[Geoserver-devel] gitattribute and fixing newline chars
following the last PSC meeting, and after attempting to use spotless,
I’ve realized we have a mix of line endings in our git checkouts, mostly
due to people forgetting to set the autocrlf setting in git.
This pull request tries to fix them, and adds a .gitattributes file that should
avoid having funny line endings in the repo, in the future.
https://github.com/geotools/geotools/pull/3702
Feedback I’m looking for:
  • Are people ok with this?
  • Can anyone on windows/osx try it out and see if anything strange happens? (I believe after checkout it out, a “git reset --hard” will be needed to fix files newlines
    If I don’t get negative feedback, I plan to apply the PR to GeoTools and the backport on the stable and maintenance branches, and then apply the same process to GWC and GS as well.
I’ll do it over the Christmas break, hopefully less people are making changes that could be affected by the PRs then.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
+1
Ian
Ian Turton
I am very much in favour of this, will report back after testing.
Jody Garnett
Hi Jody,
the PR is ready for merge, can you give it a spin?
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
