[Geoserver-devel] getting geoclient to work?
I'm trying to get Geoclient up and running.
I think I have all the pieces in place on my Windows XP system:
- Apache2,
- PHP 4.2.3
- MySQL 3.23
I know Apache and PHP are talking as a test file calling phpinfo() works.
PHP and MySQL also work together as loading a PHP/database test file is also
successful.
I've followed the instructions:
- exported a shape file from ArcView using av2svg and loaded it into MySQL;
- edited the resulting connect.php file with correct username and password;
- included the optional svg file which I also exported.
The static svg file works successfully.
However, when I run Apache and try to load geoclient.svg, I get the
following error notices in two successive pop-up windows:
Window 1
Script error window
Security violation
line:9, column: 28
Window 2
Microsoft JScript runtime error window
'the EPD' is null or not an object
line: 307, column: 4
I'm guessing the second window message is because no data was loaded. But
what does the first script error in window 1 mean?
Any suggestions/help appreciated and thanks to the Geoserver team for all
their work so far.
Eamonn
_____________________________________
Éamonn Ó Tuama
Coastal & Marine Resources Centre, UCC
Thanks for the note. Given the security violation message, the problem may
involve a security restriction in the Adobe SVG Viewer, which will use the
proprietary function postXML() to post XML to (and retreive XML from) only
the "originating server"--that is, I believe, a server on the domain from
which the SVG file was downloaded. So as a first step check to make sure
the WFS address you're giving is in the same domain - optimally, perhaps, in
the same directory - as the SVG page.
Nedjo Rogers
----- Original Message -----
To: <geoserver-devel@lists.sourceforge.net>
Sent: Wednesday, December 04, 2002 2:20 AM
Subject: [Geoserver-devel] getting geoclient to work?
- Apache2,
- PHP 4.2.3
- MySQL 3.23
successful.
Window 1
Script error window
Security violation
line:9, column: 28
Window 2
their work so far.
Eamonn
Éamonn Ó Tuama
This SF.net email is sponsored by: Microsoft Visual Studio.NET
comprehensive development tool, built to increase your
productivity. Try a free online hosted session at:
http://ads.sourceforge.net/cgi-bin/redirect.pl?micr0003en
Geoserver-devel mailing list
