Given the lack of feedback, I think I will defer this until after the code freeze, aiming for the 2.12 release.
The CatalogFacade changes are only likely to affect alternative catalog implementations. Given that this is something that probably should have been included in the initial CatalogEvent implementation, I think this should be fine.
On Mon, Feb 20, 2017 at 1:23 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
sorry I lost track of this one, too many things going on.
I too got bitten by this limitation of the API, and while it breaks an interface,
I’m not aware of an easy way to plug a different Catalog implementation, so I guess all
current implementation are actually inside the GeoServer code.
I see it also breaks CatalogFacade implementations, which is instead pluggable… but I guess
rather uncommon to implement in code outside GeoServer? I cannot remember seeing one.
+1
On Fri, Feb 10, 2017 at 7:22 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Continuing from earlier discussion, a GSIP is required in order for this change to actually get into GeoServer, see: https://github.com/geoserver/geoserver/wiki/GSIP-157
This proposal is to update the CatalogPostModifyEvent (and associated firePostModifed methods) to track changed values, similar to the current implementation of CatalogModifyEvent.
This requires some API changes in a few catalog methods and interfaces.
Ultimately, it is a useful, but relatively minor change requiring some not-backwards-compatible API changes.
While I would like to get this into 2.11, I understand that it is cutting it a bit close to the code freeze at this point.
Torben
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
