[Geoserver-devel] Getting Store source files from a FeatureTypeInfo(Impl)?
I'm trying to extend Daniele's work on DirectDownload to handle non-Coverage
cases. I understand that this isn't going to work for every case (e.g. if it
is a database Store), but the case I'm interested in should be a file.
The web part seems OK, and I'm up to the part where I need to handle building
the download links in the metadata customizer.
So I'm trying to create an equivalent to the linksFromCoverage() method:
https://github.com/geoserver/geoserver/blob/master/src/extension/csw/core/src/main/java/org/geoserver/csw/DownloadLinkHandler.java#L240
that takes a FeatureTypeInfo.
I've tries a couple of things with getting the connection parameters, and with
getting a DataAccess, but I'm not really any closer to finding a way to get the
files that the underlying DataStore is using.
Can anyone suggest how to get the applicable file(s) (e.g. each file in a
shapefile set) without special-casing each data store type (e.g. a case for
ShapefileDataStore, DirectoryDataStore, etc)?
I see the use of ResourceInfo -> FileResourceInfo in the coverage case, but I
don't see how to get something like that from the FeatureTypeInfo.
Brad
non-Coverage
it
building
with
get the
but I
Hi Brad,
the plan for vector data was to get the FeatureSource, call getInfo() and
see if the returned ResourceInfo is a FileResourceInfo.
File based stores may return one, database backed ones won't
Hope this helps
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Oh, one more thing, while for shapefiles and directories of shapefiles using the featuresource is probably
the right way to go, for geopackage I guess we should check the DataAccess ServiceInfo instead, and see if
it’s a FileServiceInfo instead.
So two checks to do I assume, first see if there is anything layer specific in the feature source, and if not,
maybe provide the download link to the entire store… hum… not entirely sure about this one though… what
if the store contains some open and some restricted layer… this poses security questions, not so straighforward
I’m afraid…
On Sat, Nov 7, 2015 at 11:53 AM, Andrea Aime <andrea.aime@anonymised.com268…> wrote:
I’m trying to extend Daniele’s work on DirectDownload to handle non-Coverage
cases. I understand that this isn’t going to work for every case (e.g. if it
is a database Store), but the case I’m interested in should be a file.
The web part seems OK, and I’m up to the part where I need to handle building
So I’m trying to create an equivalent to the linksFromCoverage() method:
I’ve tries a couple of things with getting the connection parameters, and with
getting a DataAccess, but I’m not really any closer to finding a way to get the
I see the use of ResourceInfo → FileResourceInfo in the coverage case, but I
don’t see how to get something like that from the FeatureTypeInfo.
Hi Brad,
File based stores may return one, database backed ones won’t
Hope this helps
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
it's a FileServiceInfo instead.
OK. I've only just started down this path, and this definitely helps.
maybe provide the download link to the entire store... hum... not entirely
sure about this one though... what
if the store contains some open and some restricted layer... this poses
I'm afraid...
We already have this issue with netcdf (for example) coverage DirectDownload,
where you might be exposing only some layers.
Brad
specific
entirely
> I'm afraid...
DirectDownload,
Indeed... we should at least document the potential issue
Ing. Andrea Aime
@geowolf
Technical Lead
On Sun, 8 Nov 2015 10:36:08 AM Andrea Aime wrote:
On Sat, Nov 7, 2015 at 10:59 PM, Brad Hards <bradh@anonymised.com> wrote: what
> DirectDownload,
Do you think something like the following is enough?
+.. note:: Enabling DirectDownload for a layer will allow download of the underlying file(s) that
+are used in the data store, even if part of the data store information would otherwise be protected
+by access controls.
If so, I'll make it into a pull request.
Brad
Could it be better to emphasize the security risk a bit by saying "Do not enable direct download if underlying files ..." and suggest a workaround like to split the file based datastore into public and protected ones before publishing and list store types which are affected?
-Jukka Rahkonen-
________________________________________
> DirectDownload,
Brad
Geoserver-devel mailing list
On Sun, 8 Nov 2015 10:20:37 AM Rahkonen Jukka wrote:
Extended words:
underlying file(s) that are used in the data store, even if part of the data
store information would otherwise be protected by access controls. Do not
enable DirectDownload if you are trying to limit access to part or all of the
data in the supporting data store. Consider separating mosaic'd and other
composite stores into public and protected sets where this is appropriate, and
selectively enabling the DirectDownload option.
I'm reluctant to suggest store types, because its inherently extensible, and
there are already a lot of ways to compose stores.
Brad
