+1 much needed addition
From experience either extension of plugin.
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Thu, Mar 24, 2016 at 9:52 AM, Ian Turton <ijturton@anonymised.com> wrote:
+1
I like plugin followed by module
Ian
On 23 March 2016 at 20:35, Andrea Aime <andrea.aime@anonymised.com> wrote:
+1 here too
I'd go for module status, after all 90% of what we care about are
"extensions" and "community modules".
As an alternative, PluginStatus, since people tend to call our modules
plugins, since they are indeed pluggable.
On Wed, Mar 23, 2016 at 8:53 PM, Kevin Smith <smithkm@anonymised.com> wrote:
+1
"ConfigurationStatus" sounds a bit vague while "ExtensionStatus" might
be a bit too narrow. "ComponentStatus" or maybe "ModuleStatus" seem
like they hit the mark.
Kevin Michael Smith
On Wed, Mar 23, 2016, at 07:43 AM, Chris Snider wrote:
> Hi,
> Not a voting member, but I would be ok with either ConfigurationStatus
> or
> ComponentStatus. However, I would lean more towards
> ConfigurationStatus
> if I get a preference.
> Chris Snider
> Senior Software Engineer
> Intelligent Software Solutions, Inc.
> -----Original Message-----
> From: Ben Caradoc-Davies [mailto:ben@anonymised.com]
> Sent: Tuesday, March 22, 2016 5:00 PM
> To: Jody Garnett <jody.garnett@anonymised.com>; Morgan Thompson
> <mthompson@anonymised.com>
> Cc: Geoserver Developers <geoserver-devel@lists.sourceforge.net>
> Subject: Re: [Geoserver-devel] GSIP-143 Extension Status
> Or ComponentStatus?
> On 23/03/16 11:48, Jody Garnett wrote:
> > The proposal is written as ExtensionStatus (makes sense as those are
> > the
> > things users install), is their any advantage to calling it
> > ConfigurationStatus (so we can report on on things like
> > RenderingEngine
> > from gs-main which is not properly an extension).
> Ben Caradoc-Davies <ben@anonymised.com>
> Director
> Transient Software Limited <http://transient.nz/>
> New Zealand
> Transform Data into Opportunity.
> Accelerate data analysis in your applications with
> Intel Data Analytics Acceleration Library.
> Click to learn more.
> http://pubads.g.doubleclick.net/gampad/clk?id=278785351&iu=/4140
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Ian Turton
