[Geoserver-devel] gml to svg conversion
Finally I’ve obtained from geoserver the gml file.
Now I’ve to convert it to svg for furter visualization.
How can I do it? I know that, for now, geoclient works only with geoserver_lite, not with the main geoserver.
Does anyone knows how can I perform gml to svg conversion?
Another question: How can I add more layers (more postgis tables) to my file?
Thanks for help,
greetings
Alessandro
Dot. Ing.Alessandro Ceccotti, netXcalibur s.r.l.
Via Alamanni, 25
I-50123 Firenze
T: +39.055.285859 - F: +39.055.285760
Finally I've obtained from geoserver the gml file.
Now I've to convert it to svg for furter visualization.
Someone else on the list is going to have to help with that, as I know
close to nothing about gml -> svg.
file?
This one I can handle though :wink: All you need to do is add another folder
to your featureTypes directory, of the same name as the table. So if
you're adding a feature named 'subway', with the corresponding postgis
table named subway, you create a folder called subway in featureTypes, and
add an info.xml file with its information, as well as a schema.xml file
with the appropriate schema information.
  Chris
