I have to build a Java component that will convert GML (Geography Markup Language) to WKT or WKT and vice-versa. I will have these methods:
GMLtoWKT
GMLtoWKB
WKTtoGML
WKBtoGML
GMLtoESRIShapefile
ESRIShapefiletoGML
WKTtoWKB
WKBtoWKT
That component has to be alone, a straight converter!
My component will be used in an OpenGIS Web Service standard. Do you know where I can find a Java Framework to implement my component through the Web Service?
1) I have to build a Java component that will convert GML (Geography Markup Language) to WKT or WKT and vice-versa. I will have these methods:
You could implement this as a wrapper on the existing geotool DataStore API - what is interesting is if you are using this for an OWS all your implementations will need to be stream based. This can be *very* hard with GML because GML assumes you know your bounding box *before* you write out the actual content. Hard to do if you only get one pass through the data.
2) My component will be used in an OpenGIS Web Service standard. Do you know where I can find a Java Framework to implement my component through the Web Service?
GeoServer has an Open Web Service layout, and implements WFS and WMS, you should talk to chris holmes the project leader. The application is fairly modular and would have a lot of the boiler plate code (GetCapabilities, WKT Request Parsing etc...) already done.
The Ordinance Survey get round this by using an indocument reference to a geometry which they include towards the end of the GML file. Sneaky, but apparently valid.
Now why didn't I think of that - I wonder if David would go for it
Roberto - geotools has just made a very powerful GML parser (currently supports GML 2.x because the developer David Zwiers is only interested in WFS support). It is a bit tricky extending this to GML3 support because of a lack of classes representing GML3 constructs. But it sounded like you were staying within the bounds of Shapefiles ....
Do you have specific needs with respect to versions?
At 14:06 14/10/2004 -0700, Jody Garnett wrote:
>Nice!
apparently valid.
Yes, but it binds you to in-memory only FeatureCollections if you want
to only parse the stream once ... so I didn't support it. As a side
note, I have not seen this used yet (FME and WFS both use conventional
XML).
David
James
This SF.net email is sponsored by: IT Product Guide on ITManagersJournal
Use IT products in your business? Tell us what you think of them. Give us
Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more http://productguide.itmanagersjournal.com/guidepromo.tmpl
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> >Nice!
> apparently valid.
XML).
Not sure what you mean as they did this specifically to allow for a parse once stream based approach, the bbox is built as the features stream then its stuck at the end of the GML stream. The bbox at the beginning of the stream only holds a reference to the bbox which will be generated once all of the features have been processed.
as far as I have read in this list, raster support is not yet available
in Geoserver, right?
I have also read that probably the best alternative is to use Geoserver
for the vector data together with MapServer for the raster data. Does
anybody have any experience with this configuration? Does anybody
suggest any other alternative? I would really appreciate if anybody
could give me a couple of hints about how to configure this...
Thanks!
Best regards,
Juan
P.D: By the way, do you have any idea if it is expected to be supported
in future geoserver releases?
available
Correct.
Geoserver
Personally no. If anyone does have thoughts on this though it would be
a great thing to add to the wiki for others to use: http://docs.codehaus.org/display/GEOS/Home
(yes, it's unorganized, we're working on that).
supported
Yes, it's one of the top priorities for 1.3, on which we will be
starting work shortly. There's been a good bit of work done in
GeoTools, and it's getting cleaned up now, so should be ready to roll
in relatively soon.
Chris
ITManagersJournal
Give us
