[Geoserver-devel] GSIP-137 ResourceStore REST API Proposal
Here is the proposal from Niels:
https://github.com/geoserver/geoserver/wiki/GSIP-137
+1 the proposal has been revised addressing my earlier questions.
Jody Garnett
I have read the email thread and the proposal.
+1 on the new functionality.
On Tue, Jan 26, 2016 at 10:51 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
Geoserver-devel mailing list
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
Hi Jody,
-1 for the moment, but only because the proposal is incomplete.
Bits that should be addressed before making it go forward:
  • Show the XML and JSON representations of the various resources and commands (are they properly interlinked via atom links, and what other information do they contain?). This is the most evident limitation of the proposal, as these are not implementation bits, but rightful part of the protocol you’re proposing to implement
  • Determine what happens if format is used against a file resource (that I assume we cannot transcode to another format), and what mime type will be returned for them (e.g., property files)
  • What is the metadata of a directory? I assume we can return metadata for a file too, but the proposal only mentions a format for directories
  • How does one tell apart the desire to upload a zip file, from one of uploading a directory to be unpacked? How does one create an emtpy directory?
  • I don’t claim to be a REST expert, but the POST usage seems strange… should’t POST be used only when the target resource position is determined by the server instead of by the caller? Some guidance here: http://restcookbook.com/HTTP%20Methods/put-vs-post/
  • HEAD requests for metadata seem a good idea
Finally, a general question, how is the resource work going to interact with the existing rest path mappers? What if for example one wants to upload via
the REST api some large data set to be configured, and make sure it’s going to be saved on disk instead of DBMS, because it needs to accessed
via random access and it’s in general very large?
My understanding is that JDBCConfig would only handle config and not data, but want to make sure.
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Andrea,
Thanks for your review.
On 27-01-16 10:48, Andrea Aime wrote:
Hi Jody,
* Show the XML and JSON representations of the various resources and commands (are they properly interlinked via atom links, and what other information do they contain?). This is the most evident limitation of the proposal, as these are not implementation bits, but rightful part of the protocol you're proposing to implement
I added information on the XML format for metadata and directories (JSON is analogue).
* Determine what happens if format is used against a file resource (that I assume we cannot transcode to another format), and what mime type will be returned for them (e.g., property files)
Format is only used for metadata and directories. Otherwise, you get the actual file in its own format.
This is why I used to have two endpoints, because I found it weird to have the same GET for both the metadata with specified format or the file itself with server determined format; but the community preferred it this way.
* What is the metadata of a directory? I assume we can return metadata for a file too, but the proposal only mentions a format for directories
That was a mistake (changed), metadata is for any resource irrespective of type.
* How does one tell apart the desire to upload a zip file, from one of uploading a directory to be unpacked?
I removed the zip part from the proposal, because feedback told me there isn't really need for that atm.
One does not create an empty directory. It is not part of the ResourceStore API, I had an extensive discussion about that with Jody last year who insisted it should not be possible. Directories are created on-the-fly.
* I don't claim to be a REST expert, but the POST usage seems strange... should't POST be used only when the target resource position is determined by the server instead of by the caller? Some guidance here: http://restcookbook.com/HTTP%20Methods/put-vs-post/
In that case, I should simply scrap the POST method from the proposal, the functionality is fully covered by PUT.
This is fine by mes.
* HEAD requests for metadata seem a good idea
the REST api some large data set to be configured, and make sure it's going to be saved on disk instead of DBMS, because it needs to accessed
via random access and it's in general very large?
My understanding is that JDBCConfig would only handle _config_ and not data, but want to make sure.
The JDBCResourceStore has a configuration option for excluding directories. By default, the data upload directory is excluded, and any operation on this directory gets automatically forwarded to the FileSystem ResourceStore.
Regards
Niels
Thanks Andrea, all good feedback - these proposals end up being design documents after all.
I don’t think I know enough about how rest path mappers work to understand the difference between config and data. Internally the ResourceStoreAPI is used to access config, and a different GeoServerDataDirectory method is used to resolve relative URLs into a file reference for data access.
I had a similar question with respect to the difference between “config” and “catalog” - consider using this rest api in the styles folder - we want to access the “sld” and “font” files, but ignore the “xml” files used by the catalog configuration - since they are stored elsewhere/available by another rest api.
On 27 January 2016 at 01:48, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Jody Garnett
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea, have I addressed your questions well enough with my changes?
Do we agree on removing POST altogether (have not yet changed this in the proposal yet)?
Niels
On 27-01-16 11:29, Niels Charlier wrote:
Hi Andrea,
Hi Jody,
is analogue).
it this way.
of type.
created on-the-fly.
wants to upload via
Regards
Niels
Hi Niels,
I’m sorry, still haven’t had time to review your changes.
I’ll be fully packed till evening today too, but I’ll make sure to review everything during
the weekend
On Fri, Jan 29, 2016 at 1:57 PM, Niels Charlier <niels@anonymised.com> wrote:
the proposal yet)?
Niels
Hi Andrea,
Hi Jody,
    is analogue).
it this way.
    of type.
    isn’t really need for that atm.
created on-the-fly.
wants to upload via
Regards
Niels
Ing. Andrea Aime
@geowolf
Technical Lead
Yes and no. I can now see the representation, and confirm the answer to
"are they properly interlinked via atom links?" has a negative answer.
The ResourceMetadata xml representation should be follow the same resource
interlinking
approach as our main REST API, for example:
<ResourceMetaData>
      <name> nameOfFile </name>
      <parent>
          <path>path/to/parent</path>
          <atom:link xmlns:atom="http://www.w3.org/2005/Atom&quot;
rel="alternate" href="
http://localhost:8080/geoserver/rest/resource/path/to/parent.xml&quot;
type="application/xml"/>
       <parent>
      <lastModified> date </lastModified>
      <type> UNDEFINED | RESOURCE | DIRECTORY </type>
  </ResourceMetaData>
and the same should be valid for the json representation.
Same goes for the directory representation.
the proposal yet)?
I'd remove POST, two ways to do exactly the same things seem redundant to
me,
not sure what other think... maybe the API is easier to use if one does not
have to remember whether to use PUT or POST? :slight_smile:
There are questions that still do not get an answer in the proposal, see as
follows:
Yes, but what mime type do we get? You have to return one right?
I understand it's hard to guess the mime type of a random file, so one
could say
that it's going to be "application/octet-stream", which is the most generic.
Or maybe you want to apply some special treatment to well known extensions,
like .properties and .xml or .sld.
I see that Java 7 has this useful API, maybe it can be used for a guess?
http://docs.oracle.com/javase/7/docs/api/java/nio/file/Files.html#probeContentType(java.nio.file.Path)
In any case, the proposal should state something in this respect.
Writing the above I actually raised one more question: what happens if
someone
goes and chances configuration files using the resource REST api?
It's ok to say "it's store implementation dependent", but at least we
should make
a statement on that (otherwise people will start assuming that the behavior
of one store is actually valid for all stores).
Oh, and one final question, I see it's a proposal, I'm assuming this means
these
new endpoints will be folded in the main rest API, instead of being a
community
module, right?
So is it going to be implemented using the same library as the main REST
api?
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jan 27, 2016 at 5:11 PM, Jody Garnett <jody.garnett@anonymised.com>
I don't think I know enough about how rest path mappers work to
Path mappers are used for data uploads, and they can tell you that certain
data
must be placed outside of the data directory (e.g., in a large share for
raster data).
Will this implementation consider that case?
Ing. Andrea Aime
@geowolf
Technical Lead
Modified. Fair enough, done. I didn’t want anything based on Files, because I don’t want to force caching it as a file just to determine the mime type. But I have found a way that uses both filename and content: I have added to the proposal that content type will be guessed in this manner. I don’t understand your point. The REST API will give to administrators the same control over the resource store as they would have through the file system with a regular data directory. Yes. Regards Niels
On 30-01-16 12:08, Andrea Aime wrote:
The ResourceMetadata xml representation should be follow the same resource interlinking
I’d remove POST, two ways to do exactly the same things seem redundant to me,
not sure what other think… maybe the API is easier to use if one does not
http://docs.oracle.com/javase/7/docs/api/java/nio/file/Files.html#probeContentType%28java.nio.file.Path%29
		String mimeType = URLConnection.guessContentTypeFromName(resource.name());
                if (MediaType.APPLICATION_OCTET_STREAM.getName().equals(mimeType)) {
                    try (InputStream is = new BufferedInputStream(resource.in())) {
                        mimeType = URLConnection.guessContentTypeFromStream(is);
                    } catch (IOException e) {
                        //do nothing, keep at application/octet-stream
Writing the above I actually raised one more question: what happens if someone
It’s ok to say “it’s store implementation dependent”, but at least we should make
Oh, and one final question, I see it’s a proposal, I’m assuming this means these
new endpoints will be folded in the main rest API, instead of being a community
module, right?
So is it going to be implemented using the same library as the main REST api?
On Tue, Feb 2, 2016 at 11:26 AM, Niels Charlier <niels@anonymised.com> wrote:
someone
should make
I don't understand your point. The REST API will give to administrators
Yes and no, and imho this should be clarified.
With the data directory we have a clear position, if one modifies the xml
configuration files on disk, nothing
happens, GeoServer will not notice, unless a reload is forced or it's
otherwise specified (e.g., control-flow
configuraton file, or other flies that are under a watcher).
However if I reload I have a guarantee that the config file changes will be
picked up
But if you have JDBCConfig and JDBCResourceStore then things become
somewhat more complicated...
the xml config file is saved in the resource store I assume, but I assume
JDBCConfig will not notice at all,
since it has its own database, and thus a "reload" will do nothing...
or will it be notified and will change the config db contents?
If you don't want to get into those details I'm happy to just have a
statement stating that
changing a config file has an undefined behavior, and then have some docs
to warn the users of that.
Ing. Andrea Aime
@geowolf
Technical Lead
Hmmm, I still find it difficult to understand your point.
If you are using JDBCConfig, the catalog .xml files become meaningless, are ignored and changing them never has any effect. There is no difference there whether you are using jdbcstore or not.
As far as I see it, changing a config resource with the REST API or on the file system is identical.
Regards
Niels
On 02-02-16 11:44, Andrea Aime wrote:
On Tue, Feb 2, 2016 at 11:26 AM, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
    happens if someone
    the behavior
With the data directory we have a clear position, if one modifies the xml configuration files on disk, nothing
happens, GeoServer will not notice, unless a reload is forced or it's otherwise specified (e.g., control-flow
However if I reload I have a guarantee that the config file changes will be picked up
But if you have JDBCConfig and JDBCResourceStore then things become somewhat more complicated...
the xml config file is saved in the resource store I assume, but I assume JDBCConfig will not notice at all,
If you don't want to get into those details I'm happy to just have a statement stating that
changing a config file has an undefined behavior, and then have some docs to warn the users of that.
Ing. Andrea Aime
@geowolf
Technical Lead
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Geoserver will kind of notice in both cases - icons are cached so will not pick up on a change unless we add a watcher (or until as you say the next reload).
Things like security that already have a watcher will be noticed in both cases.
We should put this off until we look at notification - chances are we will introduce notification which will benefit both JDBC and File resource store implementations.
happens, GeoServer will not notice, unless a reload is forced or it’s otherwise specified (e.g., control-flow
But if you have JDBCConfig and JDBCResourceStore then things become somewhat more complicated…
since it has its own database, and thus a “reload” will do nothing…
If you don’t want to get into those details I’m happy to just have a statement stating that
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Feb 2, 2016 at 11:54 AM, Niels Charlier <niels@anonymised.com> wrote:
You are right... it's just that my original expectation was different,
since the two plugins are developed
by the same company I was (wrongly) assuming there would be some
integration/synergy between them.
No problem. +1 on the proposal in its current state.
Ing. Andrea Aime
@geowolf
Technical Lead
+1. Looking pretty good. Observations:
- Instead of metadata, it would be (arguably) more RESTful to support a HEAD operation. You have a header for Last-Modified, could add an X-Parent and X-Type, and name could be deduced from the URL. Or is the need for custom HTTP headers a red flag? (Not to mention the problems passing these through the stack.) Andrea raised the issue of HEAD and I do not recall seeing a response. Please state why you are not using HEAD. The core need I see is for directory traversal. I dislike parsing URLs to find a parent resource, but would that be more RESTful? Is the use of a metadata parameter a REST best practice?
- I am not sure that "operation" is the right word to GET "metadata", but I do not have an alternative. Metadata is not a format. "aspect", perhaps? Do we have anything similar in the existing API?
- Are resources strictly a tree? Can you have loops? Unix filesystems support this with hard links, in which there can be multiple paths for a single resource, all canonical. What does this mean for recursive deletion? It might be worth documenting your assumptions.
- Should this API support parameters from the main REST API like "recurse" and "quietOnNotFound"? There may be more. I am not saying that I like these parameters; I think this GSIP is a bit more RESTful. I just thought that users might expect them. Please skim the existing REST API as a final review with consistency in mind.
- Should these be lowercase? Uppercase looks out of place:
"<type> UNDEFINED | RESOURCE | DIRECTORY </type>"
- Document that POST returns a 405.
Kind regards,
Ben.
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
HI Ben,
Thanks for your review!
Cool thanks, that makes it approved then.
I did send an email about the HEAD operation. Last-modified will be supported. I did not actually think of using custom http headers for the other fields. That is interesting. We can support both.
I guess I can change it back to metadata=1 as it was in an earlier version if that is preferred, but I found it more consistent with the other requests this way. The way I see it, getting the metadata is a different operation than getting the data.
I don't know if I would call it "supported". It is technically possible, but strongly discouraged, and most modern Linuxes make it impossible to hard link directories to prevent it from happening. I believe last time I encountered this about 10 years ago, my delete operation got into an infinitive loop and started to delete my whole hard drive. The ResourceStore API definitely doesn't support it, it would regard paths of different sizes as different resources. The same for JDBCstore, you can technically create such a loop directly into the database but I would regard that as a corruption of the database's integrity (and there are many other ways in which one could corrupt the resource database if an evil or stupid person manipulated the DBMS directly).
recurse -> delete, move and copy on a directory is always recursive. The alternative is failing, but I see little need to force people to
specify this explicitly. If you do an operation on a directory that is generally what you intend to do. That is different to someone wanting to delete a store who might not realise he is deleting layers. I dunno, if people still want it I can easily implement this.
quietOnNotFound -> I'd never log exceptions when someone requests a resource that is not found. That is not an error, it is still a valid request. Simply return 404
Yeah that is the internal representation, I can easily convert it to lowercase of course.
ok.
Regards
Niels
fyi, the "X-" prefix for custom headers is not the recommended approach any
more... http://tools.ietf.org/html/rfc6648#section-3
*Recommendations for Creators of New Parameters*
Creators of new parameters to be used in the context of
application protocols:
1. SHOULD assume that all parameters they create might
become standardized, public, commonly deployed, or usable across multiple
implementations.
2. SHOULD employ meaningful parameter names that they have reason
to believe are currently unused.
3. SHOULD NOT prefix their parameter names with "X-" or
similar constructs.
Rob :slight_smile:
Page updated, totalling up the numbers has this one passed:
Hopefully the work can get in before the Feb 18th cut-off.
On 26 January 2016 at 13:51, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Jody Garnett
implementations.
similar constructs.
Rob :slight_smile:
Thanks for the link, Rob. That is a good point. I felt that custom headers are a bad idea and was soliciting suggestions for best-practices for RESTful directory traversal with HEAD to find a parent. Surely someone has tried this? Or is it an acceptable practice to assume that HTTP URLs can be parsed to remove trailing path elements?
Kind regards,
Director
New Zealand
I think custom headers are fine, it’s just that if someone is using them in practice they’ll know to expect them :slight_smile:
RESTful directories (IMO) should be self-documenting: the parent of /a/b/c is /a/b and so on…
AFAICT there’s nothing special in the metadata proposal that couldn’t be dealt with via:
Content-Type: application/directory (or of a file)
Last-Modified:
(sure, XML/JSON for consistency/other reasons is fine).
Whether it’s a file or directory, the parent resource comes from the next path segment…
Rob :slight_smile:
fyi, the “X-” prefix for custom headers is not the recommended approach any
more… http://tools.ietf.org/html/rfc6648#section-3
    implementations.
  3. SHOULD NOT prefix their parameter names with “X-” or
    similar constructs.
Rob :slight_smile:
Kind regards,
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Chief Technical Officer Koordinates
+44 759 987 3480 / koordinates.com / @koordinates
