="100" height="30"
preserveAspectRatio="xMidyMid meet" onmouseover=""
onmouseout="" >
<rect pointer-events="none" id='hh' x='0' y='0'
width='100%' height='100%' fill="#BBB"/>
<line x1="0" y1="100%" x2="100%" y2="100%"
fill="none" stroke="#666" stroke-width="3"/>
<line x1="100%" y1="100%" x2="100%" y2="0"
<line x1="0" y1="0" x2="0" y2="100%" fill="none"
stroke="#EEE" stroke-width="3"/>
<line x1="0" y1="0" x2="100%" y2="0" fill="none"
<g onmouseover="toolclick(evt)"
onmousedown="chlink(evt)"
onmouseup="chlink(evt);chkup(evt)"
onload="arrangeButton(evt)" >
<g id="Keymap_toggle" onclick="showhide('keyMap')"
<use xlink:href="#bt_up" width="25" height="20"/>
<use xlink:href="#keymap" x="" y="0" width="25"
height="20" pointer-events="none" />
</g>
<g id="Legend_toggle" onclick="showhide('legend')"
<use xlink:href="#showlegend" width="25"
</g>
<g id="Autolabel_toggle" onclick="labelall()" >
<use xlink:href="#autolabel" width="25"
</g>
<g id="Manual_Label" onclick="chkdown(evt)" >
<use xlink:href="#label" width="25" height="20"
</g>
<g id="Show_Identity" onclick="chkdown(evt)">
<use xlink:href="#identity" width="25"
</g>
<g id="zoom_in" onclick="mapzoom(1)" >
<use xlink:href="#zoomplus" width="25"
</g>
<g id="zoom_all" onclick="mapzoom(0)" >
<use xlink:href="#nozoom" width="25" height="20"
</g>
<g id="zoom_out" onclick="mapzoom(-1)" >
<use xlink:href="#zoommin" width="25" height="20"
</g>
<g id="help_about" onclick="helpabout()">
<use xlink:href="#helpz" width="25" height="20"
</g>
<g id="add_feature" onclick="chkdown(evt)" >
<use xlink:href="#input" width="25" height="20"
</g>
<g id="open_map" onclick="toolclick(evt,'open_map
clicked')" >
<use xlink:href="#open" width="25" height="20"
</g>
<g id="reload_map" onclick="toolclick(evt,'reload
map clicked')" >
<use xlink:href="#reload" x="" y="0" width="25"
</g>
<g id="add_links" onclick="toolclick(evt,'links
clicked')" >
<use xlink:href="#links" width="25" height="20"
</g>
<g id="show_table"
onclick="toolclick(evt,'show_table clicked')" >
<use xlink:href="#table" width="25" height="20"
</g>
<g id="build_query" onclick="toolclick(evt,'query
clicked')">
<use xlink:href="#query" width="25" height="20"
</g>
<g id="use_filter" onclick="toolclick(evt,'use
filter clicked')">
<use xlink:href="#filter" width="25" height="20"
</g>
<g id="remove_filter"
onclick="toolclick(evt,'remove filter clicked')">
<use xlink:href="#nofilter" width="25"
</g>
<g id="find_on_map" onclick="toolclick(evt,'find
clicked')">
<use xlink:href="#find" width="25" height="20"
pointer-events="none"/>
</g>
<g id="admin" onclick="toolclick(evt,'admin
clicked')">
<use xlink:href="#jroger" width="25" height="20"
</g>
<g id="go_home" onclick="toolclick(evt,'home
clicked')">
<use xlink:href="#home" width="25" height="20"
</g>
<g>
<text x="20" y="13" id='texttool'
font-family="Arial" font-size="10"
fill='rgb(00,88,00)' >.</text>
</g>
</g>
</svg>
<defs>
<use id="masterUse" xlink:href="" x="0" y="0"
<use id="usetest" xlink:href=""></use>
<rect id="abc" x="0" y="0" width="150" height="150"
style="fill:#F00;stroke:white;stroke-width:1pt"/>
<symbol id='marker' viewBox="0 0 20 20"
preserveAspectRatio="xMidyMid meet">
<ellipse cx="10" cy="10" rx="5" ry="5"/>
</symbol>
<symbol id='fill' viewBox="0 0 20 20"
<rect x="0" y="0" width="20" height="20" />
</symbol>
<symbol id='pen' viewBox="0 0 20 20"
<path d="M 0 16 L 7 3 L 14 16 L 20 0" fill="none"/>
</symbol>
<symbol id="check" viewBox="0 0 10 10"
<rect x="0" y="0" width="10" height="10"
fill="lime" fill-opacity="0" stroke="black"
stroke-width="1pt"/>
<path d="M2,5 L5,8 8,2" fill="none" stroke="black"
stroke-width="1pt" />
</symbol>
<symbol id="uncheck" viewBox="0 0 10 10"
</symbol>
<symbol id="triangledown" viewBox="0 0 10 10"
<path fill="#888" d="M1,1 L5,9 9,1 z" stroke="none"
stroke-width="0pt" transform="translate(1,1)" />
<path fill="#CCC" d="M1,1 L5,9 9,1 z" stroke="none"
stroke-width="0pt" />
<path fill="none" d="M5,9 L1,1 9,1 " stroke="#EEE"
stroke-width="0.5pt" />
</symbol>
<symbol id="triangledown2" viewBox="0 0 10 10"
<path fill="#CCC" d="M1,1 L5,9 9,1 z" stroke="#999"
stroke-width="0.8pt" />
</symbol>
<symbol id="triangleup" viewBox="0 0 10 10"
<path fill="#888" d="M1,9 L5,1 9,9 z" stroke="none"
stroke-width="0pt" transform="translate(1,1)"/>
<path fill="#CCC" d="M1,9 L5,1 9,9 z" stroke="none"
<path fill="none" d="M1,9 L5,1 " stroke="#EEE"
</symbol>
<symbol id="triangleup2" viewBox="0 0 10 10"
<path fill="#CCC" d="M1,9 L5,1 9,9 z" stroke="#999"
</symbol>
</defs>
<defs id="toolbar_button_symbols">
<symbol id="bt_up" viewBox="0 0 30 26"
preserveAspectRatio="none">
<rect id="r1" x="0" y="0" width="28" height="24"
rx="5" ry="5" fill="#FFF" stroke="none"/>
<rect id="r3" x="2" y="2" width="28" height="24"
rx="5" ry="5" fill="#666" stroke="none"/>
<rect id="r2" x="1" y="1" width="28" height="24"
rx="5" ry="5" fill="#DDD" stroke="none"/>
</symbol>
<symbol id="bt_down" viewBox="0 0 30 26"
rx="5" ry="5" fill="yellow" stroke="#666"
stroke-width="2"/>
</symbol>
<symbol id="open" viewBox="0 0 30 26"
<polygon points="6,20 6,8 8,8 8,6 12,6 12,8 20,8
20,20" fill='rgb(00,200,00)' stroke='rgb(00,88,00)'/>
<polygon points="6,20 10,12 26,12 20,20"
fill='rgb(00,88,00)' stroke='green'/>
</symbol>
<symbol id="keymap" viewBox="0 0 30 26"
<path d="M15,4 V22 M6,13 H24"
stroke='rgb(00,88,00)' fill='none'
stroke-width='1pt'/>
<polygon points="10,8 20,8 20,18 10,18"
stroke='rgb(00,88,00)' fill='lime'/>
</symbol>
<symbol id="showlegend" viewBox="160 0 35 30"
<path d="M188.556 14.8889 L181.773 24 L164.223 24
L172.023 14.8889 z"
style="fill:#080;stroke-width:1;stroke:#000"/>
<path d="M189 10.4444 L182.217 19.5556 L164.667
19.5556 L172.467 10.4444 z"
style="fill:#FF0;stroke-width:1;stroke:#000"/>
<path d="M189 6.44444 L182.217 15.5556 L164.667
15.5556 L172.467 6.44444 z"
style="fill:#0D0;stroke-width:1;stroke:rgb(0,0,0)"/>
</symbol>
<symbol id="label" viewBox="0 0 30 26"
<polygon points="10,13 15,7 26,7 26,19 15,19"
fill='#090' stroke='#000'/>
<circle cx='16' cy='13' r='2.5' fill='#DDD'
stroke='#000'/>
<ellipse transform='translate(9,9) rotate(45)
translate(-9,-9)' cx="9" cy="9" rx="7" ry="2"
fill="none" stroke='#000'/>
</symbol>
<symbol id="input" viewBox="0 0 30 26"
<line x1="15" y1="6" x2="15" y2="20"
stroke='#000'/>
<line x1="9" y1="13" x2="21"
y2="13" stroke='#000'/>
</symbol>
<symbol id="autolabel" viewBox="0 0 30 26"
<polygon transform="translate(-3,3)" points="10,13
15,7 26,7 26,19 15,19" fill='lime' stroke='#000'/>
<circle transform="translate(-3,3)" cx='16' cy='13'
r='2.5' fill='#DDD' stroke='#000'/>
<ellipse transform='translate(9,12) rotate(45)
</symbol>
<symbol id="filter" viewBox="0 0 30 26"
<polygon points="5,5 25,5 25,7 17,16 17,22 13,22
13,16 5,7" fill='url(#green-metallic)' stroke='#000'/>
</symbol>
<symbol id="nofilter" viewBox="0 0 30 26"
<path d="M12,10 L25,20 M12,20 L25,10" fill='none'
stroke='#F00' stroke-width='4'/>
</symbol>
<symbol id="links" viewBox="0 0 30 26"
<polygon points="10,23 13,15 10,15 13,09 9,09 13,3
19,3 15,09 18,09 14,15 16,15" fill='#080'
stroke='#000'/>
</symbol>
<symbol id="table" viewBox="0 0 30 26"
<rect x="5" y="5" width="20" height="16"
fill="#FFF" stroke="black" stroke-width='1pt'/>
<rect x="7" y="9" width="5" height="11" fill="#BBB"
stroke="none"/>
<rect x="13" y="9" width="5" height="11"
fill="#BBB" stroke="none"/>
<rect x="19" y="9" width="5" height="11"
<rect x="5" y="5" width="20" height="2" fill="#000"
stroke="none"/>
</symbol>
<symbol id="identity" viewBox="0 0 30 26"
<ellipse cx="15" cy="13" rx="10" ry="10"
stroke="none" fill='rgb(00,88,00)'/>
<text x="12" y="19" font-family="Arial"
font-weight="bold" font-size="20" fill='#FFF'>i</text>
</symbol>
<symbol id="query" viewBox="0 0 30 26"
<text x="8" y="19" font-family="Arial"
font-weight="bold" font-size="18" fill='#FFF'>Q</text>
</symbol>
<symbol id="reload" viewBox="0 0 30 30"
<path transform='translate(0,1)'
d="M16.23 15.7 L22 21.5 L16.23 27.3 L16.23 23.75
C12.16 23.7 5 20.6 5 10.3 L10.7 10.3 C10.7 15 13 19.17
16.23 19.15 z"
style="fill:#060;stroke:none;"/>
<path transform='translate(15,15) rotate(180)
translate(-15,-15) translate(0,2)'
16.23 19.15 z"
</symbol>
<symbol id="jroger" viewBox="0 0 30 26"
<text x="6" y="21" font-family="Wingdings"
font-weight="bold" font-size="24"
fill='rgb(00,88,00)'>N</text>
</symbol>
<symbol id="helpz" viewBox="0 0 30 26"
<text x="6" y="21" font-family="Arial"
fill='rgb(00,88,00)'>?</text>
</symbol>
<symbol id="home" viewBox="2 2 30 26"
preserveAspectRatio="none" >
<g id="hm" pointer-events="none"
style="stroke-width:3;fill:none">
<path fill="url(#homegrad)" d="M9,13 h16 v11 h-6
v-9 h-4 v9 h-6 z"/>
<path fill="rgb(00,88,00)" d="M4,14 L17,5 30,14 z"
</g>
</symbol>
<symbol id="find" viewBox="2 2 30 26"
<g transform="translate(2,1)"
style="fill:url(#green-metallic);stroke:#004400;stroke-width:.2">
<rect x="6.3126" y="8.64304" width="5.12"
height="8"/>
<rect x="4.9113" y="16.8922" width="7.9"
height="6.46"/>
<rect x="5.70931" y="4.25491" width="6.335"
height="4.16151"/>
<rect x="17.8103" y="8.58636" width="5.12"
height="8"/>
<rect x="16.409" y="16.8356" width="7.9"
height="6.46"/>
<rect x="17.207" y="4.19823" width="6.335"
height="4.16151"/>
<rect x="11.4656" y="9.37506" width="6.4"
height="5"/>
</g>
</symbol>
<symbol id="zoomplus" viewBox="2 2 30 26"
<g id="df" pointer-events="none"
style="stroke:rgb(00,88,00);stroke-width:3;fill:none">
<ellipse cx="14" cy="14" rx="9.5" ry="9.5"
stroke-width="2"/>
<line x1="21.3333" y1="19.8889" x2="28.8889"
y2="25.2222"/>
<line x1="8.44444" y1="14.5556" x2="19.5556"
y2="14.5556"/>
<line x1="13.7778" y1="19.4444" x2="13.7778"
y2="9.22222"/>
</g>
</symbol>
<symbol id="nozoom" viewBox="34 2 30 26"
<g pointer-events="none"
style="fill:none;stroke:rgb(00,88,00);stroke-width:2">
<ellipse cx="46" cy="13.6667" rx="9.5" ry="9.5" />
<line x1="53.3333" y1="19.5556" x2="60.8889"
y2="24.8889" stroke-width="3"/>
<line x1="52.4444" y1="7" x2="39.1111"
y2="20.3333" />
</g>
</symbol>
<symbol id="zoommin" viewBox="66 2 30 26"
style="fill:none;stroke:rgb(00,88,00);stroke-width:3">
<line x1="85.3333" y1="19.5556" x2="92.8889"
y2="24.8889"/>
<ellipse cx="78" cy="13.6667" rx="9.5" ry="9.5"
stroke-width="2"/>
<line x1="72.8889" y1="13.6667" x2="83.1111"
y2="13.6667"/>
</g>
</symbol>
<linearGradient id="green-metallic" x1="0%" y1="0%"
x2="100%" y2="0%" spreadMethod="pad"
gradientUnits="objectBoundingBox">
<stop offset="1%"
style="stop-color:rgb(118,166,128);stop-opacity:1"/>
<stop offset="18%"
style="stop-color:rgb(0,78,0);stop-opacity:1"/>
<stop offset="48%"
style="stop-color:rgb(164,188,168);stop-opacity:1"/>
<stop offset="83%"
style="stop-color:rgb(122,205,142);stop-opacity:1"/>
<stop offset="99%"
</linearGradient>
<linearGradient id="homegrad"
gradientUnits="objectBoundingBox" x1="0" y1="1" x2="0"
y2="0">
<stop offset=".0" style="stop-color:palegreen"/>
<stop offset=".8"
style="stop-color:rgb(00,88,00)"/>
</linearGradient>
<radialGradient id="overgrad"
y2="0">
<stop offset=".05" style="stop-color:palegreen"/>
<stop offset=".9" style="stop-color:green"/>
</radialGradient>
</defs>
</svg>
Chat instantly with your online friends? Get the
FREE Yahoo! Messenger http://uk.messenger.yahoo.com/
