jive
1
A number of PRs are “blocked” by gs-metadata failing on GitHub actions environment.
As this is a recent difficulty is it possible to revert changes to restore build stability? Or turn off tests temporarily …
As this is being disruptive I would like to ask if we can fix this (ahead of code sprint on saturday).
Jody Garnett
It should normally be fixed now if the build is re-run.
Jody Garnett
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
jive
3
Thanks I saw your PR write after sending email.
Jody Garnett
Jody Garnett
