[Geoserver-devel] Getting started
Hi everybody,
as you may imagine I'm trying to experiment a bit with Geoserver.
Now, I've checked out the cvs, and built the war, following
the instructions in the install guide. But I'm getting into trouble.
First, the test connecting to:
http://SERVER_ADDRESS:SERVER_PORT/geoserver/GetCapabilities
doesn't work because the servlet is now mapped to wfs/GetCapabilities.
Ok, got that from the web.xml file. But when I try to connect to the
proper address, I get the following exception:
javax.servlet.ServletException: Error instantiating servlet class org.vfny.geoserver.servlets.wfs.Capabilities
  at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:901)
  at org.apache.catalina.core.StandardWrapper.allocate(StandardWrapper.java:658)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:214)
  at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643)
  at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480)
  at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2396)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:180)
  at org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.java:170)
  at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:641)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:172)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:174)
  at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:223)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:405)
  at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:380)
  at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:508)
  at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:533)
  at java.lang.Thread.run(Thread.java:534)
root cause
java.lang.ExceptionInInitializerError
  at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
  at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
  at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
  at java.lang.reflect.Constructor.newInstance(Constructor.java:274)
  at java.lang.Class.newInstance0(Class.java:308)
  at java.lang.Class.newInstance(Class.java:261)
  at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:892)
Caused by: java.lang.IllegalStateException: The server configuration has not been loaded yet
  at org.vfny.geoserver.config.ServerConfig.getInstance(ServerConfig.java:190)
  at org.vfny.geoserver.servlets.AbstractService.(AbstractService.java:82)
  ... 35 more
Eclipse tells me that the only point in which the ServerConfig.load(String) is called
is during the initialization of FreefsLog... ok, let's invoke that servlet and I get the following (and this one is really fun):
javax.servlet.ServletException: Servlet.init() for servlet FreefsLog threw exception
  at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:952)
root cause
java.lang.VerifyError: Cannot inherit from final class
  at java.lang.ClassLoader.defineClass0(Native Method)
  at java.lang.ClassLoader.defineClass(ClassLoader.java:537)
  at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:123)
  at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:1664)
  at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:953)
  at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1394)
  at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1274)
  at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302)
  at org.apache.xerces.impl.XMLNSDocumentScannerImpl.createContentDispatcher(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.(XMLDocumentFragmentScannerImpl.java:248)
  at org.apache.xerces.impl.XMLDocumentScannerImpl.(XMLDocumentScannerImpl.java:245)
  at org.apache.xerces.impl.XMLNSDocumentScannerImpl.(Unknown Source)
  at org.apache.xerces.parsers.IntegratedParserConfiguration.createDocumentScanner(Unknown Source)
  at org.apache.xerces.parsers.DTDConfiguration.(DTDConfiguration.java:366)
  at org.apache.xerces.parsers.StandardParserConfiguration.(StandardParserConfiguration.java:197)
  at org.apache.xerces.parsers.IntegratedParserConfiguration.(Unknown Source)
  at org.apache.xerces.parsers.XML11Configuration.(Unknown Source)
  at org.apache.xerces.util.ObjectFactory.newInstance(ObjectFactory.java:293)
  at org.apache.xerces.util.ObjectFactory.createObject(ObjectFactory.java:224)
  at org.apache.xerces.util.ObjectFactory.createObject(ObjectFactory.java:119)
  at org.apache.xerces.parsers.DOMParser.(DOMParser.java:153)
  at org.apache.xerces.parsers.DOMParser.(DOMParser.java:137)
  at org.apache.xerces.jaxp.DocumentBuilderImpl.(DocumentBuilderImpl.java:102)
  at org.apache.xerces.jaxp.DocumentBuilderFactoryImpl.newDocumentBuilder(DocumentBuilderFactoryImpl.java:88)
  at org.vfny.geoserver.config.ServerConfig.loadConfig(ServerConfig.java:228)
  at org.vfny.geoserver.config.ServerConfig.(ServerConfig.java:76)
  at org.vfny.geoserver.config.ServerConfig.load(ServerConfig.java:205)
  at org.vfny.geoserver.servlets.FreefsLog.init(FreefsLog.java:64)
  at javax.servlet.GenericServlet.init(GenericServlet.java:256)
  at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:924)
So I wonder... what now?
Best regards
Andrea Aime
Andrea Aime wrote:
Hi everybody,
I forgot to tell you that I'm working on Windows2000 with Tomcat 4.1.12
and jdk 1.4.2_01.
Best regards
Andrea Aime
Andrea Aime wrote:
Hi everybody,
Out of trouble finally. It seems there's a clash between the xerces
version distributed with geoserver and some other one, maybe the
one in tomcat, maybe the one in the jdk. I've removed xercesImpl.jar,
xalan.jar and xml-api.jar from the geoserver.war file and now it works
fine :slight_smile:
Best regards
Andrea Aime
