I made a test with Geoserver 2.6-RC1 by creating a new image mosaic from scratch. I used two aerial images which are natively in EPSG:3067. The resulting layer works without errors both through WMS 1.1.1 and WMS 1.3.0.
I would recommend to build the mosaic again by increasing it little by little. It may be that Geoserver has troubles with georeferencing of some granule even it does feel odd that WMS 1.1.1 works well while 1.3.0 does not.
-Jukka Rahkonen-
Lähettäjä: Andrea Aime [mailto:andrea.aime@…1268…]
Lähetetty: 24. syyskuuta 2014 15:12
Vastaanottaja: Ville Karppinen
Kopio: Geoserver-devel
Aihe: Re: [Geoserver-devel] Gs2.5.2 ImageMosaic layers show totally white image for version=1.3.0 even if bbox values swapped. Related to GEOS-6651.
On Wed, Sep 24, 2014 at 2:02 PM, Ville Karppinen <ville.karppinen@…3920…> wrote:
Version 1.3.0 gives an error, even if an image is expected (no need to
flip bbox, using CRS instead of SRS in URL):
http://wms.fmi.fi/fmi-apikey/4bda0057-9e4a-453e-9fa9-966a15a368e1/geoserver/Radar/wms?LAYERS=Radar%3Asuomi_rr_eureffin&STYLES=&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG%3A3067&BBOX=-117278.40864788,6335621.1670142,874514.7741461,7907751.5372634&WIDTH=323&HEIGHT=512
1.3.0 error:
Error rendering coverage on the fast path
org.opengis.geometry.MismatchedReferenceSystemException: The coordinate
reference system must be the same for all objects. The coordinate
Do you have the full stack trace?
Also, any chance you can share a (small) dataset that can be used to reproduce the issue you’re seeing?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
