We have enough votes already, but I’m here asking to make another final review and give an “OK to go” to the PR.
On Wed, Oct 5, 2016 at 6:09 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
I’m going to give it a try and consequently enrich the GSIP both with your suggestion and the logout handlers.
-A.
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
Best Regards,
Alessio Fabiani.
@alfa7691
On Wed, Oct 5, 2016 at 6:08 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Alessio,
you might be able to componentize the static html form this way:
http://examples7x.wicket.apache.org/compref/wicket/bookmarkable/org.apache.wicket.examples.compref.IncludePage
Not sure, never used it, but it looks like it could be a fit
On Wed, Oct 5, 2016 at 5:50 PM, Alessio Fabiani <alessio.fabiani@anonymised.com.4522…it> wrote:
Currently not, I left it untouched for two reasons mainly:
Wanted to leave the current code as much as possible similar to the original one. Just extending it.
(more technical) The current login button is a form with fields. The proposal is for links to endpoints redirecting to external login pages. Modifying the actual login button in order to be compatible with the new API means basically to introduce more complexity and render full wicket panels with custom controls. We can do this, but it will require users to write also custom code for the login buttons instead of a simple XML configuration.
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Best Regards,
Alessio Fabiani.
@alfa7691
On Wed, Oct 5, 2016 at 5:43 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
As part of this proposal is the existing login button being migrated to the new api (you know for consistency?).
On Wed, Oct 5, 2016 at 1:05 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
btw, anyone has any clue about https://github.com/geoserver/geoserver/wiki/GSIP-150 ?
I’m not familiar with the proponent, nor I have seen any discussion about it
engaging tech sites, SlashDot.org! http://sdm.link/slashdot_______________________________________________
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Jody Garnett
On Tue, Oct 4, 2016 at 10:01 PM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
+1. Looks useful.
The committee changed this to GSIP 151 as there was already a 150:
https://github.com/geoserver/geoserver/wiki/GSIP-151
Kind regards,
Ben.
On 30/09/16 23:45, Alessio Fabiani wrote:
A small yet useful GSIP.
https://github.com/geoserver/geoserver/wiki/GSIP-150—Pluggable-Login-Web-Component
It refers to the recent development on the OneLogin and OAuth2 security
provider extensions for GeoServer, but it can also be useful for CAS and
others needing to redirect outisde for authentication.
Please, comment and vote.
Best Regards,
Alessio Fabiani.
@alfa7691
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Ing. Andrea Aime
@geowolf
Technical Lead
