[Geoserver-devel] grid datastore?
Thought it did exist but it looks like it doesn’t, so it might make for a nice weekend project.
I know what the gt-grid module does but never used it. Yet it’d be quite handy to be able of configuring a read only grid layer in geoserver that doesn’t take any space on disk but is computed on the fly using gt-grid? quite the same that’s done by the mini-wms embedded in the geoserver SRS List demo, but for general use (see where the map showing the area of validity for each CRS has a grid on it? [1]).
But before giving it a shot:
  • really it doesn’t exist?
  • would it be useful for others at all?
  • if so, feature requests?
[1]
<http://demo.opengeo.org/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.demo.SRSDescriptionPage&code=EPSG:3031>
<http://demo.opengeo.org/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.demo.SRSDescriptionPage&code=EPSG:3057>
<http://demo.opengeo.org/geoserver/web/?wicket:bookmarkablePage=:org.geoserver.web.demo.SRSDescriptionPage&code=EPSG:4326>
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com
@boundlessgeo
On Tue, Jun 30, 2015 at 11:21 PM, Gabriel Roldan <groldan@anonymised.com>
wrote:
Thought it did exist but it looks like it doesn't, so it might make for a
I know what the gt-grid module does but never used it. Yet it'd be quite
doesn't take any space on disk but is computed on the fly using gt-grid?
quite the same that's done by the mini-wms embedded in the geoserver SRS
- really it doesn't exist?
- would it be useful for others at all?
- if so, feature requests?
Hi Gabriel,
there is much to say on the topic, in summary, it's not as easy as it looks
(doing the store it's indeed easy, using it for grids not as easy as it
seems).
First, Ian has been looking into the subject recently, you might want to
synch up with him:
http://blog.ianturton.com/geotools/mapping/cartography/2015/06/17/fun-with-graticules.html
There is also a relevant thread on the geotools developer mailing list,
interesting stuff there too.
About the usage issues, there are a few:
   - Reprojection, right now the store generate lines made of two points,
   and our reprojection engine still reprojects point by point, without on the
   fly densification when a line is too long to be reprojected "as is". It's a
   feature that I have in my backlog, but not sure if and when it's going to
   be implemented. I think the grid module can densify, but to get good
   results one would have to densify dynamically, depending on the zoom level
   and target projection... which is a bit of trouble when you just give a
   layer for anybody to use against the 5000 projections we expose
   - Labelling, often people want the ordinate of the grid line shown at
   the map margins, which is something we cannot easily do right now, although
   it might be doable with a rendering transformation (intersect with the
   rendering bbox, pad back from the border enough, add an attribute to give
   the label vertical or horizontal orientation)
   - Multilevel grids: often the maps require grids that are multilevel,
   every 10 degrees depicted one way, and the others every one in a different
   way
Now, I believe that all of the above issues can be solved via SLD and
rendering engine improvement with some extra effort, but they are not
exactly trivial. I guess that's why people have considered doing them as
decorations instead, and/or as DirectLayer.
All in all, I'd be favorable with just creating a grid store too, that's
something I'd been quite tempted to do myself, we should just explain to
the user base what the current limitations are
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
The code I developed handles densification, and multilevel grids are the next issue I plan on looking at and then I wanted to work out how to move the labels to the edges of the screen (I hadn’t thought of transforms but that makes sense).
Then I planned to stuff everything into a direct layer and hope for the best (or ask Jody for help).
A store could work and would allow the user to specify the CRS and bounds/ levels that they wanted.
Any way I’m definitely interested in this so keep me in the loop please
cheers
Ian
On Tue, Jun 30, 2015 at 11:21 PM, Gabriel Roldan <groldan@anonymised.com…> wrote:
Hi Gabriel,
there is much to say on the topic, in summary, it’s not as easy as it looks (doing the store it’s indeed easy, using it for grids not as easy as it seems).
First, Ian has been looking into the subject recently, you might want to synch up with him:
There is also a relevant thread on the geotools developer mailing list, interesting stuff there too.
  • Reprojection, right now the store generate lines made of two points, and our reprojection engine still reprojects point by point, without on the fly densification when a line is too long to be reprojected “as is”. It’s a feature that I have in my backlog, but not sure if and when it’s going to be implemented. I think the grid module can densify, but to get good results one would have to densify dynamically, depending on the zoom level and target projection… which is a bit of trouble when you just give a layer for anybody to use against the 5000 projections we expose
  • Labelling, often people want the ordinate of the grid line shown at the map margins, which is something we cannot easily do right now, although it might be doable with a rendering transformation (intersect with the rendering bbox, pad back from the border enough, add an attribute to give the label vertical or horizontal orientation)
  • Multilevel grids: often the maps require grids that are multilevel, every 10 degrees depicted one way, and the others every one in a different way
    Now, I believe that all of the above issues can be solved via SLD and rendering engine improvement with some extra effort, but they are not exactly trivial. I guess that’s why people have considered doing them as decorations instead, and/or as DirectLayer.
All in all, I’d be favorable with just creating a grid store too, that’s something I’d been quite tempted to do myself, we should just explain to the user base what the current limitations are
Okay thanks all for the insights and interest. All good info to keep in mind.
Meanwhile, I’d like to draw your attention (esp. @aaime) to the following bug that I found while working with a grid lines shapefile: <https://osgeo-org.atlassian.net/browse/GEOT-5169>
Wasn’t sure what the best solution would be due to possible side effects, but I did write a unit test to expose the issue.
Gabriel
On Wed, Jul 1, 2015 at 7:43 AM, Ian Turton <ijturton@anonymised.com> wrote:
On Wed, Jul 1, 2015 at 9:25 AM Andrea Aime <andrea.aime@anonymised.com8…> wrote:
cheers
Ian
On Tue, Jun 30, 2015 at 11:21 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Hi Gabriel,
Gabriel Roldán
@boundlessgeo
Hi Gabriel,
off the top of my head, I don’t know what’ happening there.
I’ll be at FOSS4G europe for the next few days, can you ping me back at the end of the week if I forget about this one?
On Mon, Jul 13, 2015 at 10:32 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
Gabriel
On Wed, Jul 1, 2015 at 9:25 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
cheers
Ian
Gabriel Roldán
@boundlessgeo
Hi Gabriel,
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Gabriel,
did you by any chance move forward with the grid store/direct layer/decoration?
On Mon, Jul 13, 2015 at 10:32 PM, Gabriel Roldan <groldan@anonymised.com.> wrote:
Gabriel
cheers
Ian
Gabriel Roldán
@boundlessgeo
Hi Gabriel,
Ing. Andrea Aime
@geowolf
Technical Lead
