[Geoserver-devel] Getting shapefile
Hello,
Well, I just got started with GT2 and GeoServer. I having some dauts
concerning the link between SHP registers and DBF registers.
Using the geotools classes, and reading the shapefile ESRI doc I undestood
that the registers in SHP and DBF are in a one-to-one relationship (and in
the same order). Is that right?
If so, that source bellow should be all right bringing attributes plus geo
info, right?
      FileChannel in = new FileInputStream(url+"Spst.shp").getChannel();
      ShapefileReader r = new ShapefileReader( in );
      org.geotools.data.shapefile.shp.ShapefileHeader sh = r.getHeader();
      System.out.println(sh.toString()+" magic:"+sh.MAGIC);
      FileChannel in2 = new FileInputStream(url+"Spst.dbf").getChannel();
      DbaseFileReader r2 = new DbaseFileReader( in2 );
      DbaseFileHeader d = r2.getHeader();
      System.out.println(d.toString());
      Object fields = new Object[d.getNumFields()];
      while (r2.hasNext()) {
        MultiLineString mls = (MultiLineString)r.nextRecord().shape();
         r2.readEntry(fields);
         System.out.print("\n"+mls.toText());
         for(int i=0;i<r2.getHeader().getNumFields();i++){}
           System.out.print(" "+fields[i].toString()+" ");
      r.close();
Calegari
Aurélio Calegari wrote:
Hello,
Yes, by shapefile format definition.
info, right?
      r.close();
It seems ok to me. But I don't understand why you don't simply get a feature reader
from the ShapefileDataStore and get features one by one (or get the FeatureSource
from the DataStore and perform a query, if you want less attributes, or want
to specify a selection predicate).
Best regards
Andrea Aime
Hi Andrea,
feature reader
FeatureSource
want
Is that what you mean? It's really much better!
      ShapefileDataSource data = new ShapefileDataSource((new
File(url+"Spst.shp").toURL()));
      FeatureCollection fc = data.getFeatures();
      FeatureIterator fi = fc.features();
      while(fi.hasNext()){
        Feature f = fi.next();
        System.out.println("> "+f.toString());
What's more, would you know where I could find some examples on how to
correctly use Filters and Queries to narrow the search?
Thanks once more!
Best regards,
Aurelio
----- Original Message -----
To: "Aurélio Calegari" <aurelio@anonymised.com>
Cc: "geosrvd" <geoserver-devel@lists.sourceforge.net>
Sent: Wednesday, January 21, 2004 12:34 PM
Subject: Re: [Geoserver-devel] Getting shapefile
> Hello,
undestood
in
geo
> info, right?
r.getHeader();
> r.close();
feature reader
FeatureSource
want
Best regards
Andrea Aime
Hey Aurelio!
Glad you are enjoying yourself. There are some DataStore tutorials on the main Geotools2 website that you could look at.
I would point you to them but they are out of date! (Ping James can we update this?)
You can also use FeatureReader to do the work: you can then work with shapefiles that are bigger then you can fit into memory. In you example
you used a FeatureCollection which loads everything into memory before you can use it.
ShapefileDataStore data = new ShapefileDataStore((new
Query query = new DefaultQuery( "Spst", Filter.NONE );
FeatureReader reader = data.getFeatureReader( query, Transaction.AUTO_COMMIT );
try {
   while( reader.hasNext() ){
       Feature feature = reader.next();
       System.out.println( "> "+reader );
finally {
   reader.close();
I did not need to call feature.toString() as the + opperator does that by default.
I am afraid someone else will have to help you with constructing filters, there are a few examples in the DataStore tutorial on the web site.
Oh I suppose I could make it clear - Query.ALL does not really work when used with DataStore.getFeatureReader - we need to know the typeName. While this seems obvious for shapefile that only handles one file, other DataStores let you work with all of the files in a directory and typeName is used to specify which file.
You can use FeatureSource and FeatureResults as you did to work around this limitation:
ShapefileDataStore data = new ShapefileDataStore((newFile(url+"Spst.shp").toURL()));
FeatureSource source = data.getFeatureSource( "Spst" );
FeatureResults results = source.getFeatures( Query.ALL );
FeatureReader reader = results.reader();
try {
finally {
   reader.close();
You can perform other interesting Queries with results such as results.getBounds() and results.getCount() and results.collection() to arrive at the FeatureCollection you used in your example (in case you want everything in memory for speed).
Jody
Thanks once more!
Best regards,
Aurelio
Hello,
undestood
in
geo
info, right?
r.getHeader();
     r.close();
feature reader
FeatureSource
want
Best regards
Andrea Aime
The SF.Net email is sponsored by EclipseCon 2004
Premiere Conference on Open Tools Development and Integration
See the breadth of Eclipse activity. February 3-5 in Anaheim, CA.
OCX 2024
Geoserver-devel mailing list
Thanks a lot Jody!
I'll keep working on it and your help was quite important for the process of understanding it all! :wink:
Best Regards,
Aurelio
Cc: "Andrea Aime" <andrea.aime@anonymised.com>; "geosrvd" <geoserver-devel@lists.sourceforge.net>; "James Macgill"
<jmacgill@anonymised.com>; "geotools-devel" <geotools-devel@lists.sourceforge.net>
Sent: Wednesday, January 21, 2004 1:17 PM
Hey Aurelio!
update this?)
you can use it.
>try {
>finally {
> reader.close();
by default.
this limitation:
>try {
>finally {
> reader.close();
Jody
>Thanks once more!
>Best regards,
>Aurelio
>From: "Andrea Aime" <andrea.aime@anonymised.com>
>>>Hello,
>undestood
>in
>geo
>>>info, right?
>r.getHeader();
>>> r.close();
>feature reader
>FeatureSource
>want
>>Best regards
>>Andrea Aime
>http://www.eclipsecon.org/osdn
>_______________________________________________
>https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Hi Judy,
I got an error trying to execute your exaples... Suppose the following code:
  static final String url = "D:\\Tomcat4.1\\webapps\\geoserver\\data\\featureTypes\\Spst\\";
  public static void main(String args) {
    try{
      FeatureReader reader = data.getFeatureReader( query, Transaction.AUTO_COMMIT ); // <--Line 36 (Exception is thrown here)
      try {
      finally {
          reader.close();
    }catch(Exception e){e.printStackTrace();}
Threw the following exception:
java.lang.NoSuchMethodError: org.geotools.feature.DefaultFeatureTypeFactory.getDefaultGeometry()Lorg/geotools/feature/AttributeType;
at org.geotools.feature.DefaultFeatureTypeFactory.createAbstractType(DefaultFeatureTypeFactory.java:85)
at org.geotools.feature.DefaultFeatureTypeFactory.createFeatureType(DefaultFeatureTypeFactory.java:48)
at org.geotools.feature.FeatureTypeFactory.getFeatureType(FeatureTypeFactory.java:621)
at org.geotools.feature.FeatureTypeFactory.newFeatureType(FeatureTypeFactory.java:163)
at org.geotools.feature.FeatureTypeFactory.newFeatureType(FeatureTypeFactory.java:185)
at org.geotools.feature.FeatureTypeFactory.getBuiltinTypes(FeatureTypeFactory.java:700)
at org.geotools.feature.FeatureTypeFactory.getSuperTypes(FeatureTypeFactory.java:303)
at org.geotools.feature.DefaultFeatureTypeFactory.createFeatureType(DefaultFeatureTypeFactory.java:51)
at org.geotools.feature.FeatureTypeFactory.newFeatureType(FeatureTypeFactory.java:226)
at org.geotools.data.shapefile.ShapefileDataStore.getSchema(ShapefileDataStore.java:278)
at org.geotools.data.AbstractDataStore.getFeatureReader(AbstractDataStore.java:305)
at calegari.util.SHPMapMan.main(SHPMapMan.java:36)
I downloaded I the sources from the CVS once the class ShapefileDataStore and others weren't in the "regular" file download.
Aurelio
Hey Aurelio!
update this?)
you can use it.
>try {
>finally {
> reader.close();
by default.
this limitation:
>try {
>finally {
> reader.close();
Jody
>Thanks once more!
>Best regards,
>Aurelio
>>>Hello,
>undestood
>in
>geo
>>>info, right?
>r.getHeader();
>>> r.close();
>feature reader
>FeatureSource
>want
>>Best regards
>>Andrea Aime
When using webapps it if very bad form to use constsnts like this {{static final String url = "D:\\Tomcat4.1\\webapps\\geoserver\\data\\featureTypes\\Spst\\";}}. Rather you should use the webcontainer and get a relative path. Check Geoserver for examples of how to get the webcontainer path {{org.vfny.geoserver.requests.Request, line 193-5}}.
    public String getRootDir(){
        return httpServletRequest.getSession().getServletContext().getRealPath("/");
David
Hi Judy,
   try{
Oh dear it seems you are in Version hell:
If you were working against the geoserver distribution (this conversation started out on the geoserver list) you would need to include the shapefile-SNAPSHOT.jar as well as geotools2.
I could not tell from you email if you had tried this against the current HEAD of geotools2? Or what the regular file down load was?
Jody
Geotools-devel mailing list
Geotools-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-devel
At 08:17 AM 1/21/2004 -0800, Jody Garnett wrote:
Hey Aurelio!
Done, you can find the links to them at the bottom right corner of the main geotools site:
http://www.geotools.org
Sorry for the delay in getting this done!
James
