[Geoserver-devel] Getting NPE at FileSystemWatcher
Today I started to get a cyclic error (doesn’t stop to show all the time) log running Geoserver master from web app module:
15 Nov 09:04:04 WARN [platform.resource] - Error polling contents of /home/fernando/Documents/geosolutions/geoserver/src/web/app/src/main/webapp/data/gwc-layers
java.lang.NullPointerException
at java.base/java.util.Objects.requireNonNull(Objects.java:221)
at org.geoserver.platform.resource.FileSystemWatcher$Watch.pollDirectory(FileSystemWatcher.java:213)
at org.geoserver.platform.resource.FileSystemWatcher$Watch.changed(FileSystemWatcher.java:209)
at org.geoserver.platform.resource.FileSystemWatcher$1.run(FileSystemWatcher.java:349)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:834)
Any hint about what could be the root cause for this?
Thanks.
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
A recent change to file system watcher was Performed by Gabriel.
Jody Garnett
Damn, please feel free to revert https://github.com/geoserver/geoserver/pull/3860 and I’ll get back to it first thing Monday. Unfortunately I’m on a family trip right now and can’t take care of it before Monday.
Gabriel.
El vie., 15 de noviembre de 2019 1:07 p. m., Jody Garnett <jody.garnett@anonymised.com> escribió:
On Fri, Nov 15, 2019 at 6:24 AM fernando.mino@anonymised.com <fernando.mino@…1268…> wrote:
Thanks.
Fernando Mino
Fernando Mino
Software Engineer
Geoserver-devel mailing list
Jody Garnett
Hi Gabriel,
ok, scheduling reverts
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thinking about it, it’s pretty obvious it reached a state not contemplated on any test case: that at the time of starting to watch the directory, it doesn’t yet exist.
It’s gonna be an easy fix, sorry for the trouble.
El sáb., 16 de noviembre de 2019 11:25 a. m., Andrea Aime <andrea.aime@anonymised.com> escribió:
Hi Gabriel,
On Sat, Nov 16, 2019 at 3:08 PM Gabriel Roldan <gabriel.roldan@anonymised.com> wrote:
Gabriel.
On Fri, Nov 15, 2019 at 6:24 AM fernando.mino@anonymised.com <fernando.mino@anonymised.com> wrote:
Thanks.
Fernando Mino
Fernando Mino
Software Engineer
Jody Garnett
Thought the same, but have no time to look into it, trying to get some other PRs merged and backported, maven and java 11 are not collaborating…
Will merge the reverts in the meantime
