I had not noticed before that EPSG folks are trolling with the official remarks as in
http://www.epsg-registry.org/indicio/query?request=GetRepositoryItem&id=urn:ogc:def:crs:EPSG::3067
gml:remarksIdentical to ETRS89 / UTM zone 35N (code 25835) except for area of use.
See ETRS89 / TM35FIN(N,E) (code 5048) for more usually used alternative with
axis order reversed.</gml:remarks>
Nobody uses EPSG:5048 in Finland as far as I know.
-Jukka Rahkonen-
Andrea Aime wrote:
On Wed, Sep 24, 2014 at 11:58 AM, Ville Karppinen <ville.karppinen@…3920…> wrote:
My question is related to the issue https://jira.codehaus.org/browse/GEOS-6651 which ended up to be a user error related to the bbox value. It seems that when version 1.3.0 bbox coordinates are swapped, only some of the images are shown properly. This seems to depend on the srs-value. For example in our services, &srs=EPSG:3035 shows images properly but when using &srs=EPSG:3067 images become totally white.
Yes, WMS 1.3 requires swapped coordinates only if the SRS in question uses
north/east orientation in the official EPSG database, you can check its online
version here: http://www.epsg-registry.org/
As a simplified rule, most of the geographic CRS need to use lat/lon order,
most of the projected ones are east/north instead (although there are a few exceptions
of projected SRS that still use north/east order)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
