[Geoserver-devel] gml to svg conversion
Why not include an atomatic process or web process for create featuretypes,
or another manner for take metadata from postgis databases?
----------- Mensaje Original --------------
De: Chris Holmes [cholmes@anonymised.com]
Para: Alessandro Ceccotti [alessandro.ceccotti@anonymised.com]
Cc: geoserver-devel@lists.sourceforge.net
[geoserver-devel@lists.sourceforge.net]
Asunto: Re: [Geoserver-devel] gml to svg conversion
Fecha: 07/07/2003 10:09:19
Mensaje:
          > Finally I've obtained from geoserver the gml file.
Now I've to convert it to svg for furter visualization.
How can I do it? I know that, for now, geoclient works only with
geoserver_lite, not with the main geoserver.
Does anyone knows how can I perform gml to svg conversion?
Someone else on the list is going to have to help with that, as I know
close to nothing about gml -> svg.
Another question: How can I add more layers (more postgis tables) to my
file?
This one I can handle though :wink: All you need to do is add another folder
to your featureTypes directory, of the same name as the table. So if
you're adding a feature named 'subway', with the corresponding postgis
table named subway, you create a folder called subway in featureTypes, and
add an info.xml file with its information, as well as a schema.xml file
with the appropriate schema information.
  Chris
This SF.Net email sponsored by: Free pre-built ASP.NET sites including
Data Reports, E-commerce, Portals, and Forums are available now.
Download today and enter to win an XBOX or Visual Studio .NET.
http://aspnet.click-url.com/go/psa00100006ave/direct;at.asp_061203_01/01
Geoserver-devel mailing list
Bladimir Moreno
