Hey Justin,
when you have a chance please take a look at the comments in <http://jira.codehaus.org/browse/GEOT-2627>, as GML3EncodingUtils.idExists() is making the gml encoding process almost twice slower and I would love you opinion on the proposed workaround
Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
Hmmm... well one possibility might be to use a similar solution as FeatureTypeCache. Each time the encoder stats, the container context gets a FeatureTypeCache instance which basically serves as a cache for feature type objects, used while parsing features to avoid creating the feature type over and over again.
A similar class could be used ot track ids during encoding. GMLConfiguration.configureContext could register it, and then whatever binding (AbstractFeatureTypeBinding or whatever) could declare a dependency on it, grab the instnace and check for or update the set with encoded ids.
The downside being that for huge feature collections the set could get quite large... but i guess its better than the current solution of building up a document full of ids.
Gabriel Roldan wrote:
Hey Justin,
Gabriel
Justin Deoliveira
That'd be a good solution to provide a context to the gml encoding process, my open question is now how to ensure that context is not shared between encoding processes, as the list of ids is to be checked independently for each one. My understanding is FeatureTypeCache is shared and that's ok, but this one may require a per process "context". What do you think?
Hey Justin,
Gabriel
Gabriel Roldan
Even though the Configuration object is a singleton in geoserver (hopefully fix that someday), the binding context is not stored as a member of it, it is created by the encoder and passed into Configuration.configureContext(). So as long as two processes are not storing the same encoder instance as state there should be no problem.
Hey Justin,
Gabriel
Justin Deoliveira
thaaat's what I call a satisfactory answer
Rini, see how FeatureTypeCache is used in WFSConfiguration.configureContext
As Justin suggested, the same way you can register a new instance of, say, IdLookUp in GMLConfiguration.configureContext and have AbstractFeatureTypeBinding take an extra constructor argument of type IdLookUp (if my understanding is correct the picocontainer will take care of passing over the constructor argument as long as it's registered by GMLConfiguration)
Then IdLookUp might be something like:
class IdLookUp{
boolean idExists(String gmlId){...}
void add(String gmlId){...}
May you have time to do that so we fix the perf penalty?
(Justin please confirm my above suggestion is correct)
Gabriel
Hey Justin,
Gabriel
Gabriel Roldan
Hi Gabriel,
Sure thing. I'll reopen the issue and assign to myself. Thank's for spotting this.
Rini
-----Original Message-----
From: Gabriel Roldan [mailto:groldan@anonymised.com]
Sent: Tuesday, 15 September 2009 11:36 AM
To: Justin Deoliveira
Cc: Geoserver-devel; Angreani, Rini (E&M, Kensington)
Subject: Re: [Geoserver-devel] GML3EncodingUtils.idExists performance impact
class IdLookUp{
Gabriel
Hey Justin,
workaround
Gabriel
Gabriel Roldan
class IdLookUp{
Sounding in just for a quick check. Is the IdLookup necessary even
for simple features? How much will it cost in terms of performance
having it always on?
I was thinking that maybe in case of simple features the need is
not there and a dummy implementation could just always return
false to idExists and avoid both the search and memory consumption
overhead?
Then again, I don't fully understand the use case. It's just that
yesterday was chatting with a user that was asking why GML3 output
was so much slower than GML2 (on 1.7.x) and this seems to make it
worse from that pov.
Andrea Aime
class IdLookUp{
Yup, that looks good.
Gabriel
Hey Justin,
Gabriel
Justin Deoliveira
class IdLookUp{
From what I have seen from the two encoding chains they are pretty integrated, would probably take a bit of work to separate them out.
overhead?
Well at some point I hope to resurrect the optimized gml encoder stuff i wrote a while back. Just lacking time as of late i guess.
Justin Deoliveira
