[Geoserver-devel] GSIP 145 Back-up and Restore Extension for GeoServer Configuration
This proposal has a lot of far reaching ideas, much more than we could get through in todays meeting:
Alessio are you available for a breakout meeting to discuss/review?
Jody Garnett
Hello Jody,
yes of course. Lets just have an agreement on the time schedule :slight_smile:
By the way the development branch is available here
https://github.com/geosolutions-it/geoserver/tree/backup_restore
based on GeoServer master.
Is still under review/development (need to add more tests and finish few tasks, especially on the GeoServer Configuration workflow).
On Tue, May 31, 2016 at 10:31 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
Thanks Alessio:
Careful reading of the proposal shows one key addition to core - the use of “variables” in resolution of connection parameters. So this GSIP could of been done as a small API / GUI change for variables — and a community module request. But the larger context is very helpful.
For the core variable API / GUI change I would like to ask for some clarifications:
a) where do the variables come from?
Introductionn: “on a file external to the data directory”
design the solution “The location where this file is placed will be configurable also via an env variable similarly to how the GeoServer data dir is setup (env variable, system variable, servlet context parameter).”
b) is their a GUI for these variables? REST API?
I expect that if this is a file it will just be reported via status extension / status page.
Not sure if you want additional details listed or logged (showing the variables).
c) Can these variables be configured on a node by node basis?
I guess the idea would be to fill in this file as part of node provisioning.
My previous feedback still applies:
  • Are we working too hard - introducing complexity that is already covered by Servlet API? These variables could be provided by JNDI (configured as part of the application server).
Your specific example is already covered by JNDI connection pool use:
jdbc.driverClassName = “my_value”
jdbc.connectUrl = “my_value”
However we can take that to a directory value:
rasters = “/mnt/team_data/rasters”
Jetty: http://www.eclipse.org/jetty/documentation/9.3.x/jndi-configuration.html
rasters
true
  • The background (/rest/br/backup/) REST API for backup/restore stuff is very cool - both technically and functionally. As mentioned it is similar to the async importer workflow and I would like see if we can combine forces - rather than have more and more async activity implementations added to GeoServer at time.
One option is to ignore this while you are working on a community module, and consider it again when you are interested making this an extension.
The second option is to think ahead to “/rest/activity” end-point would look like, define backup and restore as initial operations, and long term migrate importer, catalog reload, coveagestore statistics, bounds calculations as activities.
I apologize that the above feedback is a bit off topic for your direct need, I would be happy to work with you on an “rest activity” proposal if this is a strategic direction you agree with (or one that the PSC likes). The advantage of taking this into account now is that your customer’s REST API endpoint would not need to be migrated.
On 1 June 2016 at 01:06, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hello Jody,
Jody Garnett
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
Hi Jody,
thanks for your reviews and the time you spent on taking a look deeply both at the code and the proposal.
Let me try to reply to your questions.
First of all, currently I focused my energies to complete the backup & restore tool (which is almost ready, except for further feedbacks and reviews). For that reasons I still have to start the work on the configuration migration through the environment variables. This is something I’m going to face starting from the next week, so I’m open to review the technical analysis.
Since the proposal is more oriented to the backup & restore stuff, I wanted to maintain the core variable API / GUI changes less invasive as possible.
So the idea here is to put just the basis for further improvements of the configuration workflow.
I didn’t envisage any REST / GUI interfaces, but only the possibility of (optionally) use placeholders as part of the resources connection parameters in order to take the advantage of using external GeoServer environment variables to make it portable through different systems. My idea would be to create a more specific and detailed GSIP only for the configuration workflow in the future.
I’ll take a look at the serlvet API you are proposing and come back with more questions before start coding.
About the “/rest/activity” idea, I abosolutely agree with you. We need to move towards a unified platform. Lets start talking about on how to proceed and put down some ideas and directions.
We can work on this once the community module has been deeply tested, refactored if/where needed and we are it is stable. Before converting it into an official extension we can work on this common REST endpoint and then start moving the importer too.
On Wed, Jun 1, 2016 at 8:43 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks Alessio:
rasters
true
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
Hello Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
Dear all,
JIRAs and PRs have been created regarding this GSIP.
The specific PR is https://github.com/geoserver/geoserver/pull/1668 but, as stated in the comments, this strictly depends on the other related Jiras.
Therefore in order to fully compile the following Jiras must be merged first:
  1. GEOS-7611
  2. GEOS-7613
  3. GEOS-7614 depends-on GeoWebCache Issue #400
  4. GEOS-7616
  5. GEOS-7619
Nevertheless the code is there for your review.
Thank you all for your help in advance.
-A.
On Fri, Jun 3, 2016 at 12:19 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Hi Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Best Regards,
Alessio Fabiani.
@alfa7691
Thanks Alessio:
rasters
true
Jody Garnett
Hello Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
Here is a link for GeoWebCache pull request 400 https://github.com/geowebcache/geowebcache/issues/400 is this what you intended?
Checking GSIP-145 we have not collected enough votes to proceed … can we kick this discussion up a notch? Thus far it has just been the two of us I would like to hear from other PSC members.
On 5 July 2016 at 02:22, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Dear all,
  1. GEOS-7611
  2. GEOS-7613
  4. GEOS-7616
  5. GEOS-7619
-A.
Jody Garnett
Best Regards,
Alessio Fabiani.
@alfa7691
Hi Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Thanks Alessio:
rasters
true
Jody Garnett
Hello Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
Yep,
I understand that is a lot of stuff to digest … hopefully the others can find some time to take a look at the proposal and provide some feedbacks.
I tried to split the PRs in order to keep them as much simple and separate as possible. Also the backup&resotre stuff for the moment (as we already discussed with Jody) is a community module with the idea to merge also the importer stuff under a unique REST contest in the future (please read the previous emails in the thread).
On Wed, Jul 6, 2016 at 9:28 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
Dear all,
  1. GEOS-7611
  2. GEOS-7613
  4. GEOS-7616
  5. GEOS-7619
-A.
Best Regards,
Alessio Fabiani.
@alfa7691
Hi Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Thanks Alessio:
rasters
true
Jody Garnett
Hello Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
This work is done https://github.com/geoserver/geoserver/wiki/GSIP-145
It has one +1 from Ian, I am waiting on resolving tasks before voting myself.
On 7 July 2016 at 01:28, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Yep,
Jody Garnett
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
Dear all,
  1. GEOS-7611
  2. GEOS-7613
  4. GEOS-7616
  5. GEOS-7619
-A.
Best Regards,
Alessio Fabiani.
@alfa7691
Hi Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Thanks Alessio:
rasters
true
Jody Garnett
Hello Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Jody Garnett
Ciao Jody,
I have not understood what you mean by "I am waiting on resolving
tasks before voting myself".
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Jul 26, 2016 at 6:24 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
myself.
Jody Garnett
wrote:
Yep,
I understand that is a lot of stuff to digest ... hopefully the others can
Best Regards,
Alessio Fabiani.
@alfa7691
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
intended?
Checking GSIP-145 we have not collected enough votes to proceed ... can
Jody Garnett
Dear all,
first:
GEOS-7611
GEOS-7613
GEOS-7616
GEOS-7619
-A.
Best Regards,
Alessio Fabiani.
@alfa7691
for the attention and use of the named addressee(s) and may be confidential
or proprietary in nature or covered by the provisions of privacy act
Hi Jody,
I'm going to face starting from the next week, so I'm open to review the
technical analysis.
possible.
I didn't envisage any REST / GUI interfaces, but only the possibility
I'll take a look at the serlvet API you are proposing and come back
About the "/rest/activity" idea, I abosolutely agree with you. We need
Best Regards,
Alessio Fabiani.
@alfa7691
wrote:
Thanks Alessio:
use of "variables" in resolution of connection parameters. So this GSIP
could of been done as a small API / GUI change for variables --- and a
clarifications:
   Introductionn: "on a file external to the data directory"
   design the solution "The location where this file is placed will be
dir is setup (env variable, system variable, servlet context parameter)."
the variables).
provisioning.
- Are we working too hard - introducing complexity that is already
use:
  Jetty:
<New class="org.eclipse.jetty.plus.jndi.EnvEntry">
  <Arg></Arg>
  <Arg>rasters</Arg>
  <Arg type="java.lang.String">/mnt/team_data/rasters</Arg>
  <Arg type="boolean">true</Arg> <!-- this is an override of web.xml
</New>
- The background (/rest/br/backup/) REST API for backup/restore stuff
GeoServer at time.
extension.
  The second option is to think ahead to "/rest/activity" end-point
direct need, I would be happy to work with you on an "rest activity"
customer's REST API endpoint would not need to be migrated.
Jody Garnett
Hello Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
Le informazioni contenute in questo messaggio di posta elettronica
e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio, per
le finalità indicate nel messaggio stesso. Qualora riceviate questo
solely for the attention and use of the named addressee(s) and may be
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
Protection Code).Any use not in accord with its purpose, any disclosure,
reproduction, copying, distribution, or either dissemination, either whole
or partial, is strictly forbidden except previous formal approval of the
named addressee(s). If you are not the intended recipient, please contact
- https://github.com/geoserver/geoserver/wiki/GSIP-145
Jody Garnett
What NetFlow Analyzer can do for you? Monitors network bandwidth and traffic
patterns at an interface-level. Reveals which users, apps, and protocols are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning
reports.http://sdm.link/zohodev2dev
Geoserver-devel mailing list
I was interested in hearing about the “/rest/activity” idea. Andrea’s feedback in today’s meeting has resolved by question - it is not a good idea as it goes against how rest is expected to be organized.
With that in mind I have added my +1 to the proposal.
On 26 July 2016 at 09:45, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Jody,
I have not understood what you mean by “I am waiting on resolving
tasks before voting myself”.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New
myself.
Jody Garnett
wrote:
Yep,
Best Regards,
Alessio Fabiani.
@alfa7691
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
intended?
Jody Garnett
Dear all,
first:
GEOS-7611
GEOS-7613
GEOS-7616
GEOS-7619
-A.
Best Regards,
Alessio Fabiani.
@alfa7691
Hi Jody,
technical analysis.
possible.
Best Regards,
Alessio Fabiani.
@alfa7691
wrote:
Thanks Alessio:
clarifications:
the variables).
provisioning.
use:
Jetty:
rasters
true
  • rather than have more and more async activity implementations added to
    GeoServer at time.
extension.
Jody Garnett
Hello Jody,
Best Regards,
Alessio Fabiani.
@alfa7691
privacy act (Legislative Decree June, 30 2003, no.196 - Italy’s New Data
Jody Garnett
planning
Jody Garnett
Ciao Jody,
thanks for the quick turnaround on this.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Tue, Jul 26, 2016 at 6:53 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I was interested in hearing about the "/rest/activity" idea. Andrea's
feedback in today's meeting has resolved by question - it is not a good idea
Jody Garnett
Ciao Jody,
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
> myself.
> Jody Garnett
> wrote:
>> Yep,
>> can
>> feedbacks.
>> separate
>> already
>> the
>> the
>> Best Regards,
>> Alessio Fabiani.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> loro
>> le
>> messaggio
>> notizia
>> divulgarlo
>> utilizzarlo per
>> dettati
>> for
>> or
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> reproduction,
>> copying, distribution, or either dissemination, either whole or
>> partial, is
>> strictly forbidden except previous formal approval of the named
>> immediately the sender by telephone, fax or e-mail and delete the
>> does
>> completeness of sent messages and accepts no responsibility for
>> changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>>> intended?
>>> can
>>> of us
>>> Jody Garnett
>>>> Dear all,
>>>> but,
>>>> Jiras.
>>>> merged
>>>> first:
>>>> GEOS-7611
>>>> GEOS-7613
>>>> GEOS-7616
>>>> GEOS-7619
>>>> -A.
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> e/o
>>>> Il loro
>>>> per le
>>>> messaggio
>>>> notizia
>>>> divulgarlo
>>>> utilizzarlo per
>>>> dettati
>>>> solely
>>>> confidential
>>>> Protection
>>>> reproduction,
>>>> partial, is
>>>> sender does
>>>> changes
>>>> of
>>>>> Hi Jody,
>>>>> deeply
>>>>> and
>>>>> something
>>>>> the
>>>>> technical analysis.
>>>>> as
>>>>> possible.
>>>>> of
>>>>> possibility
>>>>> GeoServer
>>>>> My idea
>>>>> need
>>>>> to
>>>>> tested,
>>>>> converting it
>>>>> and then
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> e/o
>>>>> Il loro
>>>>> per le
>>>>> messaggio
>>>>> notizia
>>>>> divulgarlo
>>>>> utilizzarlo per
>>>>> dettati
>>>>> solely
>>>>> confidential
>>>>> Protection
>>>>> reproduction,
>>>>> partial, is
>>>>> sender does
>>>>> or
>>>>> changes
>>>>> of
>>>>> wrote:
>>>>>> Thanks Alessio:
>>>>>> the
>>>>>> GSIP
>>>>>> and a
>>>>>> clarifications:
>>>>>> be
>>>>>> GeoServer data
>>>>>> parameter)."
>>>>>> (showing
>>>>>> the variables).
>>>>>> provisioning.
>>>>>> use:
>>>>>> Jetty:
>>>>>> <Arg></Arg>
>>>>>> <Arg>rasters</Arg>
>>>>>> web.xml
>>>>>> </New>
>>>>>> stuff
>>>>>> is similar
>>>>>> combine forces
>>>>>> added to
>>>>>> GeoServer at time.
>>>>>> an
>>>>>> extension.
>>>>>> and long
>>>>>> bounds
>>>>>> activity"
>>>>>> that the
>>>>>> your
>>>>>> Jody Garnett
>>>>>>> Hello Jody,
>>>>>>> finish
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> riservate. Il
>>>>>>> messaggio, per
>>>>>>> questo
>>>>>>> di
>>>>>>> messaggio
>>>>>>> stesso,
>>>>>>> copiarlo, od
>>>>>>> contrario ai
>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>> be
>>>>>>> of
>>>>>>> New Data
>>>>>>> disclosure,
>>>>>>> either whole
>>>>>>> of the
>>>>>>> contact
>>>>>>> sender does
>>>>>>> or
>>>>>>> changes
>>>>>>> result of
>>>>>>>> discuss/review?
>>>>>>>> Jody Garnett
> traffic
> are
> planning
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
planning
+1
Jody Garnett
planning reports. [https://ad.doubleclick.net/ddm/clk/305295220;132659582;e](https://ad.doubleclick.net/ddm/clk/305295220;132659582;e)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Kevin Michael Smith
[<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
+1
-Jukka Rahkonen-
Jody Garnett
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Kevin Michael Smith
[<smithkm@...3859...>](mailto:smithkm@...3859...)
