Ciao Jody,
simply put when doing a fix:
- one must investigate if a backport is needed/ca be done
- one must capture this investigation in the JIRA and/or PR
- actual backport is optional (at least for the time being).
Long story short, I do expect people to bother and make sure a
backport can be done.
This should be captured preferably in JIRA. If they also the actual
backport even better.
That said, my +1 is already there.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Mon, Jun 29, 2015 at 5:50 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks Simone, Your edit seemed to mostly consist of a reminder about
feature back ports? I may need to end up drawing a diagram
Still if you are content with the direction of this GSIP please vote +1. I
will try and make seperate pull requests for each topic so we can keep
conversations distinct.
Jody Garnett
On 29 June 2015 at 05:21, Simone Giannecchini
<simone.giannecchini@anonymised.com> wrote:
Ciao Jody (et al.),
I am done with editing, please, review.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Sat, Jun 27, 2015 at 8:17 PM, Simone Giannecchini
> Ciao Jody,
> I will review my edits again on Mon with the others hence I would off a
> bit
> before moving on.
> Regards,
> Simone.
> Il 27/Giu/2015 16:39, "Jody Garnett" <jody.garnett@anonymised.com> ha
> scritto:
>> Thanks for the discussion Ben / Simone.
>> For this proposal I am just trying to capture our intent as a steering
>> committee. We can either sort out the exact language now in the
>> proposal or
>> in the subsequent pull requests.
>> Jody Garnett
>> On 25 June 2015 at 13:17, Jody Garnett <jody.garnett@anonymised.com> wrote:
>>> Proposal is ready for review and voting:
>>> - GSIP 129 - Dev Guide Refresh
>>> The proposal is covering a number of topics (since our developers
>>> guide
>>> covers a number of topics).
>>> The three requiring approval from the PSC list are:
>>> - removing the section on roadmap planning
>>> - adding a section on responsible disclosure
>>> - adjusting release schedule (for July beta, August RC1 (and code
>>> freeze), September release)
>>> - Clarification on our expectations for submitting fixes to master /
>>> stable / maintenance
>>> You are encouraged to read and revise the above link as I will be
>>> using
>>> the wording their as the basis for editing the developers guide.
>>> Jody Garnett
>> Monitor 25 network devices or servers for free with OpManager!
>> OpManager is web-based network management software that monitors
>> network devices and physical & virtual servers, alerts via email & sms
>> for fault. Monitor 25 devices for free with no restriction. Download
>> now
>> http://ad.doubleclick.net/ddm/clk/292181274;119417398;o
>> _______________________________________________
>> Geoserver-devel mailing list
>> Geoserver-devel@lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
for fault. Monitor 25 devices for free with no restriction. Download now
