[Geoserver-devel] gml 2.1.2.1 schemas in geoserver
Chris,
Re: your comment on the gml 2.1.2.1 schemas. We're using our own internal
schemas, but it'd be really cool if we didn't have to host any schemas
ourselves at all! That's why schemas.opengis.net exists...the problem was
that it was totally broken for gml 2.1.2, and only started working for gml 3
at version 3.1.something.
So now that we've got real live working gml 2.1.2 schemas, we can just
reference the ones that are live up at schemas.opengis.net.
That's my plan for the work that's going into fixing that bug.
I'm much of the way through it (it's easier to parse using tools that rely
on JAXB if the xml documents you are trying to read are actually valid) and
I'm hoping to commit the changes in the next few days.
--saul
View this message in context: http://www.nabble.com/gml-2.1.2.1-schemas-in-geoserver-tf4402643.html#a12559670
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Hold the phone there Saul :). The major problem with this is that
GeoServer might have a connection to the internet, and if that happens
everything kind of goes to hell.
Also... to be done correctly the the schemas would have to be downloaded
somewhere locally and stored in some sort of cache... so that xml
parsers do not download them every time... as it would result in
noticeable performance hit to download them every time. A couple of the
xml tests actually do that and are noticeably slower than the tests that
don't.
But yeah... i had the same idea for wfs 1.1... just reference
schemas.opengis.net...but no go.
-Justin
sfarber wrote:
Chris,
--saul
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Yeah, I'll also say that referencing the schemas.opengis.org isn't a very polite thing. We have quite a few geoservers out there, and would lead to a pretty significant load on their servers. I think they're more there to be the canonical reference.
Chris
don't.
-Justin
sfarber wrote:
Chris,
--saul
Good points, both of you!
I’ll do some weeding in our local geoserver “schema garden” (lots of older invalid stuff in there) and make sure it’s a good clean copy of the cannonical schema library at schemas.opengis.net.
Then I’ll make sure we reference our own directories, make sure that everything validates (you wouldn’t believe how hard it is to find a good command-line XMLschema validator) and commit the changes back.
Whew. This whole schema-dancing routine has been more work than I expected!
–asul
From: Chris Holmes [mailto:cholmes@anonymised.com3…]
Sent: Fri 9/7/2007 3:12 PM
To: Justin Deoliveira
Cc: sfarber; geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] gml 2.1.2.1 schemas in geoserver
Yeah, I’ll also say that referencing the schemas.opengis.org isn’t a
lead to a pretty significant load on their servers. I think they’re
Chris
Also… to be done correctly the the schemas would have to be downloaded
somewhere locally and stored in some sort of cache… so that xml
parsers do not download them every time… as it would result in
don’t.
But yeah… i had the same idea for wfs 1.1… just reference
schemas.opengis.net…but no go.
-Justin
sfarber wrote:
Chris,
Re: your comment on the gml 2.1.2.1 schemas. We’re using our own internal
schemas, but it’d be really cool if we didn’t have to host any schemas
ourselves at all! That’s why schemas.opengis.net exists…the problem was
So now that we’ve got real live working gml 2.1.2 schemas, we can just
That’s my plan for the work that’s going into fixing that bug.
I’m much of the way through it (it’s easier to parse using tools that rely
I’m hoping to commit the changes in the next few days.
–saul
We really ought to use OASIS catalogs to dereference a local cache, and then we can use schema validators on the local cache too.
Rob
I'll do some weeding in our local geoserver "schema garden" (lots of older invalid stuff in there) and make sure it's a good clean copy of the cannonical schema library at schemas.opengis.net.
Then I'll make sure we reference our own directories, make sure that everything validates (you wouldn't believe how hard it is to find a good command-line XMLschema validator) and commit the changes back.
*From:* Chris Holmes [mailto:cholmes@anonymised.com]
*Sent:* Fri 9/7/2007 3:12 PM
*To:* Justin Deoliveira
*Cc:* sfarber; geoserver-devel@lists.sourceforge.net
*Subject:* Re: [Geoserver-devel] gml 2.1.2.1 schemas in geoserver
Chris
> don't.
> -Justin
> sfarber wrote:
>> Chris,
>> --saul
Geoserver-devel mailing list
Can you code this, Rob? Or can you point me to the javadocs of a library
which implements this local caching mechanism?
I'd be happy to tie this into GeoServer, if it's the proper way to go.
--saul
Rob
expected!
--asul
Chris
downloaded
that
> don't.
> -Justin
> sfarber wrote:
>> Chris,
internal
problem was
for gml 3
that rely
valid) and
>> --saul
begin:vcard
fn:Rob Atkinson
n:Atkinson;Rob
org:Social Change Online
email;internet:rob@anonymised.com
title:Principal Consultant
tel;work:+61 2 42265490
tel;cell:0419 202 973
x-mozilla-html:TRUE
url:http://online.socialchange.net.au
version:2.1
end:vcard
View this message in context: http://www.nabble.com/gml-2.1.2.1-schemas-in-geoserver-tf4402643.html#a12563399
possibly some time in the next 6 months :slight_smile: I've a long list of higher priority fixes :frowning:
http://xml.apache.org/commons/components/apidocs/resolver/org/apache/xml/resolver/class-use/Catalog.html
I think it would need to be tied into gt-xml
Rob
--saul
Rob
Chris
downloaded
that
don't.
-Justin
sfarber wrote:
Chris,
internal
problem was
for gml 3
that rely
valid) and
--saul
begin:vcard
fn:Rob Atkinson
n:Atkinson;Rob
x-mozilla-html:TRUE
version:2.1
end:vcard
