[Geoserver-devel] GS 2.1.0 RC1 + GWC
Hi There,
Is there any way of removing GWC from GeoServer before deployment?
I used to do this by removing the GWC*.jar files from the lib, but it seems to be a lot tighter integrated now. I have just tried this with GS 2.1.0 RC1, and funny things happen in the Geoserver admin page, like when trying to add or edit styles telling you the page has expired! When checking through the log trace then it has an issue with the missing GWC classes!!
I have no use for GWC at the present, and it’s is not very stable when scaling up, for example when running against Multiple JVMs in Oracle Application Server (In fact not stable is putting it lightly!) so the need to be able to disable / remove is a necessity.
If anyone has any help here it would be much appreciated – even if there is a flag in the web.xml where we can turn on or off.
Steve
I am not 100% sure but I think if you should remove gwc* web-gwc* and geowebcache* you should catch pretty much everything. Regardless the answer is yes, even with the tighter integration you should be able to completely diable gwc. If not it is a bug.
On Tue, Jan 25, 2011 at 8:27 AM, Steve Way <Steve.Way@anonymised.com634…> wrote:
Hi There,
Steve
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech or Mail.Admin@anonymised.com and delete the original message.
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Tue, 2011-01-25 at 20:57 +0530, Steve Way wrote:
Hi There,
shutting down tomcat once geoserver.war is deployed and deleting *gwc*
from WEB-INF/lib works for me. You probably deleted only gwc* and got
web-gwc.jar still in there?
Could you describe better the situation/problems you face? may be
there's a simple solution but I don't quite understand what's going on
from what you're saying.
Gabriel
Steve
______________________________________________________________________
DISCLAIMER:
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
Gabriel / Justin - You were right!!
I missed the web-gwc library!
Many Thanks.
Steve
-----Original Message-----
From: Gabriel Roldan [mailto:groldan@…13…] On Behalf Of Gabriel Roldán
Sent: 25 January 2011 15:42
To: Steve Way
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] GS 2.1.0 RC1 + GWC
Hi There,
shutting down tomcat once geoserver.war is deployed and deleting *gwc* from WEB-INF/lib works for me. You probably deleted only gwc* and got web-gwc.jar still in there?
Could you describe better the situation/problems you face? may be there's a simple solution but I don't quite understand what's going on from what you're saying.
Gabriel
Steve
DISCLAIMER:
notify the sender at Infotech or Mail.Admin@...2634...
-------- Special Offer-- Download ArcSight Logger for FREE (a $49 USD
value)!
Gabriel Roldan
groldan@...1501...
