[Geoserver-devel] GridSet min/max published zoom levels UI issue?
I’ve noticed that when you try to select a gridset min/max published zoom level in the Tile Caching tab panel for a layer or layer group, particularly on the first row in the grid, there are some irregularities in behaviour. If you select a max value on the first row, the first attempt at selecting the value fails back to “Max” placeholder. The second attempt will work, however my experience is when you Save that configuration and then come back into that dialog, the max value that you’ve saved appears on the second or third row, not associated to the gridset you were attempting to change the value for.
Can anyone confirm this behaviour? I was looking at the nightly build of the dev branch, but I can confirm that I think it appears in the nightly stable branch as well.
I will file a bug and see if I can fix it if confirmed. Maybe this is so little used that no one has noticed before?
Thanks
Peter
