Apparently I need commit access to the GeoServer git repository to do the release this month, I can’t find an equivalent to https://github.com/organizations/geotools/teams for GeoServer to see if my old SVN access got moved over.
Since I’m at work just now (and thus don’t have git with out a lot of contortions with the firewall) is there any way to check?
Ian
Ian Turton
On 9 July 2013 09:32, Frank Gasdorf <frank.gasdorf@anonymised.com> wrote:
Try to edit a resource using the github Web-UI (e.g.
https://github.com/geoserver/geoserver/edit/master/.gitignore) I guess If
you haven't credentials yet you would get an Error hitting the "Edit"
button. Try to login first otherwise github shows http 404 page.
Thanks Frank - I'd forgotten I could try to use the web. It seems I don't
have git access. Can someone add me?
cheers
Ian
good luck
- Frank
2013/7/9 Ian Turton <ijturton@anonymised.com>
release this month, I can't find an equivalent to
Since I'm at work just now (and thus don't have git with out a lot of
Ian
Ian Turton
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Ian Turton
Ian,
I have added you to the GeoServer team on github.
AFAICT, you need to be a member of the team to see who is a member, so if you cannot see the page, you are not.
Kind regards,
Ben.
the release this month, I can't find an equivalent to
Ian
Ian Turton
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
On 9 July 2013 09:43, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>wrote:
Ian,
That would explain why I couldn't
Ian
