It would be super nice if geoserver had a global time zone setting
that could be applied to all datastores (part 2 of this conversation -
implementing a time zone parameter in geotools datastores and choosing
reasonable defaults).
The idea would be that the default would be UTC - after all, if you
have data that may originate in one timezone and clients in others,
the only sane way to handle data externally (and therefore internally)
is UTC (like how WMS getcaps does it). I cannot find any arguments for
non UTC behavior, so someone speak up. I don't understand all of the
implications regarding other aspects of geoserver (so please chime
in), but the WMS time functionality has some problems.
There are several places where this shows up as a problem in the
current geoserver/geotools:
1) Date fields read from shapefile datastores are interpreted using
local time zone (unless one is specified and there is no UI for this
yet) except due to https://jira.codehaus.org/browse/GEOS-4801, they
are actually not at some point (making things really confusing)
2) timestamp database types without timezone are interpreted using
local time zone. Though this could be seen as a data integrity issue,
the current datatype selected when transforming a featuretype using
geotools is timestamp without timezone (at least for postgis).
3) the WMS getcaps DimensionHelper correctly formats Date objects to
UTC and the getmap request correctly takes them in as UTC, but this
causes a miss when data in case 2 is present as the JDBC filter then
fails.
For the sake of sanity, coming up with some rules on how to handle
user dates and timestamps would benefit many, I'm guessing. Assuming
we stick with an internal representation of Date (which actually
implies UTC), my thoughts:
1) Global default timezone is UTC
2) All user data is internally represented as UTC (probably already true)
3) For non-time stamped user data (dates, timestamp w/out tz), assume
the global default timezone or allow for an override on a
store-by-store basis (for some use case I'm not aware of)
4) Server time still uses JVM default (the global default I mention is
geoserver specific)
5) Client representation is not covered here (nor by the current WMS getcaps)
I'm working on the JDBC implementation now and already submitted a
patch for GEOS-4801 (actually a geotools patch).
This problem took a long time to wrap my head around, partly because
GEOS-4801 made me go slightly crazy as I was witnessing differing
behavior, mostly because timezones suck - feedback much appreciated.
Reference Material:
Well written low-down: http://www.odi.ch/prog/design/datetime.php
Postgres : http://www.postgresql.org/docs/8.4/static/datatype-datetime.html#DATATYPE-TIMEZONES
Another : http://postgresql.1045698.n5.nabble.com/Timestamp-confusion-td2174087.html
-Ian
Ian Schneider
OpenGeo - http://opengeo.org
