[Geoserver-devel] GPKG driver does not set application_id
Making GDAL more lenient feels like a good thing to do. Many developers do not like to include snapshots into packages and I can see that the latest release jar on the Xerial site is of version 3.7.2. However, for using the latest Spatialite 4.2 binaries with OpenJUMP I have needed the 3.8.2-snapshot. That speaks also for updating the sqlite driver because it would allow also updating someday the ancient Spatialite community module which is using Spatialite v. 2.4. I haven’t noticed that 3.8.5-pre1 has appeared, need to test it immediately.
-Jukka-
Justin Deoliveira
Hey Jukka,
Yeah, I filed this ticket a few weeks back.
http://jira.codehaus.org/browse/GEOT-4816
I asked Paul to approach the gdal dev list about potentially being lenient here because fixing this one is tricky on the Java side. The sqlite driver we use uses an older version of sqlite that doesn’t have the ability to set the application_id through the driver itself. So the only option for us would be to manually rewrite those bytes of the file, which while possible I feel would be error prone. Cleaner would be to upgrade the driver to include a newer sqlite version. Which looks to be coming soon as a 3.8.5 pre release version was just posted last week.
Given that the application_id seems like a relatively obscure feature and that it is pretty common to find the sqlite installations that are older than 3.7.17 it didn’t seem like an unreasonable request. Also looking at the MBTiles driver it doesn’t check the application_id while MBTIles has an assigned number.
http://www.sqlite.org/src/artifact?ci=trunk&filename=magic.txt
-Justin
On Tue, Aug 12, 2014 at 6:51 AM, Rahkonen Jukka (Tike) <jukka.rahkonen@…1245…> wrote:
For whom it may concern,
Paul Ramsey writes that Geoserver does not set application_id when it creates GeoPackages with the community module. Obviously it should.
http://news.gmane.org/gmane.comp.gis.gdal.devel
-Jukka Rahkonen-
Geoserver-devel mailing list
Justin Deoliveira
VP Engineering | Boundless
jdeolive@…3839…
@boundlessgeo
