[Geoserver-devel] GIFMapProducerTest Failing
GIFMapProducer test seems to be consistently failing on trunk. The test is failing on my machine and on our build server so I think its legit. Plus there were some recent changes made to the GIFMapProducer to get trunk to compile against gt trunk.
Alessio, could this be something that we missed?
-JD
Justin Deoliveira
jdeolive@anonymised.com
The Open Planning Project
http://topp.openplans.org
Hi Justin,
I will check asap.
On 2/3/07, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-JD
Justin Deoliveira
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Justin,
I just tryied to recompile geoserver trunk from scratch after a fresh checkout and all went well, tests too … I would ask if you have JAI and ImageIO correctly installed on your JVM. Can also you send me the report of the test failure?
On 2/3/07, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi Justin,
I will check asap.
On 2/3/07, Justin Deoliveira <jdeolive@anonymised.com > wrote:
-JD
Justin Deoliveira
Hi Alessio,
I do have the jai libraries installed. JAI 1.1.3 and Image IO 1.0_01. I have attached the surefire report.
-Justin
Alessio Fabiani wrote:
Justin,
I just tryied to recompile geoserver trunk from scratch after a fresh checkout and all went well, tests too ... I would ask if you have JAI and ImageIO correctly installed on your JVM. Can also you send me the report of the test failure?
On 2/3/07, *Alessio Fabiani* <alessio.fabiani@anonymised.com <mailto:alessio.fabiani@anonymised.com>> wrote:
    Hi Justin,
    I will check asap.
         On 2/3/07, *Justin Deoliveira* <jdeolive@anonymised.com
    <mailto:jdeolive@anonymised.com>> wrote:
        The test
        legit.
        to get
        -JD
        Justin Deoliveira
        jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
        http://topp.openplans.org/&gt;
    http://www.geo-solutions.it/&gt;
--------------------------------------------------------- !DSPAM:1004,45c50865227014750375898!
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Justin Deoliveira
(attachments)
org.vfny.geoserver.wms.responses.map.GIFMapProducerTest.txt (7.64 KB)
Justin,
I’m not able to reproduce the problem.
Actually I have:
1 - purged my maven geotools repository
2 - updated geotools trunk
3 - made a fresh checkout and update of geoserver trunk
Compiling GeoServer, the tests are all succesfully passed on my side.
On 2/4/07, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Alessio,
-Justin
Justin,
mailto:[alessio.fabiani@anonymised.com](mailto:alessio.fabiani@anonymised.com)> wrote:
Hi Justin,
I will check asap.
On 2/3/07, Justin Deoliveira < jdeolive@anonymised.com
mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)> wrote:
The test
legit.
to get
-JD
Justin Deoliveira
jdeolive@anonymised.com mailto:[jdeolive@anonymised.com](mailto:jdeolive@anonymised.com)
http://topp.openplans.org <http://topp.openplans.org/>
http://www.geo-solutions.it <http://www.geo-solutions.it/ >
http://www.geo-solutions.it <http://www.geo-solutions.it>
Justin Deoliveira
Test set: org.vfny.geoserver.wms.responses.map.GIFMapProducerTest
Tests run: 3, Failures: 3, Errors: 0, Skipped: 0, Time elapsed: 0.431 sec <<< FAILURE!
testSimpleGetMapQuery(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest) Time elapsed: 0.133 sec <<< FAILURE!
junit.framework.AssertionFailedError
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.Assert.assertTrue(Assert.java:20)
at junit.framework.Assert.assertNotNull(Assert.java :220)
at junit.framework.Assert.assertNotNull(Assert.java:213)
at org.vfny.geoserver.wms.responses.map.GIFMapProducerTest.assertNotBlank(GIFMapProducerTest.java:66)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest.testSimpleGetMapQuery (DefaultRasterMapProducerTest.java:115)
at sun.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java :127)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at sun.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
at java.lang.reflect.Method.invoke (Method.java:324)
at org.apache.maven.surefire.junit.JUnitTestSet.execute(JUnitTestSet.java:210)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java :135)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute(AbstractDirectoryTestSuite.java:122)
at org.apache.maven.surefire.Surefire.run(Surefire.java:129)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:225)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:747)
testDefaultStyle(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest) Time elapsed: 0.056 sec <<< FAILURE!
at junit.framework.Assert.assertNotNull(Assert.java:220)
at org.vfny.geoserver.wms.responses.map.GIFMapProducerTest.assertNotBlank (GIFMapProducerTest.java:66)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest.testDefaultStyle(DefaultRasterMapProducerTest.java:227)
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest.testDefaultStyle (DefaultRasterMapProducerTest.java:131)
testBlueLake(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest) Time elapsed: 0.236 sec <<< FAILURE!
at org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest.testBlueLake(DefaultRasterMapProducerTest.java:176)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestSuite.runTest (TestSuite.java:208)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java :39)
at org.apache.maven.surefire.junit.JUnitTestSet.execute (JUnitTestSet.java:210)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.executeTestSet(AbstractDirectoryTestSuite.java:135)
at org.apache.maven.surefire.suite.AbstractDirectoryTestSuite.execute (AbstractDirectoryTestSuite.java:122)
at sun.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:39)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess (SurefireBooter.java:225)
Hi Alessio,
Thanks for taking the time to look into this. This is an odd one for sure, especially since I can replicate it my local machine, and on the build server. The common link between those two is they run linux. What platform are you running on? Also what jdk are you using? Thanks.
-Justin
Justin,
I'm not able to reproduce the problem.
Actually I have:
On 2/4/07, *Justin Deoliveira* <jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
    Hi Alessio,
    -Justin
     > Justin,
     > I just tryied to recompile geoserver trunk from scratch after a fresh
     > checkout and all went well, tests too ... I would ask if you have
    JAI
     > and ImageIO correctly installed on your JVM. Can also you send me the
     > report of the test failure?
     > On 2/3/07, *Alessio Fabiani* <alessio.fabiani@anonymised.com
     > <mailto:alessio.fabiani@anonymised.com
    <mailto:alessio.fabiani@anonymised.com>>> wrote:
     > Hi Justin,
     > I will check asap.
     > On 2/3/07, *Justin Deoliveira* < jdeolive@anonymised.com
     > <mailto:jdeolive@anonymised.com
    <mailto:jdeolive@anonymised.com>>> wrote:
     > Hi all,
     > GIFMapProducer test seems to be consistently failing on
    trunk.
     > The test
     > is failing on my machine and on our build server so I
    think its
     > legit.
     > Plus there were some recent changes made to the
    GIFMapProducer
     > to get
     > trunk to compile against gt trunk.
     > Alessio, could this be something that we missed?
     > Thanks,
     > -JD
     > Justin Deoliveira
     > jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
     > The Open Planning Project
     > http://topp.openplans.org/&gt;
     > Eng. Alessio Fabiani
     > Vice President/CTO GeoSolutions
     > http://www.geo-solutions.it/
    <http://www.geo-solutions.it/&gt;&gt;
     > Using Tomcat but need to do more? Need to support web services,
    security?
     > Get stuff done quickly with pre-integrated technology to make
    your job easier.
     > Download IBM WebSphere Application Server v.1.0.1 based on Apache
    Geronimo
    <http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642&gt;
     > !DSPAM:1004,45c50865227014750375898!
     > Geoserver-devel mailing list
     > Geoserver-devel@lists.sourceforge.net
    <mailto:Geoserver-devel@lists.sourceforge.net>
     > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
    <https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;
    Justin Deoliveira
           at
           at
           at
           at
           at
           at
           at
    :135)
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
    :135)
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
    :39)
           at
           at
           at
           at
           at
           at
--------------------------------------------------------- !DSPAM:1004,45c70565109047785049143!
Justin Deoliveira
Justin,
I am also on linux. I can probably test that for you.
Alex
On 2/5/07, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Alessio,
-Justin
> Justin,
> Actually I have:
> Hi Alessio,
> Thanks,
> -Justin
> > Justin,
> JAI
> > Hi Justin,
> > I will check asap.
> > Hi all,
> trunk.
> > The test
> think its
> > legit.
> GIFMapProducer
> > to get
> > Thanks,
> > -JD
> > Justin Deoliveira
> security?
> your job easier.
> Geronimo
> > _______________________________________________
> Justin Deoliveira
> at
> at
> at
> at
> at
> at
> at
> :135)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> :135)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> :39)
> at
> at
> at
> at
> at
> at
Justin Deoliveira
Sweet. That would be great to see if you can replicate the problem.
Thanks Alex,
-Justin
Alexander Petkov wrote:
Justin,
Alex
Hi Alessio,
-Justin
Justin,
Actually I have:
    Hi Alessio,
    -Justin
     > Justin,
    JAI
     > Hi Justin,
     > Hi all,
    trunk.
     > The test
    think its
     > legit.
    GIFMapProducer
     > to get
     > Thanks,
     > -JD
     > Justin Deoliveira
    security?
    your job easier.
    Geronimo
    Justin Deoliveira
           at
           at
           at
           at
           at
           at
           at
    :135)
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
    :135)
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
    :39)
           at
           at
           at
           at
           at
           at
Justin Deoliveira
!DSPAM:1004,45c76c90170374750375898!
Justin Deoliveira
Hello Justin and Alessio:
I did svn updates on geotolls trunk and geoserver trunk. I built
geoserver trunk on my linux workstation and all tests passed
successfully.
Alex
Thanks Alex,
-Justin
> Justin,
> Alex
>> Hi Alessio,
>> -Justin
>>> Justin,
>>> Actually I have:
>>> Hi Alessio,
>>> Thanks,
>>> -Justin
>>> > Justin,
>>> JAI
>>> > Hi Justin,
>>> > I will check asap.
>>> > Hi all,
>>> trunk.
>>> > The test
>>> think its
>>> > legit.
>>> GIFMapProducer
>>> > to get
>>> > Thanks,
>>> > -JD
>>> > Justin Deoliveira
>>> security?
>>> your job easier.
>>> Geronimo
>>> Justin Deoliveira
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> :135)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> :135)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> :39)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>> Justin Deoliveira
Justin Deoliveira
Hmmm... the plot thickens :). Alex, can I ask which distro you are using? Also, which jdk in particular?
-Justin
successfully.
Alex
Thanks Alex,
-Justin
Justin,
Alex
Hi Alessio,
-Justin
Justin,
Actually I have:
    Hi Alessio,
    -Justin
     > Justin,
    JAI
     > Hi Justin,
     > Hi all,
    trunk.
     > The test
    think its
     > legit.
    GIFMapProducer
     > to get
     > Thanks,
     > -JD
     > Justin Deoliveira
    security?
    your job easier.
    Geronimo
    Justin Deoliveira
           at
           at
           at
           at
           at
           at
           at
    :135)
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
    :135)
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
    :39)
           at
           at
           at
           at
           at
           at
Justin Deoliveira
Justin Deoliveira
!DSPAM:1004,45c78786204998365517736!
Justin Deoliveira
Arch Linux (shameless plug for archlinux.org, hehe)
j2sdk1.4.2_13 with ImageIO 1.1 and JAI 1.1.3
Alex
Justin,
I think that the problem really could be on your installed JAI and ImageIO distribution … from a relase to another of those libraries, sometimes there are a lot of improvements and bug-fixes.
On 2/5/07, Alexander Petkov <greenkov@anonymised.com> wrote:
On 2/5/07, Justin Deoliveira <jdeolive@anonymised.com > wrote:
Hmmm… the plot thickens :).
Alex
Hmm, I am using the exact same jdk, jai, imageio versions. I will have to look a little deeper into this one.
Justin,
I think that the problem really could be on your installed JAI and ImageIO distribution ... from a relase to another of those libraries, sometimes there are a lot of improvements and bug-fixes.
On 2/5/07, *Alexander Petkov* <greenkov@anonymised.com <mailto:greenkov@anonymised.com>> wrote:
     > Hmmm... the plot thickens :).
     >Alex, can I ask which distro you are using?
    Arch Linux (shameless plug for archlinux.org <http://archlinux.org>,
    hehe)
     >Also, which jdk in particular?
    Alex
--------------------------------------------------------- !DSPAM:1004,45c78ce5210871804284693!
Justin Deoliveira
You are indeed right Alessio!! I was running an old version of the image i/o plugin. Upgrading to 1.1 does the trick. Thanks for working through this with me!!
-Justin
Justin,
    hehe)
    Alex
Justin Deoliveira
