[Geoserver-devel] gs-geofence-server and wicket-dnd on 2.8.x
The community module gs-geofence-server was failing to compile on 2.8.x with a clean local Maven repo because its dependency wicket-dnd:wicket-dnd:0.4.2 is no longer available from the Google Code repository. This was breaking coverage of the communityRelease profile on Travis CI for 2.8.x.
Only gs-geofence-server on 2.8.x uses this artifact and repository; 2.9.x and master use com.github.svenmeier.wicket-dnd:wicket-dnd:0.7.3, which is available from Maven Central.
As a workaround, I manually deployed wicket-dnd:wicket-dnd:0.4.2 to the osgeo repo. I did not have the sources jar in my local repo, so feel free to deploy them if you have them. The sources are still available in the Google Code archive (only built artifacts have gone away). This artifact will likely only be used in one GeoServer release, 2.8.5, but we should have it in a working repository so GeoServer -PcommunityRelease can be built from source.
I also removed the obsolete Google Code repo from gs-geofence-server on master, 2.9.x, and 2.8.x.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Thanks for taking care of this Ben, I don't have the sources JAR
in my local repository and I think they where not available.
Kind regards,
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
mob: +39 333 8128928
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono
da considerarsi strettamente riservate. Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate
nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e
-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai
The information in this message and/or attachments, is intended solely for the attention and use of
the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree
June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named
addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the
information in this message that has been received in error. The sender does not give any warranty or accept liability as the content,
accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which
arise as a result of e-mail transmission, viruses, etc.
Sorry I was not clear ... what I mean was that the sources JAR was never available :slight_smile:
> Kind regards,
@nmcoliveira
Software Engineer
This problem will solve itself in October when support for 2.8.x ceases. :slight_smile:
Director
New Zealand
