[Geoserver-devel] GS 1.7.3 custom build not working with Oracle
When trying to build GS 1.7.3 from source (to include a custom data dir) and including the Oracle JARs in the build so they are included in the resulting WAR file, GS is producing an error when trying to add an Oracle feature type. Version 2.5.4 of the Geotools JARs are being pulled in by maven and used. Does anyone know what could be causing this error (stack trace below)?
When deploying GS 1.7.3 from the pre-built JAR and then placing the Oracle JARs in the container, adding the same Oracle feature type seems to work fine. The error only seems to happen when using a custom built GS. Could there be something we are missing in the build process that is causing this error?
Here is the stack trace of the error:
    * class java.lang.IllegalStateException: No binding has been
      provided for this attribute
Details:
java.lang.IllegalStateException: No binding has been provided for this attribute
        at org.geotools.feature.AttributeTypeBuilder.buildDescriptor(AttributeTypeBuilder.java:503)
        at org.geotools.data.oracle.OracleDataStore.getSDOGeometryAttribute(OracleDataStore.java:230)
        at org.geotools.data.oracle.OracleDataStore.buildAttributeType(OracleDataStore.java:190)
        at org.geotools.data.jdbc.JDBC1DataStore.buildSchema(JDBC1DataStore.java:1204)
        at org.geotools.data.jdbc.FeatureTypeHandler.getFeatureTypeInfo(FeatureTypeHandler.java:198)
        at org.geotools.data.jdbc.FeatureTypeHandler.getSchema(FeatureTypeHandler.java:166)
        at org.geotools.data.jdbc.JDBC1DataStore.getSchema(JDBC1DataStore.java:336)
        at org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:87)
        at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
        at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
        at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
        at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
        at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
        at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
        at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
        at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
        at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
        at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
        at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:563)
        at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:394)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:263)
        at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
        at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:584)
        at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
        at java.lang.Thread.run(Thread.java:619)
Graham Davis
Refractions Research Inc.
gdavis@anonymised.com
